I get an error 1 when uploading a (small) C program to an Arduino Uno R3 board.
I am really new at PlatformIO and embedded programming in general. I checked the following settings, but I don’t know where else to look:
- The user has been added to the
dialoutgroup. - The
99-platform-udev.ruleshave been installed in the correct location. There is still the warning of not finding this file, but I am led to believe this is just a warning and not the cause for the error. I may be wrongly informed, of course.
This is part of the output of lsusb:
Bus 003 Device 008: ID 2341:0043 Arduino SA Uno R3 (CDC ACM)
My system is Fedora 39, with VS Studio Code. Tried the upload also with Codium, but getting the same error.
This is the output I get:
Processing ATmega328P (platform: atmelavr; board: ATmega328P)
CONFIGURATION: https://docs.platformio.org/page/boards/atmelavr/ATmega328P.html
PLATFORM: Atmel AVR (5.0.0) > ATmega328P/PA
HARDWARE: ATMEGA328P 16MHz, 2KB RAM, 32KB Flash
DEBUG: Current (avr-stub) External (avr-stub, simavr)
- tool-avrdude @ 1.60300.200527 (6.3.0)
Found 0 compatible libraries
Checking size .pio/build/ATmega328P/firmware.elf
RAM: [ ] 0.0% (used 0 bytes from 2048 bytes)
Flash: [ ] 0.4% (used 144 bytes from 32768 bytes)
AVAILABLE: urclock
CURRENT: upload_protocol = urclock
Looking for upload port...
Warning! Your `/etc/udev/rules.d/99-platformio-udev.rules` are outdated. Please update or reinstall them.
More details: https://docs.platformio.org/en/latest/core/installation/udev-rules.html
Auto-detected: /dev/ttyACM0
Uploading .pio/build/ATmega328P/firmware.hex
avrdude: Can't find programmer id "urclock"
Valid programmers are:
2232HIO = FT2232H based generic programmer
4232h = FT4232H based generic programmer
arduino = Arduino
arduino-ft232r = Arduino: FT232R connected to ISP
arduinoisp = Arduino ISP Programmer
arduinoisporg = Arduino ISP Programmer
atmelice = Atmel-ICE (ARM/AVR) in JTAG mode
atmelice_dw = Atmel-ICE (ARM/AVR) in debugWIRE mode
atmelice_isp = Atmel-ICE (ARM/AVR) in ISP mode
atmelice_pdi = Atmel-ICE (ARM/AVR) in PDI mode
avr109 = Atmel AppNote AVR109 Boot Loader
avr910 = Atmel Low Cost Serial Programmer
avr911 = Atmel AppNote AVR911 AVROSP
avrftdi = FT2232D based generic programmer
avrisp = Atmel AVR ISP
avrisp2 = Atmel AVR ISP mkII
avrispmkII = Atmel AVR ISP mkII
avrispv2 = Atmel AVR ISP V2
buspirate = The Bus Pirate
buspirate_bb = The Bus Pirate (bitbang interface, supports TPI)
butterfly = Atmel Butterfly Development Board
butterfly_mk = Mikrokopter.de Butterfly
bwmega = BitWizard ftdi_atmega builtin programmer
C232HM = FT232H based module from FTDI and Glyn.com.au
c2n232i = serial port banging, reset=dtr sck=!rts mosi=!txd miso=!cts
dasa = serial port banging, reset=rts sck=dtr mosi=txd miso=cts
dasa3 = serial port banging, reset=!dtr sck=rts mosi=txd miso=cts
diecimila = alias for arduino-ft232r
dragon_dw = Atmel AVR Dragon in debugWire mode
dragon_hvsp = Atmel AVR Dragon in HVSP mode
dragon_isp = Atmel AVR Dragon in ISP mode
dragon_jtag = Atmel AVR Dragon in JTAG mode
dragon_pdi = Atmel AVR Dragon in PDI mode
dragon_pp = Atmel AVR Dragon in PP mode
flip1 = FLIP USB DFU protocol version 1 (doc7618)
flip2 = FLIP USB DFU protocol version 2 (AVR4023)
ft232r = FT232R Synchronous BitBang
ft245r = FT245R Synchronous BitBang
jtag1 = Atmel JTAG ICE (mkI)
jtag1slow = Atmel JTAG ICE (mkI)
jtag2 = Atmel JTAG ICE mkII
jtag2avr32 = Atmel JTAG ICE mkII im AVR32 mode
jtag2dw = Atmel JTAG ICE mkII in debugWire mode
jtag2fast = Atmel JTAG ICE mkII
jtag2isp = Atmel JTAG ICE mkII in ISP mode
jtag2pdi = Atmel JTAG ICE mkII PDI mode
jtag2slow = Atmel JTAG ICE mkII
jtag3 = Atmel AVR JTAGICE3 in JTAG mode
jtag3dw = Atmel AVR JTAGICE3 in debugWIRE mode
jtag3isp = Atmel AVR JTAGICE3 in ISP mode
jtag3pdi = Atmel AVR JTAGICE3 in PDI mode
jtagkey = Amontec JTAGKey, JTAGKey-Tiny and JTAGKey2
jtagmkI = Atmel JTAG ICE (mkI)
jtagmkII = Atmel JTAG ICE mkII
jtagmkII_avr32 = Atmel JTAG ICE mkII im AVR32 mode
lm3s811 = Luminary Micro LM3S811 Eval Board (Rev. A)
mib510 = Crossbow MIB510 programming board
mkbutterfly = Mikrokopter.de Butterfly
nibobee = NIBObee
o-link = O-Link, OpenJTAG from www.100ask.net
openmoko = Openmoko debug board (v3)
pavr = Jason Kyle's pAVR Serial Programmer
pickit2 = MicroChip's PICkit2 Programmer
ponyser = design ponyprog serial, reset=!txd sck=rts mosi=dtr miso=cts
siprog = Lancos SI-Prog <http://www.lancos.com/siprogsch.html>
stk500 = Atmel STK500
stk500hvsp = Atmel STK500 V2 in high-voltage serial programming mode
stk500pp = Atmel STK500 V2 in parallel programming mode
stk500v1 = Atmel STK500 Version 1.x firmware
stk500v2 = Atmel STK500 Version 2.x firmware
stk600 = Atmel STK600
stk600hvsp = Atmel STK600 in high-voltage serial programming mode
stk600pp = Atmel STK600 in parallel programming mode
ttl232r = FTDI TTL232R-5V with ICSP adapter
tumpa = TIAO USB Multi-Protocol Adapter
UM232H = FT232H based module from FTDI and Glyn.com.au
uncompatino = uncompatino with all pairs of pins shorted
usbasp = USBasp, http://www.fischl.de/usbasp/
usbasp-clone = Any usbasp clone with correct VID/PID
usbtiny = USBtiny simple USB programmer, http://www.ladyada.net/make/usbtinyisp/
wiring = Wiring
xplainedmini = Atmel AVR XplainedMini in ISP mode
xplainedmini_dw = Atmel AVR XplainedMini in debugWIRE mode
xplainedpro = Atmel AVR XplainedPro in JTAG mode
*** [upload] Error 1
============================================================================= [FAILED] Took 0.40 seconds =============================================================================
* The terminal process "platformio 'run', '--target', 'upload'" terminated with exit code: 1.
If the problem is related to avrdude not being able to find programmer id “urclock”, I don’t know where to look first to solve it.
At this point I’m at a loss.
Any help or tips in pointing me in the right direction are much appreciated.
