I am trying to use a struct in an included file, but am receiving the error variable 'My_Struct test_struct2' has initializer but incomplete type
How can I use a struct defined in struct_lib.h in the struct_lib.cpp file?
The code:
// main.cpp
#include <struct_lib.h>
struct My_Struct test_struct = { 0 };
Serial.println();
Serial.println(test_struct.value);
Serial.println(test_struct2.value);
void loop() {}
// struct_lib.h
#ifndef STRUCT_LIB_H_INCLUDED
#define STRUCT_LIB_H_INCLUDED
struct My_Struct {
int value;
extern struct My_Struct test_struct2;
// struct_lib.cpp
struct My_Struct test_struct2 = { 0 };
I am compiling for an ESP8266 with the Arduino framework.
I found this issue on the Arduino IDE, is this related?
The test code is also here.
Thank you for helping me out!
You forgot to #include "struct_lib.h"
in your struct_lib.cpp
. Otherwise you are using an undeclared type. It compiles for me when I do that.
Thank you! I just spent far too long trying to find that.
Hello all, I’ve got some trouble with this kind of example:
suppose I want to change the value of test_struct2 in struct_lib.cpp (where it is defined) like this :
/ struct_lib.cpp
#include “struct_lib.h”
test_struct2.value=3;
It’s does’nt work , when compiling I have the error message :
Compiling .pio/build/uno/src/struct_lib.cpp.o
src/struct_lib.cpp:6:1: error: ‘test_struct2’ does not name a type
test_struct2.value=4;
meanwhile, if I try the same in main.cpp it works !
Serial.println();
I’ve been hours on this without success, will appreciate any help, thanks in advance
Are you trying to write into the value
field of a global structure without that code being inside any function? That won’t work.
You need to initialize the strucutre not with 0 but with your desired value, like
.value = 3
That’s exactly what I found 2 minutes ago : it has to be inside a function !!
Many thanks for the confirmation.
