I’m new in the usage of Visual Studio Code for NodeMCU/ESP8266. Everything worked quite well as Long as I use only c language and put all in one file (the main,cpp). But I would like to use C++ and also several source Code files. So practically I have two Problems somehow related.
When I place a simple Class that really doen’t do anything in the main file, it compiles. Creating an instance of this class works so far, as the Compiler doesn’t complain. But the linker creates Errors as it cannot reference all the class Methods (constructor and other functions).
I have a similar behavior when I put some c Code in a different file, located in the same Folder where my main file is located. The Compiler again doesn’t complain but when I try to use a function from the other file in my main file, I get again a linker error.
If I try to declare a class in a Header file, the Compiler complains About the word class. So it Looks to me as a c Compiler is used or the used one (I guess it’s xtensa-lx106-elf) works in c mode.
I’m using the Standard simple Settings and therefore my platformio,ini contains only
[env:nodemcuv2]
platform = espressif8266
board = nodemcuv2
lib_extra_dirs = ~/lib
May be I have to put this Topic into another Group, but I haven’t found something related. And it’s my first post in this comunity.
Searching now for my Hours already the Internet to any solution, I didn’t found something good. Any help or hint would be aprechiated.
Erwin
