I have three projects I’m using to teach myself.
- Read a DT11 Sensor
- Use a 4 digit 7 Segment LED
- Try to combine the two and display the temperature.
The issue I’m having is for some reason I can’t simply upload code to the Arduino Uno board. I’ve had no issue until this removing projects and creating new projects as I learn more.
I’ve read quite a few historical similar topics and for example added upload_flags = -e to platformio.ini
I’m using the same Arduino UNO board with the correct port settings etc, but this is what I see in the terminal when I execute a download?
CONFIGURATION: https://docs.platformio.org/page/boards/atmelavr/uno.html
PLATFORM: Atmel AVR (5.0.0) > Arduino Uno
DEBUG: Current (avr-stub) External (avr-stub, simavr)
- framework-arduino-avr @ 5.2.0
- tool-avrdude @ 1.60300.200527 (6.3.0)
Found 8 compatible libraries
|-- SevSeg @ 3.7.1
|-- DHT sensor library @ 1.4.6
|-- Adafruit Unified Sensor @ 1.1.14
Checking size .pio\build\uno\firmware.elf
RAM: [= ] 8.7% (used 179 bytes from 2048 bytes)
Flash: [== ] 16.3% (used 5272 bytes from 32256 bytes)
AVAILABLE: arduino
Looking for upload port...
Auto-detected: COM4
Uploading .pio\build\uno\firmware.hex
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x00
avrdude done. Thank you.
*** [upload] Error 1
==================================================== [FAILED] Took 3.36 seconds ====================================================
* The terminal process "C:\Users\derek\.platformio\penv\Scripts\platformio.exe 'run', '--target', 'upload'" terminated with exit code: 1.
I can’t work out why the comms would fail when it usually works?
