I created a new project for Teensy 4.1 and installed/added the " Embedded Template Library" via library browser. When I try to import any header from the library in main.cpp, I get a error that the header can’t be found.
First of all: Why. The C++ standard template library works on the Teensy thanks to using the arm-none-eabi-gcc/g++ compiler (and not a e.g. a handycapped AVR compiler). Code like this
#undef min
#undef max
#include <etl/list.h>
#include <etl/container.h>
void setup()
// initialize digital pin 13 as an output.
pinMode(13, OUTPUT);
void iterate(const etl::ilist<int>& delays)
etl::ilist<int>::const_iterator itr;
// Iterate through the list.
itr = delays.begin();
while (itr != delays.end())
digitalWrite(13, HIGH); // turn the LED on (HIGH is the voltage level)
delay(100); // wait
digitalWrite(13, LOW); // turn the LED off by making the voltage LOW
delay(*itr++); // wait
void loop()
int delay_times1[] = { 900, 800, 700, 600, 500, 400, 300, 200, 100 };
int delay_times2[] = { 400, 300, 200, 100 };
// Fill the first delay list, then reverse it.
// Notice how we don't have to know the size of the array!
const size_t size1 = sizeof(etl::array_size(delay_times1));
etl::list<int, size1> delays1(etl::begin(delay_times1), etl::end(delay_times1));
delays1.reverse();
// Fill the second delay list,
const size_t size2 = sizeof(etl::array_size(delay_times2));
etl::list<int, size2> delays2(etl::begin(delay_times2), etl::end(delay_times2));
while (true)
iterate(delays1);
iterate(delays2);
