Upload Error > Could not find one of 'package.json' manifest files in the package
Dear Community,
I am facing an error I am not able to solve for a few days already. Can somone shed some light please?
I am trying to upload a program to my WeMos D1 Mini via Platformio.
my pfatformio.ini file:
[env:d1_mini]
platform = espressif8266@2.6.3
board = d1_mini
board_build.ldscript = eagle.flash.1m256.ld
upload_port = COM4
upload_speed = 115200
platform_packages =
   framework-arduinoespressif8266 @ https://github.com/esp8266/Arduino/releases/download/2.6.3/esp8266-2.6.3.zip
My project seems to build all right,
Processing d1_mini (platform: espressif8266@2.6.3; board: d1_mini; framework: arduino)
CONFIGURATION: https://docs.platformio.org/page/boards/espressif8266/d1_mini.html
PLATFORM: Espressif 8266 (2.6.3) > WeMos D1 R2 and mini
HARDWARE: ESP8266 80MHz, 80KB RAM, 4MB Flash
 - framework-arduinoespressif8266 @ 2.6.3
 - tool-esptool @ 1.413.0 (4.13)
 - tool-esptoolpy @ 1.30000.201119 (3.0.0)
 - toolchain-xtensa @ 2.40802.200502 (4.8.2)
Found 29 compatible libraries
Retrieving maximum program size .pio\build\d1_mini\firmware.elf
Checking size .pio\build\d1_mini\firmware.elf
RAM:   [===       ]  32.7% (used 26772 bytes from 81920 bytes)
Flash: [===       ]  33.6% (used 255680 bytes from 761840 bytes)
The problematic part is the error I am getting when trying to run the Upload Command
I am getting following error:
Error: Could not find one of 'package.json' manifest files in the package
Maybe someone out there knows what is wrong.
Thank you
Why these two older versions? Which Arduino-ESP8266 core version do you want to use, and which platform-espressif8266 version (which are two completely different entities)?
I think I would like to use 2.6.3.
The reason why to use older version is that I am trying to build a water valve control system and I need to use TimedAction and ArduinoIOT Cloud libraries. There was some clash with the newest version so I decided to use an older version.
The platform-espressif8266 version that uses Arduino-ESP8266 core 2.6.3 is
platform = espressif8266@2.3.2
does that work better?
Unfortunately no, I have simplified the ini file to this:
[env:d1_mini]
board = d1_mini
upload_port = COM4
Build was success
  • framework-arduinoespressif8266 @ 2.20603.191216 (2.6.3)
  • tool-esptool @ 1.413.0 (4.13)
  • tool-esptoolpy @ 1.20800.0 (2.8.0)
  • toolchain-xtensa @ 2.40802.200502 (4.8.2)
Upload failed. Same error:
Error: Could not find one of ‘package.json’ manifest files in the package
Thank you
Works just fine on my computer.
Maybe you have a corrupted download / package. Remove all folders in C:\Users\<user>\.platformio\packages\ and C:\Users\<user>\.platformio\.cache, then re-upload the project.
it worked!!! Thank you
thank you, it’s work.
After installing the extension in VS CODE it brought up the error while trying to create a new project, as a last resort, I installed the previous version and configured a new project in the default directory, but for some reason, it won’t accept a custom directory.
Please open a new topic with your exact platformio.ini and error message.
