Using esp idf and arduino... idf wifi init blocks arduino firebase libary
Hi guys, ive been on this for a long time now… basicaly im trying to use esp mesh lite, whitch is supposed to be able to allow the nodes to also acsess the internet inderpendantly this is preferable vs the whole mesh comunicaion being routed through a single root node… the issue im having is i cant get beond the firebase init…
so i use my own provisioning method in the esp idf, this uses smart config etc but it also usees the mesh wifi init vs the more standard wifi init method so tjis is why im stuck using the idf for wifi starting… so i tell the wifi to start whitch it dose and the mesh is running just fine idf side… i then tell arduino to constantly poll to get the time to proove in the arduino side im able to get the basic internet and that works i then use the flag that it go the time to then init the firebase and it just dosnt get past the firebase init ?
for clarity i was able to get the mdf working also facing a similar issue ie if mdf started the wifi it failed at the same spot but if i used arduino the mdf was happy and the firebase was too
am missing something fundermental ? ive asked the firebase lib guys and they are adimnet its not lib related
Still no luck with this this is the mesh code
 * SPDX-FileCopyrightText: 2022-2023 Espressif Systems (Shanghai) CO LTD
 * SPDX-License-Identifier: Apache-2.0
#include <inttypes.h>
#include "esp_log.h"
#include "freertos/task.h"
#include "freertos/timers.h"
#include "esp_wifi.h"
#include "nvs_flash.h"
#include <sys/socket.h>
#include <string.h>
#include <stdlib.h>
#include "freertos/event_groups.h"
#include "esp_event.h"
#include "esp_system.h"
#include "esp_netif.h"
#include "esp_smartconfig.h"
//#include "esp_event_loop.h"
#include "lwip/err.h"
#include "lwip/sys.h"
#if ESP_IDF_VERSION >= ESP_IDF_VERSION_VAL(4, 4, 0)
#include "esp_mac.h"
#include "esp_bridge.h"
#include "esp_mesh_lite.h"
#define PAYLOAD_LEN (1456) /**< Max payload size(in bytes) */
static EventGroupHandle_t s_wifi_event_group;
const int WIFI_CONNECTED_BIT = BIT0;
static const int ESPTOUCH_DONE_BIT = BIT1;
static const char *TAG2 = "smartconfig_example";
static void check_status()
    EventBits_t uxBits;
    uxBits = xEventGroupGetBits(s_wifi_event_group);
    if (uxBits & WIFI_CONNECTED_BIT)
        printf("wifi connected\n");
    else if (!(uxBits & WIFI_CONNECTED_BIT))
        printf("wifi disconnected\n");
uint8_t ssid[33] = {0};
uint8_t password[65] = {0};
uint8_t rvd_data[65] = {0};
char *ssid_str = NULL;
char *password_str = NULL;
extern bool wifi_connected;
extern bool start_config;
#define SMARTCONFIG_START_CONFIG() {   \
    .enable_log = false,               \
    .esp_touch_v2_enable_crypt = true, \
    .esp_touch_v2_key = "qwBIf6GbZZ5jj7Kc"};
static void smartconfig_example_task(void *parm);
static void event_handler(void *arg, esp_event_base_t event_base,
                          int32_t event_id, void *event_data)
    if (event_base == WIFI_EVENT && event_id == WIFI_EVENT_STA_START)
        xTaskCreate(smartconfig_example_task, "smartconfig_example_task", 4096, NULL, 3, NULL);
    else if (event_base == WIFI_EVENT && event_id == WIFI_EVENT_STA_DISCONNECTED)
        esp_wifi_connect();
        xEventGroupClearBits(s_wifi_event_group, WIFI_CONNECTED_BIT);
        check_status();
    else if (event_base == IP_EVENT && event_id == IP_EVENT_STA_GOT_IP)
        xEventGroupSetBits(s_wifi_event_group, WIFI_CONNECTED_BIT);
        check_status();
    else if (event_base == SC_EVENT && event_id == SC_EVENT_SCAN_DONE)
        ESP_LOGI(TAG2, "Scan done");
    else if (event_base == SC_EVENT && event_id == SC_EVENT_FOUND_CHANNEL)
        ESP_LOGI(TAG2, "Found channel");
    else if (event_base == SC_EVENT && event_id == SC_EVENT_GOT_SSID_PSWD)
        ESP_LOGI(TAG2, "Got SSID and password");
        smartconfig_event_got_ssid_pswd_t *evt = (smartconfig_event_got_ssid_pswd_t *)event_data;
        wifi_config_t wifi_config;
        bzero(&wifi_config, sizeof(wifi_config_t));
        memcpy(wifi_config.sta.ssid, evt->ssid, sizeof(wifi_config.sta.ssid));
        memcpy(wifi_config.sta.password, evt->password, sizeof(wifi_config.sta.password));
        wifi_config.sta.bssid_set = evt->bssid_set;
        if (wifi_config.sta.bssid_set == true)
            memcpy(wifi_config.sta.bssid, evt->bssid, sizeof(wifi_config.sta.bssid));
        memcpy(ssid, evt->ssid, sizeof(evt->ssid));
        memcpy(password, evt->password, sizeof(evt->password));
        ESP_LOGI(TAG2, "SSID:%s", ssid);
        ESP_LOGI(TAG2, "PASSWORD:%s", password);
        ESP_ERROR_CHECK(esp_smartconfig_get_rvd_data(rvd_data, sizeof(rvd_data)));
        ESP_LOGI(TAG2, "RVD_DATA:%s", rvd_data);
        ESP_ERROR_CHECK(esp_wifi_disconnect());
        ESP_ERROR_CHECK(esp_wifi_set_config(WIFI_IF_STA, &wifi_config));
        esp_wifi_connect();
    else if (event_base == SC_EVENT && event_id == SC_EVENT_SEND_ACK_DONE)
        nvs_handle_t my_handle;
        esp_err_t err = nvs_open("storage", NVS_READWRITE, &my_handle);
        if (err != ESP_OK)
            printf("Error (%s) opening NVS handle!\n", esp_err_to_name(err));
        else
            err = nvs_set_str(my_handle, "ssid", (char *)ssid);
            printf((err != ESP_OK) ? "Failed to write ssid!\n" : "Wrote ssid\n");
            err = nvs_set_str(my_handle, "password", (char *)password);
            printf((err != ESP_OK) ? "Failed to write password!\n" : "Wrote password\n");
            err = nvs_set_str(my_handle, "rvd_data", (char *)rvd_data);
            printf((err != ESP_OK) ? "Failed to write rvd_data!\n" : "Wrote rvd_data\n");
            err = nvs_commit(my_handle);
            printf((err != ESP_OK) ? "Failed to commit changes!\n" : "Committed changes\n");
            nvs_close(my_handle);
        xEventGroupSetBits(s_wifi_event_group, ESPTOUCH_DONE_BIT);
static esp_err_t esp_storage_init(void)
    esp_err_t ret = nvs_flash_init();
    if (ret == ESP_ERR_NVS_NO_FREE_PAGES || ret == ESP_ERR_NVS_NEW_VERSION_FOUND)
        // NVS partition was truncated and needs to be erased
        // Retry nvs_flash_init
        ESP_ERROR_CHECK(nvs_flash_erase());
    return ret;
void initialise_wifi(void)
    // nvs_flash_erase();
    esp_err_t err = nvs_open("storage", NVS_READWRITE, &my_handle); // Changed from NVS_READONLY to NVS_READWRITE
    if (err == ESP_OK)
        size_t required_size;
        err = nvs_get_str(my_handle, "ssid", NULL, &required_size);
        if (err == ESP_OK)
            ssid_str = malloc(required_size);
            err = nvs_get_str(my_handle, "ssid", ssid_str, &required_size);
        err = nvs_get_str(my_handle, "password", NULL, &required_size);
        if (err == ESP_OK)
            password_str = malloc(required_size);
            err = nvs_get_str(my_handle, "password", password_str, &required_size);
        if (ssid_str && password_str)
            ESP_LOGI(TAG2, "Found NVS WiFi credentials. Starting connecting to wifi...");
            ESP_ERROR_CHECK(esp_netif_init());
            ESP_ERROR_CHECK(esp_event_loop_create_default());
            esp_bridge_create_all_netif();
            s_wifi_event_group = xEventGroupCreate();
            wifi_config_t wifi_config = {
                .sta = {
                    .ssid = "",
                    .password = "",
            strncpy((char *)wifi_config.sta.ssid, ssid_str, sizeof(wifi_config.sta.ssid));
            strncpy((char *)wifi_config.sta.password, password_str, sizeof(wifi_config.sta.password));
            esp_bridge_wifi_set(WIFI_MODE_STA, (char *)wifi_config.sta.ssid, (char *)wifi_config.sta.password, NULL);
            // Softap
            memset(&wifi_config, 0x0, sizeof(wifi_config_t));
            size_t softap_ssid_len = sizeof(wifi_config.ap.ssid);
            if (esp_mesh_lite_get_softap_ssid_from_nvs((char *)wifi_config.ap.ssid, &softap_ssid_len) != ESP_OK)
                snprintf((char *)wifi_config.ap.ssid, sizeof(wifi_config.ap.ssid), "%s", CONFIG_BRIDGE_SOFTAP_SSID);
            size_t softap_psw_len = sizeof(wifi_config.ap.password);
            if (esp_mesh_lite_get_softap_psw_from_nvs((char *)wifi_config.ap.password, &softap_psw_len) != ESP_OK)
                strlcpy((char *)wifi_config.ap.password, CONFIG_BRIDGE_SOFTAP_PASSWORD, sizeof(wifi_config.ap.password));
            esp_bridge_wifi_set(WIFI_MODE_AP, (char *)wifi_config.ap.ssid, (char *)wifi_config.ap.password, NULL);
        else
            esp_netif_t *sta_netif = esp_netif_create_default_wifi_sta();
            assert(sta_netif);
            wifi_init_config_t cfg = WIFI_INIT_CONFIG_DEFAULT();
            ESP_ERROR_CHECK(esp_wifi_init(&cfg));
            ESP_ERROR_CHECK(esp_event_handler_register(WIFI_EVENT, ESP_EVENT_ANY_ID, &event_handler, NULL));
            ESP_ERROR_CHECK(esp_event_handler_register(IP_EVENT, IP_EVENT_STA_GOT_IP, &event_handler, NULL));
            ESP_ERROR_CHECK(esp_event_handler_register(SC_EVENT, ESP_EVENT_ANY_ID, &event_handler, NULL));
            ESP_ERROR_CHECK(esp_wifi_set_mode(WIFI_MODE_STA));
            ESP_ERROR_CHECK(esp_wifi_start());
            ESP_LOGI(TAG2, "Could not open NVS to read WiFi credentials. Starting SmartConfig...");
        // free(ssid_str);
        // free(password_str);
    EventBits_t uxBits;
    ESP_ERROR_CHECK(esp_smartconfig_set_type(SC_TYPE_ESPTOUCH_V2));
    smartconfig_start_config_t cfg = SMARTCONFIG_START_CONFIG();
    ESP_ERROR_CHECK(esp_smartconfig_start(&cfg));
    while (1)
        uxBits = xEventGroupWaitBits(s_wifi_event_group, WIFI_CONNECTED_BIT | ESPTOUCH_DONE_BIT, true, false, portMAX_DELAY);
            ESP_LOGI(TAG2, "WiFi Connected to ap");
        if (uxBits & ESPTOUCH_DONE_BIT)
            ESP_LOGI(TAG2, "smartconfig over");
            esp_smartconfig_stop();
            esp_restart();
            vTaskDelete(NULL);
void app_main_mesh()
     * @brief Set the log level for serial port printing.
    esp_log_level_set("*", ESP_LOG_INFO);
    esp_storage_init();
    initialise_wifi();
    if (WIFI_CONNECTED_BIT && ssid_str && password_str)
        wifi_connected = true;
    if (wifi_connected)
        esp_mesh_lite_config_t mesh_lite_config = ESP_MESH_LITE_DEFAULT_INIT();
        esp_mesh_lite_init(&mesh_lite_config);
        esp_mesh_lite_start();
        start_config = true;
and this is the code from the cpp
#include <WiFi.h>
#include <Firebase_ESP_Client.h>
#include <EEPROM.h>
#include <addons/TokenHelper.h>
#include <addons/RTDBHelper.h>
#include <Preferences.h>
#include <WiFiClient.h>
extern "C" void app_main_mesh();
#define API_KEY ""
#define DATABASE_URL ""
#define USER_EMAIL ""
#define USER_PASSWORD ""
FirebaseData fbdo;
FirebaseData stream;
FirebaseAuth auth;
FirebaseConfig config;
Preferences preferences;
String parentPath = "/";
String childPath[2] = {"/brightness", "/color"};
bool start_config = false;
bool wifi_connected = false;
int count = 0;
volatile bool dataChanged = false;
unsigned long sendDataPrevMillis = 0;
void receivedCallback(uint32_t from, String &msg);
void streamCallback(FirebaseStream data)
    printf("sream path, %s\nevent path, %s\ndata type, %s\nevent type, %s\nvalue, %s\n\n",
           data.streamPath().c_str(),
           data.dataPath().c_str(),
           data.dataType().c_str(),
           data.eventType().c_str(),
           data.stringData().c_str());
    printResult(data);
    printf("Received stream payload size: %d (Max. %d)\n\n", data.payloadLength(), data.maxPayloadLength());
    dataChanged = true;
void streamTimeoutCallback(bool timeout)
    if (timeout)
        Serial.printf("stream timed out, resuming...\n");
    if (!stream.httpConnected())
        Serial.printf("error code: %d, reason: %s\n\n", stream.httpCode(), stream.errorReason().c_str());
void setup()
    disableCore0WDT();
    disableCore1WDT();
    app_main_mesh();
    //while (WiFi.status() != WL_CONNECTED)
    //    printf(".");
    printf("startting\n\n");
    printf("Firebase Client v%s\n\n", FIREBASE_CLIENT_VERSION);
    config.api_key = API_KEY;
    auth.user.email = USER_EMAIL;
    auth.user.password = USER_PASSWORD;
    config.database_url = DATABASE_URL;
    config.token_status_callback = tokenStatusCallback; // see addons/TokenHelper.h
    printf("startting2\n\n");
    Firebase.reconnectNetwork(false);
    printf("startting3\n\n");
    fbdo.setBSSLBufferSize(16384 /* Rx buffer size in bytes from 512 - 16384 */, 16384 /* Tx buffer size in bytes from 512 - 16384 */);
    printf("startting4\n\n");
    stream.setBSSLBufferSize(16384 /* Rx buffer size in bytes from 512 - 16384 */, 16384 /* Tx buffer size in bytes from 512 - 16384 */);
    printf("startting5\n\n");
    Firebase.begin(&config, &auth);
    if (fbdo.httpCode() < 0)
        printf("Failed to initialize Firebase connection. Error: %s\n", fbdo.errorReason().c_str());
    printf("startting6\n\n");
    stream.keepAlive(5, 5, 1);
    printf("startting7\n\n");
    if (!Firebase.RTDB.beginStream(&stream, "/WACDEtKtNgat7RRJIZelTa5WgpH2/rooms/yeet"))
        printf("sream begin error, %s\n\n", stream.errorReason().c_str());
    Firebase.RTDB.setStreamCallback(&stream, streamCallback, streamTimeoutCallback);
void loop()
    if (dataChanged)
    printf("bridge: Received from %u msg=%s\n", from, msg.c_str());
this is the log output
I (29) boot: ESP-IDF 4.4.5 2nd stage bootloader
I (29) boot: compile time 20:18:37
I (29) boot: chip revision: v3.0
I (32) boot.esp32: SPI Speed      : 40MHz
I (37) boot.esp32: SPI Mode       : DIO
I (41) boot.esp32: SPI Flash Size : 4MB
I (46) boot: Enabling RNG early entropy source...
I (51) boot: Partition Table:
I (55) boot: ## Label            Usage          Type ST Offset   Length
I (62) boot:  0 nvs              WiFi data        01 02 00009000 00004000
I (69) boot:  1 otadata          OTA data         01 00 0000d000 00002000
I (77) boot:  2 phy_init         RF data          01 01 0000f000 00001000
I (84) boot:  3 ota_0            OTA app          00 10 00010000 001e0000
I (92) boot:  4 ota_1            OTA app          00 11 001f0000 001e0000
I (99) boot:  5 coredump         Unknown data     01 03 003d0000 00010000
I (107) boot:  6 reserved         Unknown data     01 fe 003e0000 00020000
I (114) boot: End of partition table
I (119) esp_image: segment 0: paddr=00010020 vaddr=3f400020 size=20640h (132672) map
I (175) esp_image: segment 1: paddr=00030668 vaddr=3ffb0000 size=03204h ( 12804) load
I (180) esp_image: segment 2: paddr=00033874 vaddr=40080000 size=0c7a4h ( 51108) load
I (202) esp_image: segment 3: paddr=00040020 vaddr=400d0020 size=c8f94h (823188) map
I (500) esp_image: segment 4: paddr=00108fbc vaddr=4008c7a4 size=089b0h ( 35248) load
I (525) boot: Loaded app from partition at offset 0x10000
I (525) boot: Disabling RNG early entropy source...
I (537) cpu_start: Pro cpu up.
I (537) cpu_start: Starting app cpu, entry point is 0x40081ddc
I (523) cpu_start: App cpu up.
I (553) cpu_start: Pro cpu start user code
I (553) cpu_start: cpu freq: 160000000
I (554) cpu_start: Application information:
I (558) cpu_start: Project name:     espidf-arduino-wifiscan
I (564) cpu_start: App version:      1
I (569) cpu_start: Compile time:     Nov 11 2023 21:40:28
I (575) cpu_start: ELF file SHA256:  8031330a96b0b205...
I (581) cpu_start: ESP-IDF:          4.4.5
I (586) cpu_start: Min chip rev:     v0.0
I (590) cpu_start: Max chip rev:     v3.99
I (595) cpu_start: Chip rev:         v3.0
I (600) heap_init: Initializing. RAM available for dynamic allocation:
I (607) heap_init: At 3FFAE6E0 len 00001920 (6 KiB): DRAM
I (613) heap_init: At 3FFB8B18 len 000274E8 (157 KiB): DRAM
I (619) heap_init: At 3FFE0440 len 00003AE0 (14 KiB): D/IRAM
I (626) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM
I (632) heap_init: At 40095154 len 0000AEAC (43 KiB): IRAM
I (640) spi_flash: detected chip: generic
I (643) spi_flash: flash io: dio
I (650) cpu_start: Starting scheduler on PRO CPU.
I (0) cpu_start: Starting scheduler on APP CPU.
I (74) smartconfig_example: Found NVS WiFi credentials. Starting connecting to wifi...
I (76) bridge_common: esp-iot-bridge version: 0.9.0
I (811) wifi:wifi driver task: 3ffbb178, prio:23, stack:6656, core=0
I (816) system_api: Base MAC address is not set
I (821) system_api: read default base MAC address from EFUSE
I (849) wifi:wifi firmware version: 0f80fa0
I (849) wifi:wifi certification version: v7.0
I (849) wifi:config NVS flash: enabled
I (849) wifi:config nano formating: disabled
I (853) wifi:Init data frame dynamic rx buffer num: 32
I (858) wifi:Init management frame dynamic rx buffer num: 32
I (863) wifi:Init management short buffer num: 32
I (868) wifi:Init dynamic tx buffer num: 32
I (872) wifi:Init static rx buffer size: 1600
I (876) wifi:Init static rx buffer num: 10
I (880) wifi:Init dynamic rx buffer num: 32
I (885) wifi_init: rx ba win: 6
I (887) wifi_init: tcpip mbox: 32
I (891) wifi_init: udp mbox: 6
I (895) wifi_init: tcp mbox: 6
I (899) wifi_init: tcp tx win: 5744
I (903) wifi_init: tcp rx win: 5744
I (907) wifi_init: tcp mss: 1440
I (911) wifi_init: WiFi IRAM OP enabled
I (916) wifi_init: WiFi RX IRAM OP enabled
I (921) phy_init: phy_version 4670,719f9f6,Feb 18 2021,17:07:07
I (1023) wifi:mode : null
I (1025) ip select: IP Address:192.168.4.1
I (1025) ip select: GW Address:192.168.4.1
I (1025) ip select: NM Address:255.255.255.0
I (1029) bridge_wifi: IP Address:192.168.4.1
Add netif ap with (commit id)
I (1037) bridge_common: netif list add success
I (1043) wifi:mode : softAP (c0:49:ef:e0:b8:fd)
I (1049) wifi:Total power save buffer number: 16
I (1051) wifi:Init max length of beacon: 752/752
I (1055) wifi:Init max length of beacon: 752/752
Add netif sta with (commit id)
I (1062) bridge_common: netif list add success
I (1068) wifi:mode : sta (c0:49:ef:e0:b8:fc) + softAP (c0:49:ef:e0:b8:fd)
I (1074) wifi:enable tsf
I (1076) bridge_wifi: Found ssid EE-Hub-wKt8
I (1081) bridge_wifi: Found password VAN-amble-late
I (1087) wifi:Disabled PMF config for STA
I (1090) bridge_wifi: [esp_bridge_wifi_set] sta ssid: EE-Hub-wKt8 password: VAN-amble-late
W (1100) vendor_ie: Error Get[4354]
W (1103) vendor_ie: Error Get[4354]
I (1863) wifi:Total power save buffer number: 16
I (1864) bridge_wifi: [esp_bridge_wifi_set] softap ssid: ESP_Bridge password: 12345678
I (1865) Mesh-Lite: esp-mesh-lite component version: 0.9.0
Mesh-Lite commit id: 57bc05c
I (1875) vendor_ie: Mesh ID: 77
W (1878) vendor_ie: Error Get[4354]
W (1882) vendor_ie: Error Get[4354]
I (1888) ESP_Mesh_Lite_Comm: msg action add success
I (1892) ESP_Mesh_Lite_Comm: msg action add success
I (1894) ESP_Mesh_Lite_Comm: Bind Socket 54, port 6364
W (1898) vendor_ie: [Unexpected restart]: the rtc data: level:1, ssid:EE-Hub-wKt8, bssid 00:00:00:00:00:00
I (1904) ESP_Mesh_Lite_Comm: Bind Socket 55, port 6363
W (1914) vendor_ie: Try to connect the original parent node
I (1920) ESP_Mesh_Lite_Comm: Bind Socket 56, port 6366
startting
I (1932) ESP_Mesh_Lite_Comm: Bind Socket 57, port 6365
I (1936) wifi:ap channel adjust o:1,1 n:11,2
Firebase Client v4.4.8
I (1942) wifi:new:<11,0>, old:<1,1>, ap:<11,2>, sta:<11,0>, prof:1
startting2
startting3
startting4
startting5
I (2741) wifi:state: init -> auth (b0)
I (2745) wifi:state: auth -> assoc (0)
I (2750) wifi:state: assoc -> run (10)
I (2778) wifi:connected with EE-Hub-wKt8, aid = 9, channel 11, BW20, bssid = c4:e5:32:85:a7:e9
I (2779) wifi:security: WPA2-PSK, phy: bgn, rssi: -34
I (2781) wifi:pm start, type: 1
I (2795) wifi:<ba-add>idx:0 (ifx:0, c4:e5:32:85:a7:e9), tid:6, ssn:0, winSize:64
I (2866) wifi:AP's beacon interval = 102400 us, DTIM period = 3
I (3789) esp_netif_handlers: sta ip: 192.168.1.249, mask: 255.255.255.0, gw: 192.168.1.254
I (3790) bridge_wifi: Connected with IP Address:192.168.1.249
I (3794) vendor_ie: RTC store: ssid:EE-Hub-wKt8; bssid:00:00:00:00:00:00 crc:2871029244
I (18340) wifi:<ba-add>idx:1 (ifx:0, c4:e5:32:85:a7:e9), tid:0, ssn:2, winSize:64
if p put the classic arduino while WL_CONNECTED it just stays in the while forever is the issue the firebase / arduino cant connect tot the wifi ? or the connected bit the arduino tries to get is different from the idf ?
also i know it looks like the wifi is established after the firebase begin call but even if i do it as before with the waiting for the time flag the same result… again if i start the wifi arduino side it all runs fine just the mesh needs to be commented out
@maxgerhardt any ideas ?
