full disclaimer: total newb and trying to dig my way into the matter
After some successful OTAs the Sonoff Touch with Firmware 1.70 should be my first FTDI flash. However, I won’t get arendst’s current tasmota uploaded. I already did
- by another FTDI (now standard FTDI 232-based)
- soldered the pins
- changed the cables
- switched to current Atom with current platform.io
but I still receive the following error message after a successful build/compile:
FTDI Device:
/dev/cu.usbserial-A9UV7797
Hardware ID: USB VID:PID=0403:6001 SER=A9UV7797 LOCATION=20-1.1
Description: FT232R USB UART
Anzeige im Terminal-Monitor:
pio device monitor --port /dev/cu.usbserial-A9UV7797 --baud 115200
devname:Sonoff-Tasmota-master username$ pio device monitor --port /dev/cu.usbserial-A9UV7797 --baud 115200
— Miniterm on /dev/cu.usbserial-A9UV7797 115200,8,N,1 —
— Quit: Ctrl+C | Menu: Ctrl+T | Help: Ctrl+T followed by Ctrl+H —
Log beim Upload:
Processing sonoff (platform: espressif8266@1.5.0; board: esp01_1m; framework: arduino)
Verbose mode can be enabled via
-v, --verbose
option
PLATFORM: Espressif 8266 > Espressif Generic ESP8266 ESP-01 1M
SYSTEM: ESP8266 80MHz 80KB RAM (1MB Flash)
Converting sonoff.ino
Library Dependency Finder → deleted link due to forum rulesLDF MODES: FINDER(chain) COMPATIBILITY(soft)
Collected 40 compatible libraries
Scanning dependencies…
|-- 1.0.2
| |-- 1.0
|-- 2.0.0
|-- 1.1
| |-- 1.1
| | |-- 1.0
| |-- 1.0
|-- 2.6
|-- 5.11.2
|-- 1.1
| |-- 1.0
|-- 0.5.1
| |-- 1.0
| | |-- 1.0
| |-- 1.0
| |-- 1.0
|-- 1.0
|-- 1.1.0| |-- 1.0
|-- 2.2.1
|-- 1.0
| |-- 1.0
|-- 2.3.2
|-- 1.0.0
|-- 1.0
| |-- 1.0
| | |-- 1.0
|-- <Joba_Tsl2561> 2.0.1
| |-- 1.0
|-- 1.0
|-- 1.0
|-- <BME680_driver-bme680_v3.5.9>
|-- 1.0.0
| | |-- 1.0
|-- <Mutichannel_Gas_Sensor> 0.0.1
| |-- 1.0
| |-- 1.0
|-- 1.0.1
|-- 2.2.9
| |-- 1.0
|-- 1.0
Compiling .pioenvs/sonoff/src/sonoff.ino.cpp.oLinking .pioenvs/sonoff/firmware.elf
Building .pioenvs/sonoff/firmware.bin
Checking size .pioenvs/sonoff/firmware.elf
Memory Usage → Redirecting...
DATA: [======= ] 66.3% (used 54344 bytes from 81920 bytes)
PROGRAM: [===== ] 51.8% (used 542995 bytes from 1048576 bytes)
Configuring upload protocol…
Looking for upload port…
Use manually specified: /dev/cu.usbserial-A9UV7797
Uploading .pioenvs/sonoff/firmware.bin
Uploading 547136 bytes from .pioenvs/sonoff/firmware.bin to flash at 0x00000000
warning: espcomm_send_command: didn’t receive command response
warning: espcomm_send_command(FLASH_DOWNLOAD_DATA) failed
warning: espcomm_send_command: wrong direction/command: 0x01 0x03, expected 0x01 0x04
error: espcomm_upload_mem failed
*** [upload] Error 255
========================== [ERROR] Took 9.99 seconds ==========================
Environment sonoff [ERROR]
========================== [ERROR] Took 9.99 seconds ============================================================ [SUMMARY] ==================================
Environment sonoff-minimal [SKIP]
Environment sonoff-classic [SKIP]
Environment sonoff-knx [SKIP]
Environment sonoff-allsensors [SKIP]
Environment sonoff-BG [SKIP]
Environment sonoff-BR [SKIP]
Environment sonoff-CN [SKIP]
Environment sonoff-CZ [SKIP]
Environment sonoff-DE [SKIP]
Environment sonoff-ES [SKIP]
Environment sonoff-FR [SKIP]
Environment sonoff-GR [SKIP]
Environment sonoff-HU [SKIP]
Environment sonoff-IT [SKIP]
Environment sonoff-NL [SKIP]
Environment sonoff-PL [SKIP]
Environment sonoff-PT [SKIP]
Environment sonoff-RU [SKIP]
Environment sonoff-UK [SKIP]
Environment sonoff-TW [SKIP]
I don’t know how to move on from “Error 255”. Can anybody help me?
Thanks in advance
