Use esp8266/Arduino repo
Hello!
I’m struggling with the problem of adding the esp8266 / Arduino library to my project for several days now.
I have to removed the links(GitHub - esp8266/Arduino: ESP8266 core for Arduino) to the repos and replaced it with #link
I have tried the following variants:
  1. change platform to git repo in platformio.ini
    Espressif 8266 — PlatformIO latest documentation
    [env:d1_mini]
    platform = espressif8266
    ;platform = #link
    board = d1_mini
Faild …
  1. add lib with lib_deps
    [env:d1_mini]
    ;platform = #link
    board = d1_mini
    lib_deps = #link
Faild …
  1. add lib mode deep +
    [env:d1_mini]
    ;platform = #link
    board = d1_mini
    lib_ldf_mode = deep+
    lib_deps = #link
    Faild …
i always get the compilation error:
/home/fetzen/Arduino/projects/baseDroid/src/main.ino:4:30: fatal error: WiFiServerSecure.h: No such file or directory
* Looking for WiFiServerSecure.h dependency? Check our library registry!
* CLI  > platformio lib search "header:WiFiServerSecure.h"
* Web  >https://platformio.org/lib/search?query=header:WiFiServerSecure.h
#include <WiFiServerSecure.h>
compilation terminated.
Compiling .pioenvs/d1_mini/libc30/ESP8266WiFi/ESP8266WiFiSTA.cpp.o
*** [.pioenvs/d1_mini/src/main.ino.cpp.o] Error 1
slowly I’m despairing the biblitheks are locally available, but always the same mistake. I think platformio looks only in the espressif lib.
Can someone help me and has an idea how to get the library up and running?
Is me again,
still no solution in sight, i changed from Ubuntu to Windows an tried out VSCode with the latest PlatformIO Plugin.
I started my next experiment with a blank project and the old platfomio.ini
[env:d1_mini]
board = d1_mini
lib_ldf_mode = deep
lib_deps = GitHub - esp8266/Arduino: ESP8266 core for Arduino
starting compiling with
pio run
but i get the following error:
Submodule path ‘tools/sdk/ssl/bearssl’: checked out ‘94e97043bbdebed43ecd9372bd7fd21d45bd789f’
File “c:\users\fetzen.platformio\penv\lib\site-packages\platformio_main_.py”, line 120, in main
cli(None, None, None)
File “c:\users\fetzen.platformio\penv\lib\site-packages\click\core.py”, line 700, in call
File “c:\users\fetzen.platformio\penv\lib\site-packages\click\core.py”, line 680, in main
rv = self.invoke(ctx)
File “c:\users\fetzen.platformio\penv\lib\site-packages\click\core.py”, line 1027, in invoke
File “c:\users\fetzen.platformio\penv\lib\site-packages\click\core.py”, line 873, in invoke
File “c:\users\fetzen.platformio\penv\lib\site-packages\click\core.py”, line 508, in invoke
return callback(*args, **kwargs)
File “c:\users\fetzen.platformio\penv\lib\site-packages\click\decorators.py”, line 16, in new_func
File “c:\users\fetzen.platformio\penv\lib\site-packages\platformio\commands\run.py”, line 107, in cli
result = (envname, ep.process())
File “c:\users\fetzen.platformio\penv\lib\site-packages\platformio\commands\run.py”, line 204, in process
result = self._run()
File “c:\users\fetzen.platformio\penv\lib\site-packages\platformio\commands\run.py”, line 299, in _run
self.verbose)
File “c:\users\fetzen.platformio\penv\lib\site-packages\platformio\commands\run.py”, line 322, in _autoinstall_libdeps
ctx.invoke(cmd_lib_install, libraries=[lib], silent=not verbose)
File “c:\users\fetzen.platformio\penv\lib\site-packages\click\decorators.py”, line 26, in new_func
return f(get_current_context().obj, *args, **kwargs)
File “c:\users\fetzen.platformio\penv\lib\site-packages\platformio\commands\lib.py”, line 103, in lib_install
library, silent=silent, interactive=interactive, force=force)
File “c:\users\fetzen.platformio\penv\lib\site-packages\platformio\managers\lib.py”, line 354, in install
force=force)
File “c:\users\fetzen.platformio\penv\lib\site-packages\platformio\managers\package.py”, line 712, in install
name, url, requirements, track=True)
File “c:\users\fetzen.platformio\penv\lib\site-packages\platformio\managers\package.py”, line 460, in _install_from_url
return self._install_from_tmp_dir(_tmp_dir, requirements)
File “c:\users\fetzen.platformio\penv\lib\site-packages\platformio\managers\package.py”, line 539, in _install_from_tmp_dir
shutil.move(tmp_dir, pkg_dir)
File “C:\Users\Fetzen.platformio\python27\Lib\shutil.py”, line 314, in move
rmtree(src)
File “C:\Users\Fetzen.platformio\python27\Lib\shutil.py”, line 261, in rmtree
rmtree(fullname, ignore_errors, onerror)
File “C:\Users\Fetzen.platformio\python27\Lib\shutil.py”, line 266, in rmtree
onerror(os.remove, fullname, sys.exc_info())
File “C:\Users\Fetzen.platformio\python27\Lib\shutil.py”, line 264, in rmtree
os.remove(fullname)
WindowsError: [Error 5] Zugriff verweigert: ‘C:\Users\Fetzen\Documents\PlatformIO\Projects\pioTest\.piolibdeps\_tmp_installing-afvubn-package\.git\modules\lwip2\modules\lwip2-src\objects\pack\pack-166e459aa8941cee9690a4d29db24a061ef737b6.idx’
  `pip install -U platformio` command
  http://docs.platformio.org/page/faq.html
does anyone have a solution for that?
