Hi, I have worked on a project for a few days and this started happening… Is it due to a failed chip?? Is there something I can do software related? My platform.ini config was working great before. On the last upload, my TFT screen on my project started printing white noise D:
[env:ATmega328P]
board = ATmega328P
upload_protocol = atmelice_isp
upload_flags = -e
upload_port = usb
; do not forget to run burn fuse task if changing values
board_fuses.hfuse = 0xDF ;smallest flash section size 256 since not using a bootloader with ICE programmer
board_fuses.lfuse = 0xE2 ;int 8MHz crystal (16MHz not working with less than 5V PSU)
board_fuses.efuse = 0xFE ;BOD at 1.8V, perfect for low power
adafruit/Adafruit ST7735 and ST7789 Library@^1.6.0
adafruit/Adafruit BusIO@^1.5.0
adafruit/RTClib@^1.11.3
;adafruit/DHT sensor library@^1.4.0
adafruit/RTClib@^1.12.1
Now the problem when uploading:
RAM: [==== ] 39.0% (used 799 bytes from 2048 bytes)
Flash: [===== ] 51.6% (used 16630 bytes from 32256 bytes)
AVAILABLE: atmelice_isp
CURRENT: upload_protocol = atmelice_isp
Looking for upload port...
Use manually specified: usb
Uploading .pio\build\ATmega328P\firmware.hex
avrdude: Device signature = 0x1e950f (probably m328p)
avrdude: erasing chip
avrdude: reading input file ".pio\build\ATmega328P\firmware.hex"
avrdude: writing flash (16630 bytes):
Writing | ################################################## | 100% 4.77s
avrdude: 16630 bytes of flash written
avrdude: verifying flash memory against .pio\build\ATmega328P\firmware.hex:
avrdude: load data flash data from input file .pio\build\ATmega328P\firmware.hex:
avrdude: input file .pio\build\ATmega328P\firmware.hex contains 16630 bytes
Reading | ################################################## | 100% 4.73s
avrdude: verifying ...
avrdude: verification error, first mismatch at byte 0x0000
0x91 != 0x0c
avrdude: verification error; content mismatch
avrdude: safemode: Verify error - unable to read lfuse properly. Programmer may not be reliable.
avrdude: safemode: Sorry, reading back fuses was unreliable. I have given up and exited programming mode
avrdude done. Thank you.
*** [upload] Error 1
==================================================================== [FAILED] Took 14.03 seconds ====================================================================
