Uploading Issue with STM32F103C8T6 Varient(Bluepill) via USB
Board
Operation System
Windows 10
IDE
PlatformIO Core 6.1.13
Framework
Arduino
Discription
The PIO terminal said upload success but clearly it’s not (LED not blinking)
Sketch
#include "Arduino.h"
#define LED PC13
void setup()
  pinMode(LED, OUTPUT);
void loop()
  digitalWrite(LED, HIGH);
  delay(1000);
  digitalWrite(LED, LOW);
  delay(1000);
Debug Message
Processing genericSTM32F103C8 (platform: ststm32; board: genericSTM32F103C8; framework: arduino)
------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------Verbose mode can be enabled via `-v, --verbose` option
CONFIGURATION: https://docs.platformio.org/page/boards/ststm32/genericSTM32F103C8.html
PLATFORM: ST STM32 (17.2.0) > STM32F103C8 (20k RAM. 64k Flash)
HARDWARE: STM32F103C8T6 72MHz, 20KB RAM, 64KB Flash
DEBUG: Current (blackmagic) External (blackmagic, cmsis-dap, jlink, stlink)
 - framework-arduinoststm32 @ 4.20701.0 (2.7.1)
 - framework-cmsis @ 2.50900.0 (5.9.0)
 - tool-dfuutil @ 1.11.0
 - tool-openocd @ 3.1200.0 (12.0)
 - tool-stm32duino @ 1.0.2
 - toolchain-gccarmnoneeabi @ 1.120301.0 (12.3.1)
Found 12 compatible libraries
Checking size .pio\build\genericSTM32F103C8\firmware.elf
RAM:   [=         ]   5.5% (used 1132 bytes from 20480 bytes)
Flash: [==        ]  16.6% (used 10872 bytes from 65536 bytes)
AVAILABLE: blackmagic, cmsis-dap, dfu, jlink, serial, stlink
CURRENT: upload_protocol = dfu
Looking for upload port...
Auto-detected: COM12
Uploading .pio\build\genericSTM32F103C8\firmware.bin
'java' \xa4\xa3\xacO\xa4\xba\xb3\xa1\xa9Υ~\xb3\xa1\xa9R\xa5O\xa1B\xa5i\xb0\xf5\xa6檺\xb5{\xa6\xa1\xa9Χ妸\xc0ɡC
========================= [SUCCESS] Took 2.16 seconds =========================
Other Steps to Reproduce
I unsolder ESP8226 on WEMOS’s D1 mini for USB to TTL.
This is working cuz STM32 Flash Loader can read and flash it properly
platform.ini
[env:genericSTM32F103C8]
platform = ststm32
board = genericSTM32F103C8
I tried both genericSTM32F103C8 and bluepill_f103c8 but both of them show same result.
It’s even worse if I specified port in .ini the terminal sort of break itself (the result [SUCCESS] appeared on weird place)
platform = ststm32
upload_port = \\.\COM12
Any advice is greatly appreciated.
Best,
This Java DFU (Maple) uploader has always been problematic.
Open a terminal (Windows + R → cmd.exe) and execute
java -jar C:\Users\Max\.platformio\packages\tool-stm32duino\maple_loader.jar COM12 2 1EAF:0003 test.bin
While you adapt the path for the username. What does that output?
Hi,Thanks for your reply
it show the following error
# A fatal error has been detected by the Java Runtime Environment:
#  EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=0x000000007110b5db, pid=28868, tid=0x0000000000006b54
# JRE version: Java(TM) SE Runtime Environment (8.0_401) (build 1.8.0_401-b10)
# Java VM: Java HotSpot(TM) 64-Bit Server VM (25.401-b10 mixed mode windows-amd64 compressed oops)
# Problematic frame:
# C  [jSSC-2.8_x86_64.dll+0xb5db]
# Failed to write core dump. Minidumps are not enabled by default on client versions of Windows
# If you would like to submit a bug report, please visit:
#   http://bugreport.java.com/bugreport/crash.jsp
# The crash happened outside the Java Virtual Machine in native code.
# See problematic frame for where to report the bug.
It seems like a known java issue
I saw someone mention that enabling coredump by running the following command can solve this:
java -jar crasher.jar -XX:+CreateCoredumpOnCrash
Since I’m not familiar with Java, would you recommend me doing this?
Interesting, when I execute such a command I get
C:\Users\Max\.platformio\packages\tool-stm32duino>java -jar C:\Users\Max\.platformio\packages\tool-stm32duino\maple_loader.jar COM12 2 1EAF:0003 test.bin
maple_loader v0.1
Resetting to bootloader via DTR pulse
Reset via USB Serial Failed! Did you select the right serial port?
Assuming the board is in perpetual bootloader mode and continuing to attempt dfu programming...
Searching for DFU device [1EAF:0003]...
and not a crash. My Java version is
>java --version
java 17.0.7 2023-04-18 LTS
Java(TM) SE Runtime Environment (build 17.0.7+8-LTS-224)
Java HotSpot(TM) 64-Bit Server VM (build 17.0.7+8-LTS-224, mixed mode, sharing)
You may want to try that exact version for fun?
https://www.oracle.com/java/technologies/javase/jdk17-archive-downloads.html or similiar.
I tried it, but no luck. It shows the same error as last time
If I’m tied to using USB for uploading, are there other uploader options?
