I’m trying to exclude the main.cpp file from the build of a library. This file is only usefull when the library is build as a project isself and is used for testing purposes. But when the library is build as part of another project I dont want the main.cpp compiled as it contains some hardware specific code, not needed when the library is deployed on other hardware.
I’ve tried adding a srcFilter
to the build
section of the library.json, but whatever I try, the main.cpp still gets compiled which results in errors.
Does anybody have a working example in Windows of using this?
Things I tried are i.e.:
"build": {
"flags": "-Wno-unused-function",
"srcFilter": [
"+<src/*>",
"-<src/main.*>"
