Hi, so I want to upload a Spiffs image onto my NodeMCU, but when I try I get the following error:
Building SPIFFS image from ‘data’ directory to .pioenvs\nodemcuv2\spiffs.bin
/index.htm
/input.htm
Looking for upload port…
Auto-detected: COM5
Uploading .pioenvs\nodemcuv2\spiffs.bin
error: Failed to open COM5
error: espcomm_open failed
error: espcomm_upload_mem failed
*** [uploadfs] Error 2
Would be really nice if someone could help me.
Nevermind, if you close vscode and then reopen it, everything will work just fine.
I have the same problem with ESPDuino. Nothing helps.
I’m sure the port is free. I see the ESP reset,
[env:espduino]
platform = espressif8266
board = espduino
I found older reports of 2018 where the problem was supposed to be solved in newer versions of the ESP platform.
I have the latest insall op platform IO and VSC (fresh install of both)
Help,
