Hi, I’m currently using the --with-all-packages
option with pio platform install
for dependency caching. I am aware that pio platform install
is deprecated and will be removed in future releases. Is there an equivalent flag to use with the newer pio pkg install
command? Thanks.
CC @ivankravets since I don’t see this option being implemented in platformio-core/install.py at develop · platformio/platformio-core · GitHub
What is the reason for --with-all-packages
Well, the original reason was: I thought that the package manager didn’t install required packages for a platform. I was attempting to use this flag to force-install all of the available packages.
The reason I thought that the package manager wasn’t installing the required packages: I am using the --storage-dir
option, combined with -p
for a platform. However, pio pkg install
will ignore the --storage-dir
option for all of the subsequent required packages it finds for a platform, installing them instead to the default global package location.
For example, running pio pkg install -f --storage-dir /path/to/cache -p example-platform
results in the example-platform
being installed to /path/to/cache
, while its required packages are installed to ~/.platformio/packages
. I’m pretty sure this is a bug. I would think that the platform and all required packages should be installed to the specified storage-dir. If so, I can open an issue in GitHub and take a look at it to see if it’s an easy fix.
This is not a bug. Tools and dev-platforms are located in different locations. See
What I could recommend:
- Create a dummy PIO project with overridden “dir” options
- Use it as a “template” to install dependencies to custom locations.
Thanks for the helpful feedback!
