Something has happen in my environment so that I no longer see the output from Serial.print when running Unity tests. I did used to see it, and it still is shown when using the -v verbose option but with verbose there is tons of other output too and it makes things really slow.
Any idea what could have happened or how to get it back?
I’m on PlatformIO Core, version 6.0.1.
I think thats new and before it was version 5 something, could that be related?
Do you have the project to reproduce that?
In an empty dir do pio init, add platformio.ini with:
[env:arduino-esp32]
board = m5stack-core2
and in the test folder a test_main.cpp:
#include <unity.h>
delay(2000);
UNITY_BEGIN();
Serial.println("hello");
UNITY_END();
then pio test gives:
pio test
Collected 1 tests
Processing * in arduino-esp32 environment
Building...
Uploading...
Testing...
If you don't see any output for the first 10 secs, please reset board (press reset button)
------------------------------------- arduino-esp32:* [PASSED] Took 14.54 seconds -------------------------------------
====================================== 0 test cases: 0 succeeded in 00:00:14.544 ======================================
whereas pio test -v shows the “hello”:
pio test -v
Collected 1 tests (*)
Building...
FILESYSTEM spiffs
CONFIGURATION: https://docs.platformio.org/page/boards/espressif32/m5stack-core2.html
PLATFORM: Espressif 32 (2.0.3) (https://github.com/Jason2866/platform-espressif32/releases/download/v2.0.3-rc1/platform-espressif32-2.0.3-rc1.zip) > M5Stack Core2
HARDWARE: ESP32 240MHz, 4.31MB RAM, 16MB Flash
- framework-arduinoespressif32 @ 2.0.3 (https://github.com/Jason2866/platform-espressif32/releases/download/v2.0.3-rc1/esp32-2.0.3-RC1.zip)
- tool-esptoolpy @ 1.30300.220323 (3.3.0, https://github.com/tasmota/esptool/releases/download/v3.3/esptool-3.3.zip)
Found 33 compatible libraries
|-- Unity @ 2.5.2 (License: MIT, Path: C:\CQ\unitytest\.pio\libdeps\arduino-esp32\Unity)
Building in test mode
<lambda>(["checkprogsize"], [".pio\build\arduino-esp32\firmware.elf"])
MethodWrapper(["checkprogsize"], [".pio\build\arduino-esp32\firmware.elf"])
RAM: [ ] 0.4% (used 16632 bytes from 4521984 bytes)
Flash: [== ] 18.9% (used 248213 bytes from 1310720 bytes)
.pio\build\arduino-esp32\firmware.elf :
section size addr
.rtc.text 0 1074528256
.rtc.dummy 0 1073217536
.rtc.force_fast 0 1073217536
.rtc.data 16 1342177792
.rtc_noinit 0 1342177808
.rtc.force_slow 0 1342177808
.iram0.vectors 1027 1074266112
.iram0.text 59171 1074267140
.dram0.data 13664 1073470304
.ext_ram_noinit 0 1065353216
.noinit 0 1073483968
.ext_ram.bss 0 1065353216
.dram0.bss 2968 1073483968
.flash.appdesc 256 1061158944
.flash.rodata 52592 1061159200
.flash.rodata_noload 0 1061211792
.flash.text 121759 1074593824
.iram0.text_end 1 1074326311
.iram0.data 0 1074326312
.iram0.bss 0 1074326312
.dram0.heap_start 0 1073486936
.xtensa.info 56 0
.comment 166 0
.xt.lit._ZNKSt8functionIFv22hardwareSerial_error_tEEclES0_ 0 0
.xt.prop._ZNKSt8functionIFv22hardwareSerial_error_tEEclES0_ 48 0
.xt.prop._ZN6Stream9readBytesEPhj 36 0
.xt.prop._ZNSt14_Function_baseD2Ev 36 0
.xt.prop._ZTV14HardwareSerial 12 0
.xt.lit._ZN9IPAddressD5Ev 0 0
.xt.prop._ZN9IPAddressD5Ev 0 0
.xt.prop._ZN9IPAddressD2Ev 36 0
.xt.prop._ZN9IPAddressD0Ev 36 0
.xt.prop._ZTV9IPAddress 12 0
.xt.lit._ZN5Print5writeEPKc 0 0
.xt.prop._ZN5Print5writeEPKc 48 0
.xt.lit._ZN6String4initEv 0 0
.xt.prop._ZN6String4initEv 36 0
.xt.prop._ZNK6String3lenEv 60 0
.xt.prop._ZN6String6setLenEi 72 0
.xt.lit._ZN3nvs4Lock4initEv 0 0
.xt.prop._ZN3nvs4Lock4initEv 72 0
.xt.lit._ZN14intrusive_listIN3nvs7Storage14NamespaceEntryEE17clearAndFreeNodesEv 0 0
.xt.lit._ZN19CompressedEnumTableIbLj1ELj256EE3setEjb 8 0
.xt.prop._ZN14intrusive_listIN3nvs7Storage14NamespaceEntryEE17clearAndFreeNodesEv 108 0
.xt.prop._ZN19CompressedEnumTableIbLj1ELj256EE3setEjb 60 0
.xt.prop._ZN14intrusive_listIN3nvs7Storage14NamespaceEntryEE9push_backEPS2_ 60 0
.xt.lit._ZN3nvs12NVSPartitionD5Ev 0 0
.xt.prop._ZN3nvs12NVSPartitionD5Ev 0 0
.xt.prop._ZN3nvs12NVSPartitionD2Ev 36 0
.xt.prop._ZN3nvs12NVSPartitionD0Ev 36 0
.xt.prop._ZTVN3nvs12NVSPartitionE 12 0
.xt.lit._ZN3nvs19NVSPartitionManagerD5Ev 0 0
.xt.prop._ZN3nvs19NVSPartitionManagerD5Ev 0 0
.xt.prop._ZN3nvs19NVSPartitionManagerD2Ev 36 0
.xt.prop._ZN3nvs19NVSPartitionManagerD0Ev 36 0
.xt.prop._ZN14intrusive_listIN3nvs12NVSPartitionEE5eraseENS2_8iteratorE 84 0
.xt.prop._ZTVN3nvs19NVSPartitionManagerE 12 0
.xt.prop._ZN14intrusive_listIN3nvs8HashList13HashListBlockEE5eraseENS3_8iteratorE 84 0
.xt.lit._ZN3nvs4ItemC5EhNS_8ItemTypeEhPKch 0 0
.xt.lit._ZNK19CompressedEnumTableIN3nvs4Page10EntryStateELj2ELj126EE3getEj 8 0
.xt.lit._ZN19CompressedEnumTableIN3nvs4Page10EntryStateELj2ELj126EE3setEjS2_ 8 0
.xt.prop._ZN3nvs4ItemC5EhNS_8ItemTypeEhPKch 0 0
.xt.prop._ZNK19CompressedEnumTableIN3nvs4Page10EntryStateELj2ELj126EE3getEj 60 0
.xt.prop._ZN19CompressedEnumTableIN3nvs4Page10EntryStateELj2ELj126EE3setEjS2_ 60 0
.xt.prop._ZN3nvs20isVariableLengthTypeENS_8ItemTypeE 48 0
.xt.prop._ZN3nvs4ItemC2EhNS_8ItemTypeEhPKch 60 0
.xt.lit._ZN14intrusive_listIN3nvs4PageEE5clearEv 0 0
.xt.prop._ZN14intrusive_listIN3nvs4PageEE5clearEv 60 0
.xt.prop._ZN14intrusive_listIN3nvs4PageEE9push_backEPS1_ 60 0
.xt.prop._ZN14intrusive_listIN3nvs4PageEE5eraseENS2_8iteratorE 84 0
.xt.prop._ZTISt9exception 12 0
.xt.prop._ZTISt9bad_alloc 12 0
.xt.prop._ZTVN10__cxxabiv117__class_type_infoE 12 0
.xt.prop._ZTVN10__cxxabiv120__si_class_type_infoE 12 0
.xt.prop._ZTISt17bad_function_call 12 0
.xt.prop._ZTVSt17bad_function_call 12 0
.xt.lit._ZNK9__gnu_cxx24__concurrence_lock_error4whatEv 8 0
.xt.lit._ZNK9__gnu_cxx26__concurrence_unlock_error4whatEv 8 0
.xt.lit._ZN9__gnu_cxx24__concurrence_lock_errorD5Ev 8 0
.xt.lit._ZN9__gnu_cxx26__concurrence_unlock_errorD5Ev 8 0
.xt.lit._ZN9__gnu_cxx7__mutex4lockEv 8 0
.xt.lit._ZN9__gnu_cxx13__scoped_lockD5Ev 8 0
.xt.prop._ZNK9__gnu_cxx24__concurrence_lock_error4whatEv 48 0
.xt.prop._ZNK9__gnu_cxx26__concurrence_unlock_error4whatEv 48 0
.xt.prop._ZN9__gnu_cxx24__concurrence_lock_errorD5Ev 12 0
.xt.prop._ZN9__gnu_cxx26__concurrence_unlock_errorD5Ev 12 0
.xt.prop._ZN9__gnu_cxx7__mutex4lockEv 48 0
.xt.prop._ZN9__gnu_cxx13__scoped_lockD5Ev 12 0
.xt.prop._ZN9__gnu_cxx24__concurrence_lock_errorD2Ev 36 0
.xt.prop._ZN9__gnu_cxx26__concurrence_unlock_errorD2Ev 36 0
.xt.prop._ZN9__gnu_cxx24__concurrence_lock_errorD0Ev 36 0
.xt.prop._ZN9__gnu_cxx26__concurrence_unlock_errorD0Ev 36 0
.xt.prop._ZN9__gnu_cxx13__scoped_lockD2Ev 72 0
.xt.prop._ZTIN9__gnu_cxx24__concurrence_lock_errorE 12 0
.xt.prop._ZTIN9__gnu_cxx26__concurrence_unlock_errorE 12 0
.xt.prop._ZTVN9__gnu_cxx24__concurrence_lock_errorE 12 0
.xt.prop._ZTVN9__gnu_cxx26__concurrence_unlock_errorE 12 0
.debug_frame 60936 0
.debug_info 2923097 0
.debug_abbrev 251470 0
.debug_loc 443023 0
.debug_aranges 24312 0
.debug_ranges 60816 0
.debug_line 1134702 0
.debug_str 245411 0
Total 5397531
Uploading...
FILESYSTEM spiffs
section size addr
.xtensa.info 56 0
.comment 166 0
.debug_loc 443023 0
.debug_str 245411 0
Total 5397531
<lambda>(["upload"], [".pio\build\arduino-esp32\firmware.bin"])
AVAILABLE: esp-prog, espota, esptool, iot-bus-jtag, jlink, minimodule, olimex-arm-usb-ocd, olimex-arm-usb-ocd-h, olimex-arm-usb-tiny-h, olimex-jtag-tiny, tumpa
MethodWrapper(["upload"], [".pio\build\arduino-esp32\firmware.bin"])
Auto-detected: COM3
"C:\Users\tornt\.platformio\penv\Scripts\python.exe" "C:\Users\tornt\.platformio\packages\tool-esptoolpy\esptool.py" --chip esp32 --port "COM3" --baud 460800 --before default_reset --after hard_reset write_flash -z --flash_mode dio --flash_freq 40m --flash_size detect 0x1000 C:\Users\tornt\.platformio\packages\framework-arduinoespressif32\tools\sdk\esp32\bin\bootloader_dio_40m.bin 0x8000 C:\CQ\unitytest\.pio\build\arduino-esp32\partitions.bin 0xe000 C:\Users\tornt\.platformio\packages\framework-arduinoespressif32\tools\partitions\boot_app0.bin 0x10000 .pio\build\arduino-esp32\firmware.bin
esptool.py v3.3
Serial port COM3
Connecting......
Chip is ESP32-D0WDQ6-V3 (revision 3)
Features: WiFi, BT, Dual Core, 240MHz, VRef calibration in efuse, Coding Scheme None
Crystal is 40MHz
MAC: 24:0a:c4:f8:7e:ec
Uploading stub...
Running stub...
Stub running...
Changing baud rate to 460800
Changed.
Configuring flash size...
Auto-detected Flash size: 16MB
Flash will be erased from 0x00001000 to 0x00005fff...
Flash will be erased from 0x00010000 to 0x0004cfff...
Flash params set to 0x0240
Compressed 17088 bytes to 11848...
Writing at 0x00001000... (100 %)
Wrote 17088 bytes (11848 compressed) at 0x00001000 in 0.9 seconds (effective 156.7 kbit/s)...
Hash of data verified.
Compressed 3072 bytes to 128...
Wrote 3072 bytes (128 compressed) at 0x00008000 in 0.1 seconds (effective 224.3 kbit/s)...
Wrote 8192 bytes (47 compressed) at 0x0000e000 in 0.2 seconds (effective 327.1 kbit/s)...
Compressed 248608 bytes to 135646...
Writing at 0x00010000... (11 %)
Writing at 0x0001d119... (22 %)
Writing at 0x00024e2b... (33 %)
Writing at 0x0002a400... (44 %)
Writing at 0x0002f6f0... (55 %)
Writing at 0x00037bb6... (66 %)
Writing at 0x000402e5... (77 %)
Writing at 0x00045a40... (88 %)
Writing at 0x0004b1d3... (100 %)
Wrote 248608 bytes (135646 compressed) at 0x00010000 in 3.7 seconds (effective 532.3 kbit/s)...
Leaving...
Hard resetting via RTS pin...
Testing...
hello
0 Tests 0 Failures 0 Ignored
OK
------------------------------------- arduino-esp32:* [PASSED] Took 14.84 seconds -------------------------------------
======================================================= SUMMARY =======================================================
Environment Test Status Duration
arduino-esp32 * SKIPPED 00:00:14.836
====================================== 0 test cases: 0 succeeded in 00:00:14.836 ======================================
Reminds me of
Can you replace Serial.println("hello"); with TEST_MESSAGE("hello") and check if it appears in the regular pio test output?
No TEST_MESSAGE doesn’t show either, only when using -v.
If it worked in PIO core 5.x and the aim is to keep 100% compatibility with it in 6.x, then please file an issue at Issues · platformio/platformio-core · GitHub about this case.
