I’m trying to upgrade my old library OpcServer from pio v2 to pio v3 and I’m not sure of the “correct” way to do some things.
I use travis-ci to test my builds, previously to test different platforms (atmelsam, espressif8266, and now adding espressif32). I was defining these in a platformio.ini file and then using:
platformio ci --lib="." --project-conf="platformio.ini"
However I’m not sure if I should instead be just using multiple commands and specifying the different configs to platformio ci
instead like:
platformio ci --lib="." --board zero
platformio ci --lib="." --board nodemcuv2
… etc
I took a look at a few other libraries out there and I didn’t see anyone else using a platformio.ini
file so I feel like I’m doing something wrong. Also keeping it in the project root folder is misleading as pio build
will now fail in v3 due to missing setup() and loop() (since its just a library, although I think build used to work in v2?)
The other issue I had previously is the zero board requires some additional libraries (WiFi101
and Adafruit CC3000 Library
) and I would have to manually ignore those libraries for the other platforms as just having them installed would cause the build to fail.
Do I include these dependent libraries in my library.json
? Honestly I’m considering just removing support for zero from my build because I don’t even know who is using it (I just added it for completeness). Rather than having to deal with those libraries making it complicated.
Any guidance would be appreciated! Thanks!
