I have seveal projects using ESP32 and ESP3866 boards using Wifi and ESP-NOW . They worked without problems.
Today I updated platformio as offered at startup.
Since then, upload does not work any more.
I also tried a new empty project with same resut.
log before upload begins:
Processing nodemcuv2 (platform: espressif8266; board: nodemcuv2; framework: arduino)
CONFIGURATION: https://docs.platformio.org/page/boards/espressif8266/nodemcuv2.html
PLATFORM: Espressif 8266 (4.0.1) > NodeMCU 1.0 (ESP-12E Module)
HARDWARE: ESP8266 80MHz, 80KB RAM, 4MB Flash
- framework-arduinoespressif8266 @ 3.30002.0 (3.0.2)
- tool-esptool @ 1.413.0 (4.13)
- tool-esptoolpy @ 1.30000.201119 (3.0.0)
- tool-mkspiffs @ 1.200.0 (2.0)
- toolchain-xtensa @ 2.100300.210717 (10.3.0)
Found 36 compatible libraries
|-- elapsedMillis @ 1.0.6
|-- ESP8266WiFi @ 1.0
|-- Servo @ 1.0.2
|-- Ticker @ 1.0
Retrieving maximum program size .pio/build/nodemcuv2/firmware.elf
Checking size .pio/build/nodemcuv2/firmware.elf
RAM: [=== ] 34.9% (used 28576 bytes from 81920 bytes)
Flash: [=== ] 26.3% (used 274713 bytes from 1044464 bytes)
AVAILABLE: espota, esptool
Looking for upload port...
Auto-detected: /dev/cu.SLAB_USBtoUART
Uploading .pio/build/nodemcuv2/firmware.bin
esptool.py v3.0
Serial port /dev/cu.SLAB_USBtoUART
Then I get the following error on all my projects:
File "/Users/ruediheimlicher/.platformio/packages/tool-esptoolpy@1.30000.201119/esptool.py", line 3969, in <module>
_main()
File "/Users/ruediheimlicher/.platformio/packages/tool-esptoolpy@1.30000.201119/esptool.py", line 3962, in _main
main()
File "/Users/ruediheimlicher/.platformio/packages/tool-esptoolpy@1.30000.201119/esptool.py", line 3551, in main
esp = chip_class(each_port, initial_baud, args.trace)
File "/Users/ruediheimlicher/.platformio/packages/tool-esptoolpy@1.30000.201119/esptool.py", line 271, in __init__
self._port = serial.serial_for_url(port)
File "/Users/ruediheimlicher/.platformio/penv/lib/python3.9/site-packages/serial/__init__.py", line 90, in serial_for_url
instance.open()
File "/Users/ruediheimlicher/.platformio/penv/lib/python3.9/site-packages/serial/serialposix.py", line 332, in open
self._reconfigure_port(force_update=True)
File "/Users/ruediheimlicher/.platformio/penv/lib/python3.9/site-packages/serial/serialposix.py", line 517, in _reconfigure_port
termios.tcsetattr(
termios.error: (22, 'Invalid argument')
*** [upload] Error 1
How can I get back to previous version?
macos 12.5
core 6.1.6
Home: 3.4.3
Example of platformio.ini:
[env:nodemcu-32s]
enjoyneering/LiquidCrystal_I2C@^1.3.3
thingpulse/ESP8266 and ESP32 OLED driver for SSD1306 displays@^4.3.0
adafruit/Adafruit SSD1306@^2.5.7
adafruit/Adafruit GFX Library@^1.11.5
board = nodemcu-32s
