Using ProcessUnFlags in middlewares script?
Hello all,
I’m importing an edge-impulse middleware into a project. The Tensorflow contents produce some build errors (due to uninitialized variables). My solution is to use the middleware script, as below.
My question is does the env.ProcessUnFlags(“-Werror=maybe-uninitialized”) only effect the node captured or the entire project? Is there a better way to do this?
Thanks
Import("env")
import sys
# --- Add custom macros for the ALL files which path contains "edge-impulse-sdk"
def edge_impulse_sdk_configuration(env, node):
    if "edge-impulse-sdk" not in node.get_path():
        return node
    # Remove -Werror=maybe-uninitialized
    print("WARNING: Adding custom build flags for edge-impulse-sdk")
    env.ProcessUnFlags("-Werror=maybe-uninitialized")
    return node
env.AddBuildMiddleware(edge_impulse_sdk_configuration)
That looks like it effects the whole project / environment.
You can try something like
        return node
    return env.Object(
        node,
        CCFLAGS=[flag for flag in env["CCFLAGS"] if flag != "-Werror=maybe-uninitialized"]
Many thanks, I’ll give that a go.
