hi…i have an open source project which uses a library which i need to adapt to be embedded as create a PR for it…
the problem is that the libary uses a makefile to build, which mean it has several folders of source code (which aside from src and include) which won’t compile unless they’ll see each other
for example i have one source file in src folder which uses stpncpy.c , i have other source files in extra folder which use the source files in src folder so they won’t compile unless they’ll see them
my only other option is to create pre-post python scrypt that just copy all the src files i need from one folder to another into lib folder
# Copyright (c) 2018 Y Paritcher
PREFIX=$$HOME/x-tools/arm-unknown-linux-gnueabi/bin/arm-unknown-linux-gnueabi-
PREFIXKT4=arm-kindlepw2-linux-gnueabi-
CC=gcc
AR=ar
RANLIB=ranlib
CFLAGS=-Wall -Wextra -Wno-format-truncation -O2 -flto -pedantic $(INC_DIR:%=-I%)
LDLIBS=-lm
INC_DIR = include
STATICDIR=build/static
SHAREDDIR=build/shared
LIBDIR=lib
SRCDIR=src/
EXTRADIR=extra/
FFIDIR=ffi-cdecl/
LUADIR=lua/
PYTHONDIR=python/
sharedobjects := $(patsubst $(SRCDIR)%.c,$(SHAREDDIR)/%.o,$(wildcard $(SRCDIR)*.c))
staticobjects := $(patsubst $(SRCDIR)%.c,$(STATICDIR)/%.o,$(wildcard $(SRCDIR)*.c))
extraexecs := $(patsubst %.c, %, $(wildcard $(EXTRADIR)*.c))
fficdefs := $(LUADIR)libzmanim.lua $(PYTHONDIR)libzmanim_cdef.py
TESTDIR=test/
TESTLDFLAGS=-L$(LIBDIR)
TESTLDLIBS=-lzmanim
TESTLDLIB=-l:libzmanim.a
testobjects := $(patsubst %.c,%.o,$(wildcard $(TESTDIR)*.c))
VPATH = src $(INC_DIR)
.PHONY: clean cleaner all shared static test directories teststatic testshared teststandard kindle KT4 fresh extra wasm rock ffi
all:
$(MAKE) directories
$(MAKE) shared static
$(MAKE) test extra
kindle: CC = $(PREFIX)gcc
kindle: AR = $(PREFIX)ar
kindle: RANLIB = $(PREFIX)ranlib
kindle: directories shared static test
KT4: CC = $(PREFIXKT4)gcc
KT4: AR = $(PREFIXKT4)gcc-ar
KT4: RANLIB = $(PREFIXKT4)gcc-ranlib
KT4: directories shared static test
rock: cleaner directories shared
wasm: CC = clang
wasm: CFLAGS= -DNOSTDLIB -Wall -Wextra --target=wasm32 -nostdlib -mmultivalue -Xclang -target-abi -Xclang experimental-mv -Wl,--no-entry -Wl,--export-all $(INC_DIR:%=-I%)
wasm: $(LIBDIR)/libzmanim.wasm
directories: | $(SHAREDDIR) $(STATICDIR) $(LIBDIR)
shared: $(LIBDIR)/libzmanim.so
static: $(LIBDIR)/libzmanim.a
test: teststatic testshared teststandard
teststatic: static $(TESTDIR)teststatic
testshared: shared $(TESTDIR)testshared
teststandard: static $(TESTDIR)test
$(LIBDIR):
mkdir -p $(LIBDIR)
$(STATICDIR):
mkdir -p $(STATICDIR)
$(SHAREDDIR):
mkdir -p $(SHAREDDIR)
$(LIBDIR)/libzmanim.so: $(sharedobjects)
$(CC) -shared $(LDFLAGS) $^ $(LDLIBS) -o $@
$(LIBDIR)/libzmanim.a: $(staticobjects)
$(AR) rc $@ $^
$(RANLIB) $@
$(LIBDIR)/libzmanim.wasm: $(wildcard $(SRCDIR)hebrewcalendar.c)
$(CC) $(CFLAGS) -o $@ $^
$(SHAREDDIR)/%.o: $(SRCDIR)%.c
$(CC) -fPIC -c $(CPPFLAGS) $(CFLAGS) $< -o $@
$(STATICDIR)/%.o: $(SRCDIR)%.c
$(CC) -static -c $(CPPFLAGS) $(CFLAGS) $< -o $@
$(TESTDIR)%.o: $(TESTDIR)%.c
$(CC) -c $(CPPFLAGS) $(CFLAGS) $< -o $@
$(TESTDIR)teststatic: $(testobjects)
$(CC) -static $(TESTLDFLAGS) $^ $(TESTLDLIBS) -lm -o $@
$(TESTDIR)testshared: $(testobjects)
$(CC) $(TESTLDFLAGS) $^ $(TESTLDLIBS) -o $@
$(TESTDIR)test: $(testobjects)
$(CC) $(TESTLDFLAGS) $^ $(TESTLDLIB) $(LDLIBS) -o $@
testobjects: shared static
extra: static $(extraexecs)
$(extraexecs): %: %.c
$(CC) $(CFLAGS) $(TESTLDFLAGS) $^ $(TESTLDLIB) $(LDLIBS) -o $@
install:
mkdir -p $(INST_LIBDIR)
cp lib/libzmanim.so $(INST_LIBDIR)
mkdir -p $(INST_LUADIR)
cp $(LUADIR)libzmanim.lua $(INST_LUADIR)
cp $(LUADIR)libzmanim_load.lua $(INST_LUADIR)
$(fficdefs): $(FFIDIR)libzmanim.c
CPPFLAGS="$(INC_DIR:%=-I%)" ffi-cdecl $(CC) $^ $@
ffi: $(fficdefs)
clean:
rm -f $(SHAREDDIR)/*.o $(STATICDIR)/*.o $(TESTDIR)test.o
cleaner: clean
rm -f $(LIBDIR)/libzmanim.so $(LIBDIR)/libzmanim.a $(TESTDIR)testshared $(TESTDIR)teststatic $(TESTDIR)test $(extraexecs) $(LIBDIR)/libzmanim.wasm $(fficdefs)
fresh:
$(MAKE) cleaner
$(MAKE) all
