Using ESP-Prog to debug ESP32 code using PlatformIO in VisualCode
If anyone has successfully used ESP32 and ESP-Prog Debugger in PlatformIO using Viscual Code please elt me know, I been trying to connect but its giving me errors.
FTDI drivers are installed. however it does not communicate over port
openocd -f interface/ftdi/esp32_devkitj_v1.cfg -f target/esp32.cfg
Open On-Chip Debugger v0.11.0-esp32-20220706 (2022-07-06-15:48)
Licensed under GNU GPL v2
For bug reports, read
OpenOCD: Bug Reporting
adapter speed: 20000 kHz
Error: libusb_open() failed with LIBUSB_ERROR_NOT_SUPPORTED
Error: libusb_open() failed with LIBUSB_ERROR_NOT_FOUND
Error: no device found
Error: unable to open ftdi device with vid 0403, pid 6010, description ‘', serial '’ at bus location ‘
Error: unable to open ftdi device with vid 0403, pid 6014, description '
’, serial ‘’ at bus location '
looking forward to yuor support
You might need to run Zadig for tweaking the drivers.
You’ll find a good tutorial here
