Hi.
Does anyone here use a ESP8266 NONOS SDK? I can’t make even the simplest code to work. I copied examples from GitHub - platformio/platform-espressif8266: Espressif 8266: development platform for PlatformIO, code compiles perfectly, but after upload device (wemos d1 mini) gets stuck in a reboot loop.
ets Jan 8 2013,rst cause:2, boot mode:(3,6
Arduino sdk works fine. I don’t know how to bite this
I experimented with different boards (different flash sizes) but to no avail.
Damn, should I really have to read entire chip and SDK documentation to build and run included sample code?
I am sticking to linux ubuntu compiling for nonos sdk. This platformio is nonsense, shame though, it is advertised really well, was excited to try it out.
Also…arduino doesn’t work too well for me in platformio either. Blinky works, but other stuff not su much. Just tried to run relatively complex code built in platformio, and all hell broke loose. Same code works flawlessly and beatifully in arduino
We don’t maintain it personally. It seems that we should remove these SDKs from our supported list and wait when someone will provide better integration.
The problem is the exact same as I have already solved before and reported: The ESP-8266-Non-OS build script doesn’t flash the esp_init_data_default.bin file to the correct address for the module. In fact, it doesn’t flash / compile it all (for all modules, not as only for 1MB modules as I assumed) when you look at the build / flash commands
The actuall correct uplaod command for me would be to load esp_init_data_default.bin to 0x3fc000 (4MB module). You can go into your tool-esptool folder and after-flash the file
Now it’s questionable for me if I should fix this because probably, the community-provided new ESP8266-RTOS/NONOS builders will be far better than the current one and will work with the most current SDK version (see here), so it doesn’t make sense to work on old stuff; that is, when it’s planned to integrate this builder into the main platform-espressif8266. Or what do you think @ivankravets?
As I explained, use esptool and the correct path to the esp_init_data_default.bin file. Depending on your PIO core installation it’s e.g. in C:\Users\<user>\.platformio\packages\tool-esptool\esptool.exe and the esp_init_data_default.bin is in packages\framework-esp8266-nonos-sdk\bin\esp_init_data_default.bin.
You’d need to construct the correct command with the correct path and execute it in a command shell (cmd.exe).
We’d have to write a fix for the python builder script but I think there will be an update to this entire platform soon so I didn’t bother with it, see above.
Once you execute that command one time, the contents should be kept there unless you erase the chip, so it should stay there even if you upload another firmware.
There was also a bugfix release 2.0.4 so if you do a platform update (pio platform update or via the VSCode IDE) it suffices to say platform = espressif8266 now. (If you want to be extra carefull you can platform = espressif8266@>=2.0.4 to make sure you get at least that version)
Okay another question about using NONOS SDK with platformIO.
How to use heatshrink- a data compression/decompression library for embedded/real-time systems on data files (SPIFFS) for ESP8266 on platformIO. is it possible? I’ve used it already with NONOS SDK, but, not sure how to do it on platformIO
