I’m trying to get PlatformIO core cli to run on AWS lambda. My ultimate goal is to be able to kick-off an AWS Lambda function, build a firmware using ESPhome cli (which calls PlatformIO under the hood) and then save the firmware bin to S3.
AWS Lambda has some unique aspects in that the filesystem is read-only except for the /tmp directory which is ephemeral storage. I have built a layer for Lambda which includes all of the python dependencies needed, which is linked to /opt/python which is automatically in the search path. I’ve also set PYTHONPATH=/opt/python in the environment. I’m using the Python 3.12 runtime on x86_64 architecture.
My question is, how do I make PlatformIO use a global python installation and package path, rather than using the default install? Two issues I’m facing:
- PlatformIO cannot find Pyserial. The build actually succeeds but at the end of the build process, it fails looking for Pyserial in
/var/lang/bin/python3.12. It’s not there, because it’s not part of AWS’s Python runtime. Pyserial is installed in/opt/pythonbut pio doesn’t seem to want to look there or respect PYTHONPATH env.
2024-01-12T13:34:59.658Z Linking .pioenvs/simple-test/bootloader.elf
2024-01-12T13:34:59.737Z Building .pioenvs/simple-test/bootloader.bin
2024-01-12T13:34:59.814Z Pyserial is not installed for /var/lang/bin/python3.12. Check the README for installation instructions.
2024-01-12T13:34:59.815Z Traceback (most recent call last):
2024-01-12T13:34:59.815Z File "/tmp/.platformio/packages/tool-esptoolpy/esptool.py", line 31, in <module>
2024-01-12T13:34:59.815Z import esptool
2024-01-12T13:34:59.815Z File "/tmp/.platformio/packages/tool-esptoolpy/esptool/__init__.py", line 42, in <module>
2024-01-12T13:34:59.815Z from esptool.cmds import (
2024-01-12T13:34:59.815Z File "/tmp/.platformio/packages/tool-esptoolpy/esptool/cmds.py", line 14, in <module>
2024-01-12T13:34:59.815Z from .bin_image import ELFFile, ImageSegment, LoadFirmwareImage
2024-01-12T13:34:59.815Z File "/tmp/.platformio/packages/tool-esptoolpy/esptool/bin_image.py", line 14, in <module>
2024-01-12T13:34:59.815Z from .loader import ESPLoader
2024-01-12T13:34:59.815Z File "/tmp/.platformio/packages/tool-esptoolpy/esptool/loader.py", line 21, in <module>
2024-01-12T13:34:59.816Z import serial
2024-01-12T13:34:59.816Z ModuleNotFoundError: No module named 'serial'
2024-01-12T13:34:59.823Z *** [.pioenvs/simple-test/bootloader.bin] Error 1
2024-01-12T13:35:00.772Z ========================= [FAILED] Took 149.28 seconds =========================
- Second issue (less critical) is that pio creates a Python venv for the build automatically. This works, but it’s inefficient because it will download the python dependencies every time, increasing the Lambda execution time and cost. I want to include all the python dependencies in my layer, and force platformIO to not create a venv and instead use the installed python packages in
/opt/python.
2024-01-12T13:33:15.578Z Creating a new virtual environment for IDF Python dependencies
2024-01-12T13:33:19.226Z WARNING: The directory '/home/sbx_user1051/.cache/pip' or its parent directory is not owned or is not writable by the current user. The cache has been disabled. Check the permissions and owner of that directory. If executing pip with sudo, you should use sudo's -H flag.
2024-01-12T13:33:19.315Z Installing ESP-IDF's Python dependencies
2024-01-12T13:33:19.647Z WARNING: The directory '/home/sbx_user1051/.cache/pip' or its parent directory is not owned or is not writable by the current user. The cache has been disabled. Check the permissions and owner of that directory. If executing pip with sudo, you should use sudo's -H flag.
2024-01-12T13:33:19.800Z Collecting urllib3<2
2024-01-12T13:33:19.801Z Obtaining dependency information for urllib3<2 from https://files.pythonhosted.org/packages/b0/53/aa91e163dcfd1e5b82d8a890ecf13314e3e149c05270cc644581f77f17fd/urllib3-1.26.18-py2.py3-none-any.whl.metadata
2024-01-12T13:33:19.840Z Downloading urllib3-1.26.18-py2.py3-none-any.whl.metadata (48 kB)
2024-01-12T13:33:19.850Z ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 48.9/48.9 kB 5.1 MB/s eta 0:00:00
2024-01-12T13:33:20.233Z Collecting cryptography<35.0.0,>=2.1.4
2024-01-12T13:33:20.240Z Downloading cryptography-3.4.8-cp36-abi3-manylinux_2_24_x86_64.whl (3.0 MB)
2024-01-12T13:33:20.275Z ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 3.0/3.0 MB 93.5 MB/s eta 0:00:00
2024-01-12T13:33:20.318Z Collecting future>=0.18.3
2024-01-12T13:33:20.322Z Downloading future-0.18.3.tar.gz (840 kB)
2024-01-12T13:33:20.329Z ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 840.9/840.9 kB 235.5 MB/s eta 0:00:00
2024-01-12T13:33:20.414Z Installing build dependencies: started
2024-01-12T13:33:22.134Z Installing build dependencies: finished with status 'done'
Is there a way to force PlatformIO to find all Python dependencies in /opt/python?
Thanks in advance!
