so, I’d like to remotely (OTA) upload to my Arduino Industrial 101, unfortunately, PlatformIO IDE is unable to automatically detect it, and setting upload_port to it’s IP in the ini file doesn’t help (it still tries to upload as if it was a normal serial port). Since there is zero documentation on the upload_protocol option, I haven’t tried it, but maybe that could hold the solution?
Anyways, here’s the console output from the upload part:
DATA: [== ] 15.5% (used 396 bytes from 2560 bytes)
PROGRAM: [=== ] 27.5% (used 7898 bytes from 28672 bytes)
AVAILABLE: avr109
CURRENT: upload_protocol = avr109
Looking for upload port...
Use manually specified: 192.168.0.103
Forcing reset using 1200bps open/close on port 192.168.0.103
Waiting for the new upload port...
Error: Couldn't find a board on the selected port. Check that you have the correct port selected. If it is correct, try pressing the board's reset button after initiating the upload.
*** [upload] Explicit exit, status 1
Any ideas?
Note: Arduino IDE detects and uploads to the board just fine.
