I want to integrate my existing framwork with platformio. It requires GCC 10, so I must first enable the use of newer toolchains. I copied the avr-gcc-10.2.0-P0829, added a platform.json, installed it with pio platform install from a local directory. But when I now try to use it the second phase of the installation can’t find it:
$ pio platform install file://c:/ti-software/platformio/avr-gcc-10
Platform Manager: Installing file://c:/ti-software/platformio/avr-gcc-10
Platform Manager: toolchain-atmelavr @ 1.90300.191015 has been installed!
The platform 'file://c:/ti-software/platformio/avr-gcc-10' has been successfully installed!
The rest of the packages will be installed later depending on your build environment.
Wouter@DESKTOP-SPUBNQD MINGW64 /c/ti-software/platformio_test/native-blink
$ pio run -v
Processing uno (platform: atmelavr; board_build.mcu: atmega328p; board_build.f_cpu: 16000000L; upload_protocol: arduino; upload_speed: 115200; platform_packages: toolchain-atmelavr@~1.90300.191015)
Tool Manager: Installing platformio/toolchain-atmelavr @ ~1.90300.191015
Error: Could not find the package with 'platformio/toolchain-atmelavr @ ~1.90300.191015' requirements for your system 'windows_amd64'
What am I doing wrong?
Also, what would be the correct designation for this GGC 10.2, would it be “100200” ?
