I’m new to PlatformIO and I’m migrating my native ArduinoIDE project to PlatformIO to refactor it.
Unfortunately I’m getting this error:
Uploading .pioenvs/teensy36/firmware.hex
Teensy Loader, Command Line, Version 2.1
Read ".pioenvs/teensy36/firmware.hex": 17560 bytes, 1.7% usage
Error opening HID Manager
Soft reboot is not implemented for OSX
Waiting for Teensy device...
(hint: press the reset button)
Even if I’m pressing the reset button nothing happen.
I’m working on Mac OSX 10.12.6 (16G29) with the latest atom App and the latest PlatformIO Packages …
Do anybody has a solution for that problem?
Hm, I’ve got a similar setup (though I’m using the CLI, not Atom) and it works just fine.
I assume that a similar build works with Teensyduino?
Have you done the obvious stuff like swap cables and USB ports?
PlatformIO uses a different command line uploader than the Mac GUI one provided with Teensyduino, but it’s been very reliable for me.
yes, with teensyduino everything works fine …
I’ve found a thread about a little “hack” but this isn’t the way I want to get it working because in my understanding I have to modify some system stuff and that can’t be the goal I think.
I didn’t tried the CLI until now, but I’m thinking about including grunt with a watcher on the built file and then executing the CLI task to upload it to my teensy … but again: this is way to complicated … there should be a better way by uploading the new firmware via the PlatformIO package … otherwise I could switch to another IDE because PlatformIO within atom is getting useless for me
Hm, I’m not sure, something’s definitely not right. The 'Error opening HID Manager" is the useful error here.
Check out:
https://forum.pjrc.com/threads/36546-teensy_loader_cli-on-OSX-quot-Error-opening-HID-Manager-quot
yeah, that’s the thread I found … I removed the teensy_loader_cli binary from the folder (like in the last post).
It’s working now … as far as I know is the softreboot currently not implemented for OSX … so I have to manually reboot the teensy … but hey … the most important thing to me was the code completion, code indention and structure
Thank you for your help
The same macOS, all works well with Teensy 3.1. Is this a probem only with new Teensys? I think we can disable CLI for Teensy 3.5+
/cc @blackketter
teensy_loader_cli works fine for me with Teensy 3.6. I’m not sure what the root problem is, it predates 3.5/6, I believe.
Looking at the code, IOHIDManagerOpen() fails but I don’t know how to reproduce here to dig deeper.
@pixel-shock A shot in the dark: is your user an Administrator?
I prefer the CLI updater to the GUI one personally, happy to help fix…
@ivankravets Maybe it’s only with the new one … this is my first project with the arduino/ teensy stuff
It think the most dynamic solution would be a flag in the platformio.ini in which the user can toggle the usage of the teensy_loader_cli binary?
@blackketter Yes I’m the Admin user on that machine, I also tried it on my another MacBook and I was able to reproduce the problem with the same error message.
But since I manually rebooted the teensy after uploading via Atom+PlatfomIO it’s working with the automatic reboot with the Teensy Loader GUI open.
