Use headers give me an error
When I try to use a header, #ifdef doesn’t work properly, the code inside is gray out, if I call de function, I get an error. the identifier "blink" is not defined.
If I remove #ifdef, I get a new error when I try to compile, undefined reference to 'blink()'.
My headers are in include folder.
header.h
#ifdef HEADER_H
#define HEADER_H
#pragma once
void blink();
header.cpp
#include "header.h"
void blink(){
//code here
main.cpp
#include "header.h"
void setup(){
blink();
void loop(){
//code here
in your file header.h
must be
#ifndef HEADER_H
and delete
in your file header.cpp
This was a mistake when I redacted this.
Now my If it works, but I continue with the same problem undefined reference to 'blink()'
Look the complete message:
c:/users/<myuser>/.platformio/packages/toolchain-xtensa/bin/../lib/gcc/xtensa-lx106-elf/4.8.2/../../../../xtensa-lx106-elf/bin/ld.exe: .pio\build\esp12e\src\main.cpp.o:(.text._Z9reconnectv+0x38): undefined reference to `wificonfig(char const*, char const*)'
c:/users/<myuser>/.platformio/packages/toolchain-xtensa/bin/../lib/gcc/xtensa-lx106-elf/4.8.2/../../../../xtensa-lx106-elf/bin/ld.exe: .pio\build\esp12e\src\main.cpp.o:(.text._Z9reconnectv+0x4d): undefined reference to `wificonfig(char const*, char const*)'
*** [.pio\build\esp12e\firmware.elf] Error 1
Your error message and description don’t match.
What’s the complete code and platformio.ini with which your problem can be reproduced?
I get the same error from two different headers.
Is just init the wifi settings on esp, and put the code in header for use in other projects, I just call the function wificonfig in the setup with the SSID and Password.
Here is the code:
wificonfig.h
#ifndef wificonfig_h
#define wificonfig_h
    #pragma once
    void wificonfig(const char *SSID, const char *PSK);
wificonfig.cpp
#include "wificonfig.h"
#include <ESP8266WiFi.h>
#include <ESP8266WiFiMulti.h>
void wificonfig(const char *SSID, const char *PSK){
    WiFiClient client;
    ESP8266WiFiMulti WiFiMulti;
    while (1){
        WiFi.mode(WIFI_STA);
        //WiFi.config(staticIP, subnet, gateway, dns);
        WiFiMulti.addAP(SSID, PSK);
        //WiFi.begin(APSSID,APPSK);
        if (WiFi.status() == WL_IDLE_STATUS) { // when not connected to a network, but powered on
            digitalWrite(LED_BUILTIN, !digitalRead(LED_BUILTIN));
            Serial.println("WL_IDLE_STATUS");
        else if (WiFi.status() == WL_CONNECTED) {
            Serial.print("WL_CONNECTED ");
            break;
        else if (WiFi.status() == WL_NO_SSID_AVAIL) {
            Serial.println("WL_NO_SSID_AVAIL");
        else if (WiFi.status() == WL_CONNECT_FAILED) {
            Serial.println("WL_CONNECT_FAILED");
        else if (WiFi.status() == WL_CONNECTION_LOST) {
            Serial.println("WL_CONNECTION_LOST");
        else if (WiFi.status() == WL_DISCONNECTED) {
            Serial.println("WL_DISCONNECTED");
        else {
    Serial.println("Attempting again...");
    delay(3000);
platfiomio.ini
[env:esp12e]
platform = espressif8266
board = esp12e
    -D PIO_FRAMEWORK_ARDUINO_LWIP2_LOW_MEMORY ;No sé bien que hace esto, solo se que ayuda a reservar espacio para el update.
    PubSubClient
    arduino-timer@^2.0.1
    ArduinoJson@^6.15.2
    Time
Where did you place the cpp-files corresponding to the header-files?
I assume that you have placed them in include:
If your project looks like that:
include
-> header.h
header.cpp
src
-> main.cpp
/home/hst/.platformio/packages/toolchain-xtensa/bin/../lib/gcc/xtensa-lx106-elf/4.8.2/../../../../xtensa-lx106-elf/bin/ld: .pio/build/d1_mini/src/main.cpp.o:(.text.setup+0x0): undefined reference to `blink()'
/home/hst/.platformio/packages/toolchain-xtensa/bin/../lib/gcc/xtensa-lx106-elf/4.8.2/../../../../xtensa-lx106-elf/bin/ld: .pio/build/d1_mini/src/main.cpp.o: in function `setup':
main.cpp:(.text.setup+0xa): undefined reference to `blink()'
pio run ends with the error message described by you.
Instead if your project looks like that:
include
-> header.h
src
-> main.cpp
header.cpp
RAM:   [===       ]  32.7% (used 26776 bytes from 81920 bytes)
Flash: [==        ]  24.6% (used 256584 bytes from 1044464 bytes)
Creating BIN file ".pio/build/d1_mini/firmware.bin" using ".pio/build/d1_mini/firmware.elf"
=============================================================== [SUCCESS] Took 4.83 seconds ==============================================================
everything should work fine :wink:
Thanks, the problem was the location of .cpp files. Now its work. :grin:
