Hi, I am very new to this software and was trying out a mini project by uploading and monitoring a code on PlatformIO IDE on to a LilyGo-TTGo-HiGrow sensor, but i keep getting two problems that I don’t know how to solve. Before i display the errors, i want to point out some things that might be the causes of this: i am putting my WIFI and WIFI password exactly as i do when i try to connect my phone for example, is that right? Also, i downloaded the MQTT add-on on Home Assistant and am using the same broker name, username, and password for the code on PlatformIO, is that also right (my broker name is core-mosquitto and i have a feeling it has to be in the form of an IP address all numbers, but I’m also not sure)?
This is the error I’m getting:
Error Message: ‘void adc_power_off()’ is deprecated [-Wdeprecated-declarations]
Full Error Message:
void goToDeepSleep()
Serial.print("Going to sleep... ");
Serial.print(TIME_TO_SLEEP);
Serial.println(" seconds");
if (logging) {
writeFile(SPIFFS, "/error.log", "Going to sleep for 10800 seconds \n");
WiFi.disconnect(true);
WiFi.mode(WIFI_OFF);
btStop();
// Configure the timer to wake us up!
esp_sleep_enable_timer_wakeup(TIME_TO_SLEEP * uS_TO_S_FACTOR);
// Testpurposes
//esp_sleep_enable_timer_wakeup(10 * uS_TO_S_FACTOR);
if (logging)
writeFile(SPIFFS, "/error.log", "Going to deep sleep \n \n \n");
// Go to sleep! Zzzz
esp_deep_sleep_start();
void goToDeepSleepFiveMinutes()
Serial.print("300");
Serial.println(" sekunder");
if (logging) {
writeFile(SPIFFS, "/error.log", "Going to sleep for 300 seconds \n");
btStop();
adc_power_off();
esp_wifi_stop();
esp_bt_controller_disable();
++sleep5no;
esp_sleep_enable_timer_wakeup(300 * uS_TO_S_FACTOR);
Error Message 2: ‘void adc_power_off()’ is deprecated [-Wdeprecated-declarations]
Full Error Message 2:
if (logging) {
btStop();
// Testpurposes
if (logging)
if (logging) {
btStop();
adc_power_off();
esp_wifi_stop();
++sleep5no;
For further info, this is the terminal when i try to upload and monitor:
> Executing task: C:\Users\Imad\.platformio\penv\Scripts\platformio.exe run --target upload --target monitor --environment esp32dev <
PLATFORM: Espressif 32 (3.4.0) > Espressif ESP32 Dev Module
- framework-arduinoespressif32 3.10006.210326 (1.0.6)
- tool-esptoolpy 1.30100.210531 (3.1.0)
- toolchain-xtensa32 2.50200.97 (5.2.0)
Found 38 compatible libraries
|-- <ArduinoJson> 6.17.0
|-- <ArduinoHttpClient> 0.4.0
|-- <esp32_ftpclient> 0.1.3
| |-- <WiFi> 1.0
|-- <BH1750> 1.1.4
| |-- <Wire> 1.0.1
|-- <Adafruit Unified Sensor> 1.1.4
|-- <DHT sensor library> 1.4.0
|-- <SPIFFS> 1.0
| |-- <FS> 1.0
|-- <Adafruit BME280 Library> 2.1.2
| |-- <SPI> 1.0
| |-- <Wire> 1.0.1
|-- <NTPClient> 3.1.0
|-- <PubSubClient> 2.8.0
|-- <SD(esp32)> 1.0.5
| |-- <FS> 1.0
| |-- <SPI> 1.0
|-- <SPI> 1.0
|-- <Time> 1.6
|-- <WiFi> 1.0
|-- <Wire> 1.0.1
Compiling .pio\build\esp32dev\src\main.cpp.o
Generating partitions .pio\build\esp32dev\partitions.bin
Compiling .pio\build\esp32dev\libe2b\ArduinoHttpClient\HttpClient.cpp.o
Compiling .pio\build\esp32dev\libe2b\ArduinoHttpClient\URLEncoder.cpp.o
Compiling .pio\build\esp32dev\libe2b\ArduinoHttpClient\WebSocketClient.cpp.o
Compiling .pio\build\esp32dev\libe2b\ArduinoHttpClient\b64.cpp.o
Compiling .pio\build\esp32dev\lib67e\WiFi\ETH.cpp.o
Compiling .pio\build\esp32dev\lib67e\WiFi\WiFi.cpp.o
Compiling .pio\build\esp32dev\lib67e\WiFi\WiFiAP.cpp.o
Compiling .pio\build\esp32dev\lib67e\WiFi\WiFiClient.cpp.o
.pio\libdeps\esp32dev\ArduinoHttpClient\src\HttpClient.cpp: In member function 'int HttpClient::startRequest(const char*, const char*, const char*, int, const byte*)':
.pio\libdeps\esp32dev\ArduinoHttpClient\src\HttpClient.cpp:87:61: warning: logical not is only applied to the left hand side of comparison [-Wlogical-not-parentheses]
if (!iClient->connect(iServerName, iServerPort) > 0)
.pio\libdeps\esp32dev\ArduinoHttpClient\src\HttpClient.cpp:97:64: warning: logical not is only applied to the left hand side of comparison [-Wlogical-not-parentheses]
if (!iClient->connect(iServerAddress, iServerPort) > 0)
Compiling .pio\build\esp32dev\lib67e\WiFi\WiFiGeneric.cpp.o
Compiling .pio\build\esp32dev\lib67e\WiFi\WiFiMulti.cpp.o
Archiving .pio\build\esp32dev\libe2b\libArduinoHttpClient.a
Compiling .pio\build\esp32dev\lib67e\WiFi\WiFiSTA.cpp.o
In file included from src\main.cpp:121:0:
src/go-to-deep-sleep.h: In function 'void goToDeepSleepFiveMinutes()':
src/go-to-deep-sleep.h:41:3: warning: 'void adc_power_off()' is deprecated [-Wdeprecated-declarations]
adc_power_off();
In file included from src\main.cpp:15:0:
C:\Users\Imad\.platformio\packages\framework-arduinoespressif32\tools\sdk\include\driver/driver/adc.h:242:6: note: declared here
void adc_power_off(void) __attribute__((deprecated));
adc_power_off();
src/go-to-deep-sleep.h:41:17: warning: 'void adc_power_off()' is deprecated [-Wdeprecated-declarations]
adc_power_off();
Compiling .pio\build\esp32dev\lib67e\WiFi\WiFiScan.cpp.o
Compiling .pio\build\esp32dev\lib67e\WiFi\WiFiServer.cpp.o
Compiling .pio\build\esp32dev\lib67e\WiFi\WiFiUdp.cpp.o
Compiling .pio\build\esp32dev\libfb1\esp32_ftpclient\ESP32_FTPClient.cpp.o
Compiling .pio\build\esp32dev\libe43\Wire\Wire.cpp.o
Compiling .pio\build\esp32dev\libc07\BH1750\BH1750.cpp.o
Compiling .pio\build\esp32dev\lib874\Adafruit Unified Sensor\Adafruit_Sensor.cpp.o
Archiving .pio\build\esp32dev\lib67e\libWiFi.a
Compiling .pio\build\esp32dev\lib226\DHT sensor library\DHT.cpp.o
Compiling .pio\build\esp32dev\lib226\DHT sensor library\DHT_U.cpp.o
Compiling .pio\build\esp32dev\lib176\FS\FS.cpp.o
Compiling .pio\build\esp32dev\lib176\FS\vfs_api.cpp.o
Archiving .pio\build\esp32dev\libfb1\libesp32_ftpclient.a
Compiling .pio\build\esp32dev\lib4d8\SPIFFS\SPIFFS.cpp.o
Archiving .pio\build\esp32dev\libe43\libWire.a
Archiving .pio\build\esp32dev\libc07\libBH1750.a
Compiling .pio\build\esp32dev\lib15a\SPI\SPI.cpp.o
Compiling .pio\build\esp32dev\libea6\Adafruit_BME280_Library\Adafruit_BME280.cpp.o
Archiving .pio\build\esp32dev\lib874\libAdafruit Unified Sensor.a
Compiling .pio\build\esp32dev\libd32\NTPClient\NTPClient.cpp.o
Archiving .pio\build\esp32dev\lib15a\libSPI.a
Archiving .pio\build\esp32dev\lib226\libDHT sensor library.a
Compiling .pio\build\esp32dev\libbf9\PubSubClient\PubSubClient.cpp.o
Compiling .pio\build\esp32dev\lib6fb\SD\SD.cpp.o
Compiling .pio\build\esp32dev\lib6fb\SD\sd_diskio.cpp.o
Compiling .pio\build\esp32dev\lib6fb\SD\sd_diskio_crc.c.o
Archiving .pio\build\esp32dev\lib176\libFS.a
Archiving .pio\build\esp32dev\lib4d8\libSPIFFS.a
Compiling .pio\build\esp32dev\lib956\TimeLib\DateStrings.cpp.o
Compiling .pio\build\esp32dev\lib956\TimeLib\Time.cpp.o
Archiving .pio\build\esp32dev\libFrameworkArduinoVariant.a
Compiling .pio\build\esp32dev\FrameworkArduino\Esp.cpp.o
Archiving .pio\build\esp32dev\libea6\libAdafruit_BME280_Library.a
Archiving .pio\build\esp32dev\libd32\libNTPClient.a
Compiling .pio\build\esp32dev\FrameworkArduino\FunctionalInterrupt.cpp.o
Compiling .pio\build\esp32dev\FrameworkArduino\HardwareSerial.cpp.o
Archiving .pio\build\esp32dev\libbf9\libPubSubClient.a
Compiling .pio\build\esp32dev\FrameworkArduino\IPAddress.cpp.o
Compiling .pio\build\esp32dev\FrameworkArduino\IPv6Address.cpp.o
Archiving .pio\build\esp32dev\lib6fb\libSD.a
Compiling .pio\build\esp32dev\FrameworkArduino\MD5Builder.cpp.o
Compiling .pio\build\esp32dev\FrameworkArduino\Print.cpp.o
Archiving .pio\build\esp32dev\lib956\libTimeLib.a
Compiling .pio\build\esp32dev\FrameworkArduino\Stream.cpp.o
Compiling .pio\build\esp32dev\FrameworkArduino\StreamString.cpp.o
Compiling .pio\build\esp32dev\FrameworkArduino\WMath.cpp.o
Compiling .pio\build\esp32dev\FrameworkArduino\WString.cpp.o
Compiling .pio\build\esp32dev\FrameworkArduino\base64.cpp.o
Compiling .pio\build\esp32dev\FrameworkArduino\cbuf.cpp.o
Compiling .pio\build\esp32dev\FrameworkArduino\esp32-hal-adc.c.o
Compiling .pio\build\esp32dev\FrameworkArduino\esp32-hal-bt.c.o
Compiling .pio\build\esp32dev\FrameworkArduino\esp32-hal-cpu.c.o
Compiling .pio\build\esp32dev\FrameworkArduino\esp32-hal-dac.c.o
Compiling .pio\build\esp32dev\FrameworkArduino\esp32-hal-gpio.c.o
Compiling .pio\build\esp32dev\FrameworkArduino\esp32-hal-i2c.c.o
Compiling .pio\build\esp32dev\FrameworkArduino\esp32-hal-ledc.c.o
Compiling .pio\build\esp32dev\FrameworkArduino\esp32-hal-log.c.o
Compiling .pio\build\esp32dev\FrameworkArduino\esp32-hal-matrix.c.o
Compiling .pio\build\esp32dev\FrameworkArduino\esp32-hal-misc.c.o
Compiling .pio\build\esp32dev\FrameworkArduino\esp32-hal-psram.c.o
Compiling .pio\build\esp32dev\FrameworkArduino\esp32-hal-rmt.c.o
Compiling .pio\build\esp32dev\FrameworkArduino\esp32-hal-sigmadelta.c.o
Compiling .pio\build\esp32dev\FrameworkArduino\esp32-hal-spi.c.o
Compiling .pio\build\esp32dev\FrameworkArduino\esp32-hal-time.c.o
Compiling .pio\build\esp32dev\FrameworkArduino\esp32-hal-timer.c.o
Compiling .pio\build\esp32dev\FrameworkArduino\esp32-hal-touch.c.o
Compiling .pio\build\esp32dev\FrameworkArduino\esp32-hal-uart.c.o
C:\Users\Imad\.platformio\packages\framework-arduinoespressif32\cores\esp32\esp32-hal-spi.c: In function 'spiTransferBytesNL':
C:\Users\Imad\.platformio\packages\framework-arduinoespressif32\cores\esp32\esp32-hal-spi.c:922:39: warning: initialization from incompatible pointer type [-Wincompatible-pointer-types]
uint8_t * last_out8 = &result[c_longs-1];
C:\Users\Imad\.platformio\packages\framework-arduinoespressif32\cores\esp32\esp32-hal-spi.c:923:40: warning: initialization from incompatible pointer type [-Wincompatible-pointer-types]
uint8_t * last_data8 = &last_data;
Compiling .pio\build\esp32dev\FrameworkArduino\libb64\cdecode.c.o
Compiling .pio\build\esp32dev\FrameworkArduino\libb64\cencode.c.o
Compiling .pio\build\esp32dev\FrameworkArduino\main.cpp.o
Compiling .pio\build\esp32dev\FrameworkArduino\stdlib_noniso.c.o
Compiling .pio\build\esp32dev\FrameworkArduino\wiring_pulse.c.o
Compiling .pio\build\esp32dev\FrameworkArduino\wiring_shift.c.o
Archiving .pio\build\esp32dev\libFrameworkArduino.a
Linking .pio\build\esp32dev\firmware.elf
Retrieving maximum program size .pio\build\esp32dev\firmware.elf
Checking size .pio\build\esp32dev\firmware.elf
RAM: [= ] 13.2% (used 43316 bytes from 327680 bytes)
Flash: [======= ] 69.9% (used 916182 bytes from 1310720 bytes)
Building .pio\build\esp32dev\firmware.bin
esptool.py v3.1
Merged 1 ELF section
AVAILABLE: esp-prog, espota, esptool, iot-bus-jtag, jlink, minimodule, olimex-arm-usb-ocd, olimex-arm-usb-ocd-h, olimex-arm-usb-tiny-h, olimex-jtag-tiny, tumpa
Looking for upload port...
Auto-detected: COM3
Uploading .pio\build\esp32dev\firmware.bin
esptool.py v3.1
Serial port COM3
Connecting........__
Chip is ESP32-D0WDQ6 (revision 1)
Features: WiFi, BT, Dual Core, 240MHz, VRef calibration in efuse, Coding Scheme None
Crystal is 40MHz
MAC: fc:f5:c4:0c:fb:c0
Uploading stub...
Running stub...
Stub running...
Changing baud rate to 460800
Changed.
Configuring flash size...
Auto-detected Flash size: 4MB
Flash will be erased from 0x00001000 to 0x00005fff...
Flash will be erased from 0x00010000 to 0x000effff...
Compressed 17104 bytes to 11191...
Writing at 0x00001000... (100 %)
Wrote 17104 bytes (11191 compressed) at 0x00001000 in 0.6 seconds (effective 241.6 kbit/s)...
Hash of data verified.
Compressed 3072 bytes to 128...
Wrote 3072 bytes (128 compressed) at 0x00008000 in 0.1 seconds (effective 350.8 kbit/s)...
Wrote 8192 bytes (47 compressed) at 0x0000e000 in 0.1 seconds (effective 490.0 kbit/s)...
Compressed 916416 bytes to 536879...
Writing at 0x00010000... (3 %)
Writing at 0x0001b4bd... (6 %)
Writing at 0x000292de... (9 %)
Writing at 0x0004011d... (12 %)
Writing at 0x00045795... (15 %)
Writing at 0x0004b0b7... (18 %)
Writing at 0x00050235... (21 %)
Writing at 0x00055475... (24 %)
Writing at 0x0005a92b... (27 %)
Writing at 0x0005fdf9... (30 %)
Writing at 0x000654ea... (33 %)
Writing at 0x0006e741... (36 %)
Writing at 0x00074e2b... (39 %)
Writing at 0x0007a444... (42 %)
Writing at 0x0007fe94... (45 %)
Writing at 0x000850ca... (48 %)
Writing at 0x0008ac51... (51 %)
Writing at 0x00090c7c... (54 %)
Writing at 0x00096b34... (57 %)
Writing at 0x0009c567... (60 %)
Writing at 0x000a2063... (63 %)
Writing at 0x000a7c25... (66 %)
Writing at 0x000adb30... (69 %)
Writing at 0x000b42f6... (72 %)
Writing at 0x000ba066... (75 %)
Writing at 0x000c03bc... (78 %)
Writing at 0x000c620f... (81 %)
Writing at 0x000cbfe5... (84 %)
Writing at 0x000d1fd4... (87 %)
Writing at 0x000d9c54... (90 %)
Writing at 0x000df805... (93 %)
Writing at 0x000e4dcb... (96 %)
Writing at 0x000eac75... (100 %)
Wrote 916416 bytes (536879 compressed) at 0x00010000 in 13.3 seconds (effective 549.7 kbit/s)...
Leaving...
Hard resetting via RTS pin...
========================================================================================= [SUCCESS] Took 68.89 seconds =========================================================================================
--- Available filters and text transformations: colorize, debug, default, direct, esp32_exception_decoder, hexlify, log2file, nocontrol, printable, send_on_enter, time
--- More details at https://bit.ly/pio-monitor-filters
--- Miniterm on COM3 115200,8,N,1 ---
ets Jun 8 2016 00:22:57
rst:0x1 (POWERON_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
mode:DIO, clock div:2
load:0x3fff0018,len:4
load:0x3fff001c,len:1044
load:0x40078000,len:10124
load:0x40080400,len:5828
entry 0x400806a8
Void Setup
Listing directory: /
- failed to open file for reading
Here comes the calibration info:
Here comes the name info:
Here comes the charge date info info:
Size of SSID array 1
SSID name: FRITZ!BOX7490.............................................................
....................we should break
Going to sleep... 300 sekunder
I hope anyone can help me, I would really appreciate that!
