Hi to everybody, I’m new to PlatformIO.
I would like to use the Nucleo STM32L4R5ZI-P , but I noticed that only the Nucleo STM32L4R5ZI model (without -P) is supported.
Looking at the boards/nucleo_l4r5zi.json file, I noticed that the supported variants are “STM32L4xx/L4R5Z(G-I)T_L4R7ZIT_L4S5ZIT_L4S7ZIT,” where the “-P” model does not seem to be present.
How can I solve this?
TIA,
CP
Create a new PlatformIO with any board (e.g., “Arduino Uno” and Framework “Arduino”)
Create a new folder boards in the root of the project
Create a new file boards/nucleo_l4r5zi_p.json with content
"build": {
"core": "stm32",
"cpu": "cortex-m4",
"extra_flags": "-DSTM32L4 -DSTM32L4R5xx",
"f_cpu": "120000000L",
"mcu": "stm32l4r5zit6p",
"product_line": "STM32L4R5xx",
"variant": "STM32L4xx/L4R5ZITxP"
"connectivity": [
"can"
"debug": {
"default_tools": [
"stlink"
"jlink_device": "STM32L4R5ZI",
"onboard_tools": [
"stlink"
"openocd_board": "st_nucleo_l4",
"openocd_target": "stm32l4x",
"svd_path": "STM32L4R5.svd"
"frameworks": [
"arduino",
"cmsis",
"mbed",
"stm32cube",
"zephyr"
"name": "ST Nucleo L4R5ZI-P",
"upload": {
"maximum_ram_size": 655360,
"maximum_size": 2097152,
"protocol": "stlink",
"protocols": [
"jlink",
"cmsis-dap",
"stlink",
"blackmagic",
"mbed"
"url": "https://www.st.com/en/evaluation-tools/nucleo-l4r5zi-p.html",
"vendor": "ST"
Set the platformio.ini as
[env:nucleo_l4r5zi_p]
platform = ststm32
board = nucleo_l4r5zi_p
Set src/main.cpp as
#define LED LED_BLUE /* or LED_GREEN or LED_RED */
pinMode(LED, OUTPUT);
Serial.begin(9600);
void loop(){
Serial.println("LED toggling");
digitalWrite(LED, HIGH);
delay(1000);
digitalWrite(LED, LOW);
delay(1000);
And try to upload it.See if the LED blinks. If yes, it should be equivalent to the Arduino IDE setup to “Nucleo L4R5ZI-P”.
maxgerhardt:
Thanks, it works!
Now I’ll try to adapt the previous project for the Nucleo F401RE (using the “stm32” framework)…
C.
