Hi to everyone.
Currently, I try to structure my project and have the following problem:
In my lib-folder, I have a folder called “my_display”. Here I have “my_display.h” and a “my_display.c” file.
I include the “my_display.h” file in my “src/main.cpp” file, which works fine. But when I add an external library to my “my_display.h” I cannot build the project anymore.
The “my_display.h” looks like this:
#include <TFT_eSPI.h> //by Bodmer v2.4.2
#include <SPI.h>
void newLine();
void drawtext(char *, int16_t, int16_t, uint16_t);
int16_t lastCursorX = 0;
int16_t lastCursorY = 0;
TFT_eSPI tft = TFT_eSPI();
and this is the “my_display.c”
#include "my_display.h"
void newLine() {
lastCursorX = 0;
lastCursorY = lastCursorY+11;
void drawtext(char *text, int16_t x, int16_t y, uint16_t color) {
tft.setCursor(x, y);
tft.setTextColor(color);
tft.setTextWrap(true);
tft.print(text);
lastCursorX = tft.getCursorX();
lastCursorY = tft.getCursorY();
If it is helpful, this is my platformio.ini:
[env:nodemcuv2]
platform = espressif8266
board = nodemcuv2
upload_port = /dev/ttyUSB1
monitor_rts = 0
monitor_dtr = 0
upload_speed = 230400
adafruit/DHT sensor library @ 1.3.0
adafruit/Adafruit Unified Sensor@^1.1.5
arduino-libraries/NTPClient@^3.1.0
paulstoffregen/Time@^1.6.1
bodmer/TFT_eSPI@^2.4.42
jchristensen/Timezone@^1.2.4
bodmer/JPEGDecoder@^1.8.1
The error-output looks like this:
Compiling .pio/build/nodemcuv2/lib1fd/my_display/my_display.c.o
In file included from /home/user/.platformio/packages/framework-arduinoespressif8266/cores/esp8266/Print.h:27,
from .pio/libdeps/nodemcuv2/TFT_eSPI/TFT_eSPI.h:31,
from lib/my_display/my_display.h:2,
from lib/my_display/my_display.c:1:
/home/user/.platformio/packages/framework-arduinoespressif8266/cores/esp8266/Printable.h:25:1: error: unknown type name 'class'
25 | class Print;
/home/user/.platformio/packages/framework-arduinoespressif8266/cores/esp8266/Printable.h:33:1: error: unknown type name 'class'
33 | class Printable {
/home/user/.platformio/packages/framework-arduinoespressif8266/cores/esp8266/Printable.h:33:17: error: expected '=', ',', ';', 'asm' or '__attribute__' before '{' token
In file included from .pio/libdeps/nodemcuv2/TFT_eSPI/TFT_eSPI.h:31,
/home/user/.platformio/packages/framework-arduinoespressif8266/cores/esp8266/Print.h:36:1: error: unknown type name 'class'
36 | class Print {
/home/user/.platformio/packages/framework-arduinoespressif8266/cores/esp8266/Print.h:36:13: error: expected '=', ',', ';', 'asm' or '__attribute__' before '{' token
36 | class Print {
/home/user/.platformio/packages/framework-arduinoespressif8266/cores/esp8266/Print.h:120:9: error: expected '=', ',', ';', 'asm' or '__attribute__' before '<' token
120 | template<> size_t Print::printNumber(double number, uint8_t digits);
In file included from .pio/libdeps/nodemcuv2/TFT_eSPI/TFT_eSPI.h:32,
/home/user/.platformio/packages/framework-arduinoespressif8266/libraries/SPI/SPI.h:43:1: error: unknown type name 'class'
43 | class SPISettings {
/home/user/.platformio/packages/framework-arduinoespressif8266/libraries/SPI/SPI.h:43:19: error: expected '=', ',', ';', 'asm' or '__attribute__' before '{' token
/home/user/.platformio/packages/framework-arduinoespressif8266/libraries/SPI/SPI.h:52:1: error: unknown type name 'class'
52 | class SPIClass {
/home/user/.platformio/packages/framework-arduinoespressif8266/libraries/SPI/SPI.h:52:16: error: expected '=', ',', ';', 'asm' or '__attribute__' before '{' token
/home/user/.platformio/packages/framework-arduinoespressif8266/libraries/SPI/SPI.h:86:8: error: unknown type name 'SPIClass'
86 | extern SPIClass SPI;
In file included from .pio/libdeps/nodemcuv2/TFT_eSPI/Processors/TFT_eSPI_ESP8266.h:35,
from .pio/libdeps/nodemcuv2/TFT_eSPI/TFT_eSPI.h:67,
/home/user/.platformio/packages/framework-arduinoespressif8266/cores/esp8266/FS.h:24:10: fatal error: memory: No such file or directory
24 | #include <memory>
compilation terminated.
*** [.pio/build/nodemcuv2/lib1fd/my_display/my_display.c.o] Error 1
In file included from .pio/libdeps/nodemcuv2/TFT_eSPI/TFT_eSPI.h:868,
from src/main.cpp:17:
My understanding of the problem is, that “TFT_eSPI.h” and/or “SPI.h” have dependencies, which cannot be found, because they are used in another directory (“libs/my_display”) instead of “src/”. And I have no glue how I can fix this.
Does anyone know what I am doing wrong? Am very grateful for any help.
(I’m using the VS-Code-Plugin of Platformio on Ubuntu 21.10.)
