EDIT: Cross-posted GitHub issue is live here.
I purchased one of the official ESP32-S2-DevKitM-1 boards from Espressif on Amazon and am trying to figure out how to get an example project built and uploaded to my board.
As far as I know, there is no exact match for my board in the PlatformIO board library, but I think that the ESP32-S2-Saola-1 is probably the closest target available. I started trying things on my own (trying to adapt this known-good project that I’ve used with my ESP-8266 NodeMCU 1.0), only to realize I had no idea what I was doing
and try to find an example project to start from. However, I haven’t found a combination of targets and projects that have built or uploaded successfully.
I was trying for a while to get the repo’s platform-espressif32/examples/espidf-arduino-wifiscan example project to work, but I kept running into issues. The Build All task seems to indicate that env:esp-wrover-kit and env:esp32dev both build correctly: But neither uploads because my part is the ESP32-S2 variant and not the regular ESP32.
`esp32dev`
> Executing task: C:\Users\neilb\.platformio\penv\Scripts\platformio.exe run --target upload --environment esp32dev <
Processing esp32dev (board: esp32dev; platform: espressif32; framework: arduino, espidf)
--------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------Verbose mode can be enabled via `-v, --verbose` option
PLATFORM: Espressif 32 (3.2.1) > Espressif ESP32 Dev Module
- framework-arduinoespressif32 0.0.0+sha.d011dd7
- framework-espidf 3.40001.200521 (4.0.1)
- tool-cmake 3.16.4
- tool-esptoolpy 1.30000.201119 (3.0.0)
- tool-idf 1.0.1
- tool-mconf 1.4060000.20190628 (406.0.0)
- tool-ninja 1.9.0
- toolchain-esp32ulp 1.22851.191205 (2.28.51)
- toolchain-xtensa32 2.80400.210211 (8.4.0)
Warning! Arduino framework as an ESP-IDF component doesn't handle the `variant` field! The default `esp32` variant will be used.
Found 0 compatible libraries
Retrieving maximum program size .pio\build\esp32dev\firmware.elf
Checking size .pio\build\esp32dev\firmware.elf
RAM: [= ] 12.1% (used 39660 bytes from 327680 bytes)
Flash: [====== ] 64.0% (used 671254 bytes from 1048576 bytes)
AVAILABLE: esp-prog, espota, esptool, iot-bus-jtag, jlink, minimodule, olimex-arm-usb-ocd, olimex-arm-usb-ocd-h, olimex-arm-usb-tiny-h, olimex-jtag-tiny, tumpa
Looking for upload port...
Auto-detected: COM5
Uploading .pio\build\esp32dev\firmware.bin
esptool.py v3.0
Serial port COM5
Connecting....
A fatal error occurred: This chip is ESP32-S2 not ESP32. Wrong --chip argument?
*** [upload] Error 2
================================================================================================================ [FAILED] Took 16.34 seconds ================================================================================================================
Environment Status Duration
esp32dev FAILED 00:00:16.339
=========================================================================================================== 1 failed, 0 succeeded in 00:00:16.339 ===========================================================================================================
The terminal process "C:\Users\neilb\.platformio\penv\Scripts\platformio.exe 'run', '--target', 'upload', '--environment', 'esp32dev'" terminated with exit code: 1.
`esp32dev`
> Executing task: C:\Users\neilb\.platformio\penv\Scripts\platformio.exe run --target upload --environment esp-wrover-kit <
Processing esp-wrover-kit (board: esp-wrover-kit; platform: espressif32; framework: arduino, espidf)
CONFIGURATION: https://docs.platformio.org/page/boards/espressif32/esp-wrover-kit.html
PLATFORM: Espressif 32 (3.2.1) > Espressif ESP-WROVER-KIT
DEBUG: Current (ftdi) On-board (ftdi) External (esp-prog, iot-bus-jtag, jlink, minimodule, olimex-arm-usb-ocd, olimex-arm-usb-ocd-h, olimex-arm-usb-tiny-h, olimex-jtag-tiny, tumpa)
- tool-cmake 3.16.4
- tool-idf 1.0.1
- tool-ninja 1.9.0
Retrieving maximum program size .pio\build\esp-wrover-kit\firmware.elf
Checking size .pio\build\esp-wrover-kit\firmware.elf
AVAILABLE: esp-prog, espota, esptool, ftdi, iot-bus-jtag, jlink, minimodule, olimex-arm-usb-ocd, olimex-arm-usb-ocd-h, olimex-arm-usb-tiny-h, olimex-jtag-tiny, tumpa
Auto-detected: COM5
Uploading .pio\build\esp-wrover-kit\firmware.bin
esptool.py v3.0
Serial port COM5
Connecting....
================================================================================================================ [FAILED] Took 15.12 seconds ================================================================================================================
esp-wrover-kit FAILED 00:00:15.118
=========================================================================================================== 1 failed, 0 succeeded in 00:00:15.118 ===========================================================================================================
The terminal process "C:\Users\neilb\.platformio\penv\Scripts\platformio.exe 'run', '--target', 'upload', '--environment', 'esp-wrover-kit'" terminated with exit code: 1.
But the ESP32-S2-Saola-1 target that I suspect is closest to what I actuall have doesn’t build either because it doesn’t support the arduino framework. Can someone please help me figure out how to use my dev board with the Arduino framework?
I’m fairly confused about what’s going on, lol…
