Here is the websocket server example, in the platformio library search it is " WebSockets by Markus Sattler", unmodified fresh from the library, in arduino it works fine, but on platformio, it gives an error
variable “WiFiMulti” is not a type name
at line containing: WiFiMulti WiFiMulti;
i have no idea what the problem is or how to address such a problem
* WebSocketServer.ino
* Created on: 22.05.2015
#include <WiFi.h>
#include <WiFiMulti.h>
#include <WiFiClientSecure.h>
#include <WebSocketsServer.h>
WebSocketsServer webSocket = WebSocketsServer(81);
#define USE_SERIAL Serial1
void hexdump(const void *mem, uint32_t len, uint8_t cols = 16) {
const uint8_t* src = (const uint8_t*) mem;
USE_SERIAL.printf("\n[HEXDUMP] Address: 0x%08X len: 0x%X (%d)", (ptrdiff_t)src, len, len);
for(uint32_t i = 0; i < len; i++) {
if(i % cols == 0) {
USE_SERIAL.printf("\n[0x%08X] 0x%08X: ", (ptrdiff_t)src, i);
USE_SERIAL.printf("%02X ", *src);
src++;
USE_SERIAL.printf("\n");
void webSocketEvent(uint8_t num, WStype_t type, uint8_t * payload, size_t length) {
switch(type) {
case WStype_DISCONNECTED:
USE_SERIAL.printf("[%u] Disconnected!\n", num);
break;
case WStype_CONNECTED:
IPAddress ip = webSocket.remoteIP(num);
USE_SERIAL.printf("[%u] Connected from %d.%d.%d.%d url: %s\n", num, ip[0], ip[1], ip[2], ip[3], payload);
// send message to client
webSocket.sendTXT(num, "Connected");
break;
case WStype_TEXT:
USE_SERIAL.printf("[%u] get Text: %s\n", num, payload);
// webSocket.sendTXT(num, "message here");
// send data to all connected clients
// webSocket.broadcastTXT("message here");
break;
case WStype_BIN:
USE_SERIAL.printf("[%u] get binary length: %u\n", num, length);
hexdump(payload, length);
// webSocket.sendBIN(num, payload, length);
break;
case WStype_ERROR:
case WStype_FRAGMENT_TEXT_START:
case WStype_FRAGMENT_BIN_START:
case WStype_FRAGMENT:
case WStype_FRAGMENT_FIN:
break;
// USE_SERIAL.begin(921600);
USE_SERIAL.begin(115200);
//Serial.setDebugOutput(true);
USE_SERIAL.setDebugOutput(true);
USE_SERIAL.println();
for(uint8_t t = 4; t > 0; t--) {
USE_SERIAL.printf("[SETUP] BOOT WAIT %d...\n", t);
USE_SERIAL.flush();
delay(1000);
WiFiMulti.addAP("SSID", "passpasspass");
while(WiFiMulti.run() != WL_CONNECTED) {
delay(100);
webSocket.begin();
webSocket.onEvent(webSocketEvent);
webSocket.loop();
