There’s plenty of information on how to connect an esp-prog adapter for debugging but has anyone successfully used an esp32-s3 devkit with builtin JTAG to debug another board? I have Freenove ESP32 WROVER CAM board that I would like to debug using the an esp32-s3 devkit. I would like to use this board as I mistakenly purchased two of them
undefinedC:\Users\Eamonn.platformio\packages\toolchain-xtensa-esp32@8.4.0+2021r2-patch5\bin\xtensa-esp32-elf-gdb.exe: warning: Couldn’t determine a path for the index cache directory.
Reading symbols from c:\Users\Eamonn\Documents\PlatformIO\Projects\esp32ardblank.pio\build\esp32dev\firmware.elf…
PlatformIO: debug_tool = esp-bridge
Open On-Chip Debugger v0.11.0-esp32-20220706 (2022-07-06-15:48)
Licensed under GNU GPL v2
For bug reports, read
Info : only one transport option; autoselect ‘jtag’
Info : esp_usb_jtag: VID set to 0x303a and PID to 0x1002
Info : esp_usb_jtag: capabilities descriptor set to 0x30a
adapter speed: 40000 kHz
WARNING: boards/esp-wroom-32.cfg is deprecated, and may be removed in a future release.
Warn : Transport “jtag” was already selected
adapter speed: 5000 kHz
Info : tcl server disabled
Info : telnet server disabled
Error: esp_usb_jtag: could not find or open device!
Remote communication error. Target disconnected.: Success.
