My board is plugged in to the same named usb port that the Arduino IDE recognizes. upload_speed = 115200
I’m trying to overwrite the code that is currently running on the board. Which does use Serial.print().
Could that be why the port is busy?
File "/Users/dave_j/.platformio/packages/tool-esptoolpy/esptool.py", line 3201, in <module>
_main()
File "/Users/dave_j/.platformio/packages/tool-esptoolpy/esptool.py", line 3194, in _main
main()
File "/Users/dave_j/.platformio/packages/tool-esptoolpy/esptool.py", line 2889, in main
esp = chip_class(each_port, initial_baud, args.trace)
File "/Users/dave_j/.platformio/packages/tool-esptoolpy/esptool.py", line 237, in __init__
self._port = serial.serial_for_url(port)
File "/Users/dave_j/.platformio/penv/lib/python3.7/site-packages/serial/__init__.py", line 88, in serial_for_url
instance.open()
File "/Users/dave_j/.platformio/penv/lib/python3.7/site-packages/serial/serialposix.py", line 268, in open
raise SerialException(msg.errno, "could not open port {}: {}".format(self._port, msg))
serial.serialutil.SerialException: [Errno 16] could not open port /dev/cu.usbserial-14220: [Errno 16] Resource busy: '/dev/cu.usbserial-14220'
*** [upload] Error 1
