Hi, platform.io newbie here, trying to upload to my new Portenta H7, using DFU upload protocol. Was wondering if anyone had any ideas as to what my issue could be:
/home/nathan/.platformio/packages/tool-dfuutil/bin/dfu-util: symbol lookup error: /home/nathan/.platformio/packages/tool-dfuutil/bin/dfu-util: undefined symbol: libusb_set_option
*** [upload] Error 127
libusb package issue? I’m not sure where to go with this, any help would be greatly appreciated
That’s not good – looks like the dfu-util binary dynamically links to a libusb library that is missing a function / symbol.
What does
ldd /home/nathan/.platformio/packages/tool-dfuutil/bin/dfu-util
output?
Hi, thanks for your reply, this is what I get:
linux-vdso.so.1 (0x00007ffd8b5b7000) |
libusb-1.0.so.0 => /lib/x86_64-linux-gnu/libusb-1.0.so.0 (0x00007f16098e7000) |
libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6 (0x00007f16094f6000) |
libudev.so.1 => /lib/x86_64-linux-gnu/libudev.so.1 (0x00007f16092d8000) |
libpthread.so.0 => /lib/x86_64-linux-gnu/libpthread.so.0 (0x00007f16090b9000) |
/lib64/ld-linux-x86-64.so.2 (0x00007f1609aff000) |
librt.so.1 => /lib/x86_64-linux-gnu/librt.so.1 (0x00007f1608eb1000) |
Which Linux distribution and version are you using?
HI, I’m on Ubuntu 18.04.6
That’s very outdated.
However, PlatformIO’s tool-dfuutil should locally come with a working libusb-1.0.so.0, to make it work independently of the installed libusb-dev package version of the distribution.
What’s the output of tree /home/nathan/.platformio/packages/tool-dfuutil/
On a PlatformIO CLI, what’s the output of pio --version
and pio platform list
the tree output is this,
├── AUTHORS
├── bin
│ ├── dfu-prefix
│ ├── dfu-suffix
│ ├── dfu-util
│ └── dfu-util-static
├── ChangeLog
├── COPYING
├── dfuse-pack.py
├── package.json
└── README
platform io version:
PlatformIO Core, version 6.1.6
platform list:
Platforms
└── ststm32 @ 15.5.1 (required: platformio/ststm32)
It indeed seems so that the used dfuutil version in this case does not have a lib/
folder that would have a compatible libusb library.
Try the following:
pio pkg install -g -t "tool-dfuutil@1.9.200310"
cp -r ~/.platformio/packages/tool-dfuutil@1.9.200310/lib ~/.platformio/packages/tool-dfuutil/.
Does uploading work now?
Hi, yep thats done it thanks. was it a version issue?
Yes, without lib/
folder in the tool-dfuutil folder, it would try to use you’re distribution’s libusb-dev
package, which seems too old and is missing that libusb_set_option
function. Try updating your distribution if you can to avoid future problems with this.
(I’m assuming sudo apt install libusb-dev
told you “Newest version already installed”)
ahhh I see thanks for your help!!! Yes it did.
