Hi, having hard time to get something done which seems simple: use sensor_lora_node_PSoC4100S.cpp or
sensor_usb_node_SAMD21.cpp (both in project src ), depending on the env: below.
Without src_filter the build works fine (with not-to-be-used --.cpp file removed from src first).
Using src_filter breaks the build because .h files in the project’s include are not found.
What am I doing wrong…?
[platformio]
default_envs = cubecell_board
src_dir = src/
[common]
src_filter = -<*.cpp> -<lic/> ; exclude all .cpp files in src directory
[env:cubecell_board]
platform = asrmicro650x
board = cubecell_board
build_flags = -I include
src_filter = ${common.src_filter} +<sensor_lora_node_PSoC4100S.cpp> ; use only this .cpp
[env:sodaq_sff]
platform = atmelsam
board = sodaq_sff
board_build.mcu = samd21g18a
board_build.f_cpu = 48000000L
src_filter = ${common.src_filter} +<sensor_usb_node_SAMD21.cpp> ; use only this .cpp
upload_protocol = sam-ba
