neogene
February 20, 2024, 9:02pm
1
Hi, i’ve just started using platformio on visual studio code on Mac OS Ventura, but when changing the upload_speed value inside the ini file is not respected.
It fails uploading to an LILYGO TTGO ESP32-Paxcounter LoRa32 .
extract from .ini:
[env:usb]
upload_protocol = esptool
upload_speed = 115200
the log displays:
Retrieving maximum program size .pio/build/usb/firmware_ttgov21new_v3.6.1.elf
Checking size .pio/build/usb/firmware_ttgov21new_v3.6.1.elf
RAM: [== ] 19.9% (used 65248 bytes from 327680 bytes)
Flash: [======= ] 65.3% (used 1283321 bytes from 1966080 bytes)
Configuring upload protocol…
AVAILABLE: cmsis-dap, esp-bridge, esp-prog, espota, esptool, iot-bus-jtag, jlink, minimodule, olimex-arm-usb-ocd, olimex-arm-usb-ocd-h, olimex-arm-usb-tiny-h, olimex-jtag-tiny, tumpa
Looking for upload port…
Using manually specified: /dev/cu.usbserial-56750049631
Uploading .pio/build/usb/firmware_ttgov21new_v3.6.1.bin
esptool.py v4.5.1
Serial port /dev/cu.usbserial-56750049631
Connecting…
Chip is ESP32-PICO-D4 (revision v1.0)
Features: WiFi, BT, Dual Core, 240MHz, Embedded Flash, VRef calibration in efuse, Coding Scheme None
Crystal is 40MHz
MAC: d4:d4:da:9e:ae:84
Uploading stub…
Running stub…
Stub running…
Changing baud rate to 921600
Changed.
A fatal error occurred: Unable to verify flash chip connection (Packet content transfer stopped (received 7 bytes)).
*** [upload] Error 2
What is the full platformio.ini?
neogene
February 20, 2024, 9:27pm
3
; ---> SELECT ONE TARGET BOARD FROM FOLLOWING ROWS <---
; Note: For "LILYGO TTGO ESP32-Paxcounter LoRa32 V2.1 1.6.1" select board ttgov21new.h
; Note: For "LILYGO TTGO ESP32-Paxcounter LoRa32 V2.0 1.6.0" select board ttgov2.h and add bodge wire from LORA_IO1 to GPIO33
[board]
;halfile = generic.h
;halfile = ebox.h
;halfile = eboxtube.h
;halfile = ecopower.h
;halfile = heltec.h
;halfile = heltecv2.h
;halfile = heltecv21.h
;halfile = ttgov1.h
;halfile = ttgov2.h
;halfile = ttgov21old.h
halfile = ttgov21new.h
;halfile = ttgofox.h
;halfile = ttgobeam.h
;halfile = ttgobeam10.h
;halfile = ttgotdisplay.h
;halfile = ttgotwristband.h
;halfile = fipy.h
;halfile = lopy.h
;halfile = lopy4.h
;halfile = lolin32litelora.h
;halfile = lolin32lora.h
;halfile = lolin32lite.h
;halfile = wemos32oled.h
;halfile = wemos32matrix.h
;halfile = octopus32.h
;halfile = tinypico.h
;halfile = tinypicomatrix.h
;halfile = m5core.h
;halfile = m5fire.h
;halfile = olimexpoeiso.h
[platformio]
; upload firmware to board with usb cable
default_envs = usb
; upload firmware to a paxexpress repository
;default_envs = ota
; use upstream version of arduino-espressif32 framework
;default_envs = dev
description = Paxcounter is a device for metering passenger flows in realtime. It counts how many mobile devices are around.
[common]
; for release_version use max. 10 chars total, use any decimal format like "a.b.c"
release_version = 3.6.1
; DEBUG LEVEL: For production run set to 0, otherwise device will leak RAM while running!
; 0=None, 1=Error, 2=Warn, 3=Info, 4=Debug, 5=Verbose
debug_level = 0
extra_scripts = pre:shared/build.py
otakeyfile = ota.conf
lorakeyfile = loraconf.h
lmicconfigfile = lmic_config.h
platform_espressif32 = espressif32@6.3.2
upload_speed = 115200 ; set by build.py and taken from hal file
lib_deps_lora =
mcci-catena/MCCI LoRaWAN LMIC library @ ^4.1.1
lib_deps_display =
bitbank2/OneBitDisplay @ ^2.3.1
bitbank2/bb_spi_lcd @ ^2.4.1
ricmoo/QRCode @ ^0.0.1
lib_deps_ledmatrix =
seeed-studio/Ultrathin_LED_Matrix @ ^1.0.0
lib_deps_rgbled =
fastled/FastLED @ ^3.6.0
lib_deps_gps =
mikalhart/TinyGPSPlus @ ^1.0.3
lib_deps_sensors =
adafruit/Adafruit Unified Sensor @ ^1.1.11
adafruit/Adafruit BME280 Library @ ^2.2.2
adafruit/Adafruit BMP085 Library @ ^1.2.2
boschsensortec/BSEC Software Library @ 1.8.1492
lewapek/Nova Fitness Sds dust sensors library @ ^1.5.1
lib_deps_basic =
https://github.com/dbSuS/libpax.git
https://github.com/SukkoPera/Arduino-Rokkit-Hash.git
bblanchon/ArduinoJson @ ^6.21.3
makuna/RTC @ ^2.4.2
mathertel/OneButton @ ^2.0.3
lewisxhe/XPowersLib @ ^0.1.7
256dpi/MQTT @ ^2.5.1
lib_deps_all =
${common.lib_deps_basic}
${common.lib_deps_lora}
${common.lib_deps_display}
${common.lib_deps_rgbled}
${common.lib_deps_gps}
${common.lib_deps_sensors}
${common.lib_deps_ledmatrix}
build_flags_all =
-include "shared/paxcounter.conf"
'-D CORE_DEBUG_LEVEL=${common.debug_level}'
'-D LOG_LOCAL_LEVEL=${common.debug_level}'
'-D PROGVERSION="${common.release_version}"'
'-D LIBPAX_WIFI'
'-D LIBPAX_BLE'
'-D LIBPAX_ARDUINO'
'-D USE_ESP_IDF_LOG'
'-D TAG=__FILE__'
'-U BOARD_HAS_PSRAM'
[env]
board_build.partitions = min_spiffs.csv
build_type = release
upload_speed = ${common.upload_speed}
;upload_port = COM12
platform = ${common.platform_espressif32}
lib_deps = ${common.lib_deps_all}
-include "shared/hal/${board.halfile}"
${common.build_flags_all}
extra_scripts = ${common.extra_scripts}
monitor_speed = ${common.monitor_speed}
monitor_filters = time, esp32_exception_decoder, default
[env:ota]
upload_protocol = custom
[env:usb]
; necessary for macos - adjust devicename accordingly
;upload_port = /dev/cu.usbserial-56750049631
;monitor_port = /dev/cu.usbserial-56750049631
[env:dev]
platform = https://github.com/platformio/platform-espressif32.git#develop
platform_packages = framework-arduinoespressif32 @ https://github.com/espressif/arduino-esp32.git
[env:ci]
-include "shared/hal/${sysenv.CI_HALFILE}" ; set by CI
PlatformIO definitely respects upload_speed by passing the wanted value into the esptool.py invocation. For example,
upload_speed = 74880
When doing a verbose upload (project tasks → Advanced → Verbose Upload), it prints
“/home/xxxxxxx/.platformio/penv/bin/python” “/home/xxxxxxx/.platformio/packages/tool-esptoolpy/esptool.py” --chip esp32 --port “/dev/ttyACM0” --baud 74880 […]
Do the same in your project. Does it pass 921600 or 115200? In the first case, another extra_script may have overwritten your upload_speed directive, such as
In the second case (esptool.py gets passed 115200 but stil uses 921600), it’s an esptool.py issue, not PlatformIO.
neogene
February 21, 2024, 12:31pm
5
maxgerhardt:
esptool.py”
ok I see baud at 921600 in command.
/Users/neogene/.platformio/packages/tool-esptoolpy/esptool.py" --chip esp32 --port "/dev/cu.usbserial-56750049631" --baud **921600** --before default_reset --after hard_reset write_flash -z --flash_mode dio --flash_freq 40m --flash_size 4MB 0x1000 /Users/neogene/Downloads/Safari/ESP32-Paxcounter-3.6.1/.pio/build/usb/bootloader.bin 0x8000 /Users/neogene/Downloads/Safari/ESP32-Paxcounter-3.6.1/.pio/build/usb/partitions.bin 0xe000 /Users/neogene/.platformio/packages/framework-arduinoespressif32@3.20009.0/tools/partitions/boot_app0.bin 0x10000 .pio/build/usb/firmware_ttgov21new_v3.6.1.bin
neogene
February 21, 2024, 12:33pm
6
Looking build.py it uses:
myboard = mykeys["board"]
myuploadspeed = mykeys["upload_speed"]
env.Replace(BOARD=myboard)
env.Replace(UPLOAD_SPEED=myuploadspeed)
print('\033[94m' + "Target board: " + myboard + " @ " + myuploadspeed + "bps" + '\033[0m')
neogene
February 21, 2024, 12:37pm
7
ok found: the related file has a comment in the first lines which declare the value of the upload speed, and it parse that file getting the speed (never seen used a comment as a param but now i manage to upload). Thank you for the support.
Thank you.
// clang-format off
// upload_speed 115200
// board esp32dev
#ifndef _TTGOV21NEW_H
#define _TTGOV21NEW_H
#include <stdint.h>
Working on Platformio on Ubuntu for a year now. Just upgraded my hardware and now compiling times are minimal, just a few seconds only. Now I want to increase the upload speed that I am struggling with.
Using a ESP32-S3 over USC-C for uploading. Whatever upload_speed I set in the platformio.ini (tested from 9600 till 921600) the upload time remains the same. For 994.640 bytes (compressed 639.799) it takes about 7-8 seconds (around 1.000 kbit/s). When I do a verbose upload, I see that my supplied speeds are used in the command.
Also tried to use ArduinoOTA to see if that would be faster, but that gives me 11-12 seconds to upload a new file (when the ESP32 was next to my Access Point).
So, I hope somebody can explain the above behavior and how I can achieve faster uploads using the USB port on the ESP32.
Thanks
Etienne
