Hi all,
upload target seems not interpreting correctly Windows style backslash.
I have highlighted in bold windows backslash not correctly interpreted
_Configuring upload protocol..._
_AVAILABLE: esp-prog, esptool, ftdi, iot-bus-jtag, jlink, minimodule, olimex-arm-usb-ocd, olimex-arm-usb-ocd-h, olimex-arm-usb-tiny-h, olimex-jtag-tiny, tumpa_
_CURRENT: upload_protocol = ftdi_
_Uploading .pioenvs\esp-wrover-kit\firmware.bin_
_Open On-Chip Debugger 0.10.0-dev (2018-11-05-04:10)_
_Licensed under GNU GPL v2_
_For bug reports, read_
_http://openocd.org/doc/doxygen/bugs.html_
_none separate_
_adapter speed: 20000 kHz_
_esp32 interrupt mask on_
_Info : ftdi: if you experience problems at higher adapter clocks, try the command "ftdi_tdo_sample_edge falling"_
_Info : clock speed 20000 kHz_
_Info : JTAG tap: esp32.cpu0 tap/device found: 0x120034e5 (mfg: 0x272 (Tensilica), part: 0x2003, ver: 0x1)_
_Info : JTAG tap: esp32.cpu1 tap/device found: 0x120034e5 (mfg: 0x272 (Tensilica), part: 0x2003, ver: 0x1)_
_Info : Target halted. PRO_CPU: PC=0x40000400 (active) APP_CPU: PC=0x40000400_
_Info : esp32: Debug controller 0 was reset (pwrstat=0x5F, after clear 0x0F)._
_Info : esp32: Core 0 was reset (pwrstat=0x5F, after clear 0x0F)._
_Info : Target halted. PRO_CPU: PC=0x5000004B (active) APP_CPU: PC=0x00000000_
_Info : esp32: Core 0 was reset (pwrstat=0x1F, after clear 0x0F)._
_Info : esp32: Debug controller 1 was reset (pwrstat=0x5F, after clear 0x0F)._
_Info : esp32: Core 1 was reset (pwrstat=0x5F, after clear 0x0F)._
_** Programming Started **_
_auto erase enabled_
_Info : Target halted. PRO_CPU: PC=0x4009171A (active) APP_CPU: PC=0x40000400_
_Info : Flash mapping 0: 0x10020 -> 0x3f400020, 23 KB_
_Info : Flash mapping 1: 0x20018 -> 0x400d0018, 67 KB_
_Info : Auto-detected flash size 4096 KB_
_Info : Using flash size 4096 KB_
_wrote 139264 bytes from file .pioenvs\esp-wrover-kit\firmware.bin in 2.993481s (45.432 KiB/s)_
_** Programming Finished **_
_** Verify Started **_
_read 136224 bytes from file .pioenvs\esp-wrover-kit\firmware.bin and flash bank 0 at offset 0x00010000 in 0.681558s (195.187 KiB/s)_
_contents match_
_** Verified OK **_
**_Error: couldn't open c:UsersjlmartinDocumentsPlatformIOProjects╔81122-115851-espidf-blink.pioenvsesp-wrover-kiootloader.bin_**
_embedded:startup.tcl:454: Error: ** Programming Failed **_
_in procedure 'program_esp32'_
in procedure 'program_error' called at file "C:\Users\jlmartin\.platformio\packages\tool-openocd-esp32/share/openocd/scripts/target/esp32.cfg", line 153
_at file "embedded:startup.tcl", line 454_
_*** [upload] Error 1_
If i write the command with {{… }} on a MSDOS prompt there is no problem.
Where shall i put these {{…}} ?
