I need to build 8266 code with arduino framework 2.7.4 and according to the docs at
https://docs.platformio.org/en/latest/platforms/espressif8266.html#using-arduino-framework-with-staging-version
I have aligned my platformio.ini accordingly:
[env:d1_mini_pro]
platform = espressif8266
board = d1_mini_pro
platform_packages =
platformio/framework-arduinoespressif8266 @https://github.com/esp8266/Arduino.git#2843a5a
; platformio/framework-arduinoespressif8266 @ https://github.com/esp8266/Arduino/releases/download/2.7.4/esp8266-2.7.4.zip
Error reads (first few lines):
In file included from C:\Users\Inso.platformio\packages\framework-arduinoespressif8266\cores\esp8266/Arduino.h:41,
from C:\Users\Inso.platformio\packages\framework-arduinoespressif8266\cores\esp8266\abi.cpp:22:
C:\Users\Inso.platformio\packages\framework-arduinoespressif8266\cores\esp8266/core_esp8266_version.h: In instantiation of ‘constexpr int conststr::parseNthInteger(const char (&)[N], unsigned int) [with unsigned int N = 6]’:
C:\Users\Inso.platformio\packages\framework-arduinoespressif8266\cores\esp8266/core_esp8266_version.h:130:37: required from here
C:\Users\Inso.platformio\packages\framework-arduinoespressif8266\cores\esp8266/core_esp8266_version.h:118:1: internal compiler error: in bot_manip, at cp/tree.c:3055
118 | }
My main is reduced to
void setup(void) {}
void loop(){}
to ensure the problem is not code or lib related.
I have seen that often in parallel to framework-arduinoespressif8266 also tool-esptoolpy is changed, but I cannot find the version to be used with 2.7.4.
Is it necessary at all?
Or is there something else I am missing?
