I have a handful of AT89S52 chips here, and a TL866 II-Plus programmer. Is there a way to create a custom “board” that is just the microcontroller itself and set MiniPro as the upload protocol?
I don’t see that chip being supported in PlatformIO Registry directly. If it’s a generic Intel 8051 variant you might have luck basing a new board off https://github.com/platformio/platform-intel_mcs51/blob/develop/boards/stc89c52rc.json as base, using sdcc
as the compiler (docs). You would however also need to teach the platform the new upload program (idk what you use for uploading) via a custom upload protocol, as there’s only stcgal
support (docs) .
So the good news is, I am about 40% of the way there. Not knowing what I am doing is a slight hinderance, but hacking up some MiniPro support will probably be quite advantageous. I will attempt tp submit what I create when I am done.
Hello, I’ve created a simple github action that builds the minipro tool for windows here. Download the zip file for your platform and uncompress it on the %HOMEPATH%\.platformio\packages\tool-minipro
. (create the directory if it doesn’t exist)
On Linux, just checkout the sources from here, build it (just make
), and copy minipro
, infoic.xml
and logicic.xml
to ~/.platformio/packages/tool-minipro
I then added the following on my platformio.ini:
upload_protocol = custom
upload_flags =
-p
AT29C512
--infoic
${platformio.packages_dir}/tool-minipro/infoic.xml
--logicic
${platformio.packages_dir}/tool-minipro/logicic.xml
upload_command = ${platformio.packages_dir}/tool-minipro/minipro.exe $UPLOAD_FLAGS -w $SOURCE
Note that I’m using a AT29C512
flash for my particular project, edit it appropriately for your project! If you’re on Linux, don’t use minipro.exe
but rather just minipro
on the upload_command
I know this post is old, but it might be useful for someone
