Upload via avrdude to megaAvr-0: RSP_ILLEGAL_MCU_STATE
Hey guys, I am attempting an upload to a fresh Atmega3208 via a UPDI programmer (jtag2updi) and get the following error when attempting an upload:
avrdude error: bad response to read memory command: RSP_ILLEGAL_MCU_STATE
avrdude error: unable to read byte at address 0x0000
avrdude error: read operation not supported for memory signature
avrdude error: unable to read signature data for part ATmega3208, rc=-2
avrdude error: unable to read signature data, rc=-2
avrdude error: bad response to leave progmode command: RSP_ILLEGAL_MCU_STATE
After looking into this further, I tried various build flags to erase the chip first to attempt an unlock if it was locked (but I bought it freshly baked?), and to modify some fuse bits but to no avail. I also looked at related posts in this forum but haven’t found this exact scenario thus far (most don’t have issues on the initial read during programming). Has anyone else run into this similar issue or have ideas on what could be causing the behavior? I can entertain a wiring problem considering the initial read fails, but we are talking about one wire here so I am not sure how…
EDIT: Thought I’d add -v output:
avrdude: Version 7.1-arduino.1
         Copyright the AVRDUDE authors;
         see https://github.com/avrdudes/avrdude/blob/main/AUTHORS
         System wide configuration file is /home/arch/.platformio/packages/tool-avrdude/avrdude.conf
         User configuration file is /home/arch/.avrduderc
         User configuration file does not exist or is not a regular file, skipping
         Using Port                    : /dev/ttyUSB0
         Using Programmer              : jtag2updi
         Overriding Baud Rate          : 115200
JTAG ICE mkII sign-on message:
Communications protocol version: 1
M_MCU:
  boot-loader FW version:        1
  firmware version:              6.00
  hardware version:              1
S_MCU:
  hardware version:              1
Serial number:                   00:00:00:00:00:00
Device ID:                       JTAGICE mkII
         AVR Part                      : ATmega3208
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         Serial program mode           : yes
         Parallel program mode         : yes
         Memory Detail                 :
                                           Block Poll               Page                       Polled
           Memory Type Alias    Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           fuse0       wdtcfg      0     0     0    0 no          1    1      0     0     0 0x00 0x00
           fuse1       bodcfg      0     0     0    0 no          1    1      0     0     0 0x00 0x00
           fuse2       osccfg      0     0     0    0 no          1    1      0     0     0 0x00 0x00
           fuse4       tcd0cfg     0     0     0    0 no          1    1      0     0     0 0x00 0x00
           fuse5       syscfg0     0     0     0    0 no          1    1      0     0     0 0x00 0x00
           fuse6       syscfg1     0     0     0    0 no          1    1      0     0     0 0x00 0x00
           fuse7       append      0     0     0    0 no          1    1      0     0     0 0x00 0x00
           fuse8       bootend     0     0     0    0 no          1    1      0     0     0 0x00 0x00
           fuses                   0     0     0    0 no          9   10      0     0     0 0x00 0x00
           lock                    0     0     0    0 no          1    1      0     0     0 0x00 0x00
           tempsense               0     0     0    0 no          2    1      0     0     0 0x00 0x00
           signature               0     0     0    0 no          3    1      0     0     0 0x00 0x00
           prodsig                 0     0     0    0 no         61   61      0     0     0 0x00 0x00
           sernum                  0     0     0    0 no         10    1      0     0     0 0x00 0x00
           osccal16                0     0     0    0 no          2    1      0     0     0 0x00 0x00
           osccal20                0     0     0    0 no          2    1      0     0     0 0x00 0x00
           osc16err                0     0     0    0 no          2    1      0     0     0 0x00 0x00
           osc20err                0     0     0    0 no          2    1      0     0     0 0x00 0x00
           data                    0     0     0    0 no          0    1      0     0     0 0x00 0x00
           userrow     usersig     0     0     0    0 no         64   64      0     0     0 0x00 0x00
           eeprom                  0     0     0    0 no        256   64      0     0     0 0x00 0x00
           flash                   0     0     0    0 no      32768  128      0     0     0 0x00 0x00
         Programmer Type : JTAGMKII_UPDI
         Description     : JTAGv2 to UPDI bridge
         M_MCU HW version: 1
         M_MCU FW version: 6.00
         S_MCU HW version: 1
         S_MCU FW version: 6.00
         Serial number   : 00:00:00:00:00:00
         Vtarget         : 5.0 V
