Unnecessary double quotes with upload_flags
for some reason platformio adds quotes, what produces errors.
platformio.ini:
upload_flags =
    -c hla_serial 003600183438511034313939
this is how pio resolves this
openocd "-c hla_serial 003600183438511034313939" -d2 -s /Users/xx/.platformio/packages/tool-openocd/scripts -f board/st_nucleo_h743zi.cfg -c "program {.pio/build/brain_node/firmware.elf} verify reset; shutdown;"
and this is the error:
invalid command name "hla_serial"
to put quotes also dont help:
-c "hla_serial 003600183438511034313939"
xPack OpenOCD, x86_64 Open On-Chip Debugger 0.10.0+dev-00378-ge5be992df (2020-06-26-12:31)
tool-openocd 2.1000.200630
toolchain-gccarmnoneeabi 1.90201.191206 (9.2.1)
PlatformIO Core, version 5.2.0
With Regards
Ivan
Kinda solved myself. It should be written following way.
Instead of:
upload_flags =
    -c hla_serial 274E0C0011145157544D4E00
Should be:
upload_flags =
    -c
now the command is properly shaped:
openocd -c "hla_serial 274E0C0011145157544D4E00" -d2 ...
very fragile syntax…
