Firstly, thanks for an excellent framework. I am facing an issue uploading for mbed STM32F439ZIT6 using platformIO. I have tried to read various sources in order to better understand what’s going on and checked similar topics here, but the error returned from openocd doesn’t seem very clear as to what’s going wrong. I am very accustomed to embedded development with AVR, ESP, SAMD and Arduino, but not with ST32 boards, it is possible (and likely) that I’ve missed a step, and I apologise in advance if thats the case!
The platformio project I’m trying to build is an open source library that uploads fine for the MKR1300 and ATmega2560 targets, I can run the examples on either of the other two targets. You can see the full project setup on Github: GitHub - davetcc/IoAbstraction: Rotary encoders, fully debounced switches, EEPROM support on Arduino and mbed - direct and over I2C
Output of Device list (taken on Windows but similar report on MacOS):
>pio device list
COM8
Hardware ID: USB VID:PID=0483:374B SER=7 LOCATION=1-8:x.2
Description: STMicroelectronics STLink Virtual COM Port (COM8)
Two setups that I’ve tried this on:
Windows 10 with PlatformIO, version 4.3.3, cmd shell
IDE: Clion 2020.1 (mingw chain) (but this fails even from CLI)
CPU Ryzen 1700X, 32GB RAM, 500G M2 SSD.
MacOS Catalina with Platform IO version 4.3.3, zsh shell
IDE Clion 2020.1 (Fails even from CLI)
MacBook PRO 15" / 16GB RAM / 500G SSD.
Snippet of the error message taken from below log
Error: init mode failed (unable to connect to the target)
in procedure 'program'
** OpenOCD init failed **
Snippet of platformio.ini (see link at top of post for full project):
[env:STM439]
platform = ststm32
board = nucleo_f439zi
framework = mbed
;upload_port = /dev/cu.usbmodem14103
upload_port = COM8
;monitor_speed = 115200
build_flags = -D_NO_EEPROM_CLASS_=1, -DPIO_FRAMEWORK_MBED_RTOS_PRESENT
Command executed on both MacOS (zsh) and Windows 10 (cmd):
pio run -t upload -e STM439 -v
Full log contents:
Processing STM439 (platform: ststm32; board: nucleo_f439zi; framework: mbed; upload_port: COM8; build_flags: -D_NO_EEPROM_CLASS_=1, -DPIO_FRAMEWORK_MBED_RTOS_PRESENT)
CONFIGURATION: [link removed]/nucleo_f439zi.html
PLATFORM: ST STM32 6.1.0 > ST Nucleo F439ZI
HARDWARE: STM32F439ZIT6 180MHz, 256KB RAM, 2MB Flash
DEBUG: Current (stlink) On-board (stlink) External (blackmagic, jlink)
- framework-mbed 6.51401.200402 (5.14.1)
- tool-dfuutil 1.9.200310
- tool-openocd 2.1000.190707 (10.0)
- tool-stm32duino 1.0.2
Collecting mbed sources...
LDF: Library Dependency Finder ->...
Found 10 compatible libraries
|-- <src> (C:\Users\dave\Documents\Arduino\libraries\IoAbstraction\src)
MethodWrapper(["checkprogsize"], [".pio\build\STM439\firmware.elf"])
RAM: [= ] 9.8% (used 25800 bytes from 262144 bytes)
Flash: [ ] 3.1% (used 64664 bytes from 2097152 bytes)
.pio\build\STM439\firmware.elf :
section size addr
.text 61720 134217728
.ARM.exidx 8 134279448
.crash_data_ram 256 536871344
.data 2936 536871600
.bss 22864 536874536
.heap 169096 536897400
.ARM.attributes 46 0
.comment 126 0
.debug_info 951446 0
.debug_abbrev 99175 0
.debug_loc 161827 0
.debug_aranges 13448 0
.debug_ranges 20752 0
.debug_line 162102 0
.debug_str 171991 0
.debug_frame 41916 0
.stabstr 118 0
Total 1879827
<lambda>(["upload"], [".pio\build\STM439\firmware.elf"])
AVAILABLE: blackmagic, jlink, mbed, stlink
openocd -d2 -s C:\Users\dave\.platformio\packages\tool-openocd/scripts -f board/st_nucleo_f4.cfg -c "program {.pio\build\STM439\firmware.elf} verify reset; shutdown;"
xPack OpenOCD, 64-bit Open On-Chip Debugger 0.10.0+dev (2019-07-17-11:28)
Licensed under GNU GPL v2
For bug reports, read
[link removed]
debug_level: 2
Info : clock speed 2000 kHz
Info : STLINK V2J36M26 (API v2) VID:PID 0483:374B
Info : Target voltage: 3.235194
shutdown command invoked
*** [upload] Error 1
===================================================================================================== [FAILED] Took 56.04 seconds =====================================================================================================
Environment Status Duration
ATmega2560 IGNORED
Mkr1300 IGNORED
STM439 FAILED 00:00:56.036
================================================================================================ 1 failed, 0 succeeded in 00:00:56.036 ================================================================================================
Lastly, to remove any doubt, mbed-blink from the examples fails in exactly the same way.
Info : Target voltage: 3.238345
and for reference I had to add the following lines to blink’s platformio.ini:
[env:nucleo_f439]
platform = ststm32
framework = mbed
Many thanks,
Dave
