I’m trying to get platformio up and running. MacOS 12.6.8, VSCode 1.86.2, PlatformIO 6.1.13. For test purposes trying to upload a program to an Adafruit Feather 32 to blink the on-board LED. It works when upload from the Arduino IDE, but not when uploaded by platformio. Compilation and upload are successful, but the program does not run. Searching this issue comes up with some similar topics but no solutions germane to my situation. Any guidance?
platformio.ini:
[env:featheresp32]
board = featheresp32
upload_protocol = esptool
monitor_rts = 0
monitor_dtr = 0
Code:
#define ONBOARD_LED 13
pinMode(ONBOARD_LED, OUTPUT);
delay(1000);
digitalWrite(ONBOARD_LED, HIGH);
delay(100);
digitalWrite(ONBOARD_LED, LOW);
Output:
Processing featheresp32 (platform: espressif32; board: featheresp32; framework: arduino)
CONFIGURATION: https://docs.platformio.org/page/boards/espressif32/featheresp32.html
PLATFORM: Espressif 32 (6.2.0) > Adafruit ESP32 Feather
- framework-arduinoespressif32 @ 3.20008.0 (2.0.8)
- tool-mkfatfs @ 2.0.1
- tool-openocd-esp32 @ 2.1100.20220706 (11.0)
Found 33 compatible libraries
Retrieving maximum program size .pio/build/featheresp32/firmware.elf
Checking size .pio/build/featheresp32/firmware.elf
RAM: [= ] 6.7% (used 22076 bytes from 327680 bytes)
Flash: [== ] 17.6% (used 230521 bytes from 1310720 bytes)
AVAILABLE: cmsis-dap, esp-bridge, esp-prog, espota, esptool, iot-bus-jtag, jlink, minimodule, olimex-arm-usb-ocd, olimex-arm-usb-ocd-h, olimex-arm-usb-tiny-h, olimex-jtag-tiny, tumpa
Looking for upload port...
Using manually specified: /dev/cu.SLAB_USBtoUART
Uploading .pio/build/featheresp32/firmware.bin
esptool.py v4.5.1
Serial port /dev/cu.SLAB_USBtoUART
Connecting....
Chip is ESP32-D0WD-V3 (revision v3.0)
Features: WiFi, BT, Dual Core, 240MHz, VRef calibration in efuse, Coding Scheme None
Crystal is 40MHz
MAC: 94:b5:55:6a:d5:ec
Uploading stub...
Running stub...
Stub running...
Changing baud rate to 460800
Changed.
Configuring flash size...
Flash will be erased from 0x00001000 to 0x00005fff...
Flash will be erased from 0x00010000 to 0x00048fff...
Compressed 17520 bytes to 12170...
Writing at 0x00001000... (100 %)
Wrote 17520 bytes (12170 compressed) at 0x00001000 in 0.6 seconds (effective 227.2 kbit/s)...
Hash of data verified.
Compressed 3072 bytes to 146...
Wrote 3072 bytes (146 compressed) at 0x00008000 in 0.1 seconds (effective 470.3 kbit/s)...
Wrote 8192 bytes (47 compressed) at 0x0000e000 in 0.1 seconds (effective 770.1 kbit/s)...
Compressed 230880 bytes to 128220...
Writing at 0x00010000... (12 %)
Writing at 0x0001ddd1... (25 %)
Writing at 0x0002358d... (37 %)
Writing at 0x00028737... (50 %)
Writing at 0x0002ddb2... (62 %)
Writing at 0x00036310... (75 %)
Writing at 0x0003e51e... (87 %)
Writing at 0x00043b4b... (100 %)
Wrote 230880 bytes (128220 compressed) at 0x00010000 in 3.3 seconds (effective 565.9 kbit/s)...
Leaving...
Hard resetting via RTS pin...
================================================= [SUCCESS] Took 7.51 seconds =================================================
