Unity library is missing?
I am trying to run a simple unit test but it fails because Unity.h is missing. If I add unity to my lib_dep, the test does work, but then my normal build fails.
Any suggestions? I had the impression that platformio is supposed to identify automatically the test’s dependency on Unity.
Platformio.ini:
[env:my_env]
build_type = debug
; build_type = release
platform = ststm32
; test_filter = serial_packets/test_serial_packets_client
; debug_test = serial_packets/test_serial_packets_client
test_filter = test_trivial
debug_test = test_trivial
extra_scripts = extra_script.py
board = my_genericSTM32H750VBT6
; Linker file is from cube ide.
board_build.ldscript = STM32H750VBTX_FLASH.ld
debug_tool = stlink
upload_protocol = stlink
; debug_build_flags = -O0 -ggdb3 -g3
; debug_build_flags = -Og -ggdb3 -g3
debug_build_flags = -Os -g3 -ggdb3
; debug_init_break = tbreak app_main
debug_init_break = tbreak none
test_framework = custom
; test_port = COM6
monitor_port = COM6
lib_archive = no
check_skip_packages = yes
  adc
  data_recorder
  host_link
  io
  misc
  printer_link
  controller
  cube_ide
  serial_packets
  system
  ; unity
  -fmax-errors=5
  -Werror
  -mfpu=fpv5-sp-d16
  -mfloat-abi=hard
  -Wl,-Map,${BUILD_DIR}/firmware.map
  -mthumb
  -D DEBUG
  -D USE_HAL_DRIVER
  -DSTM32_THREAD_SAFE_STRATEGY=4
  -fstack-usage
  -std=gnu11
  -Ilib/cube_ide/Core/Inc
  -Ilib/cube_ide/Core/ThreadSafe
  -Ilib/cube_ide/Drivers/CMSIS/Device/ST/STM32H7xx/Include
  -Ilib/cube_ide/Drivers/CMSIS/Include
  -Ilib/cube_ide/Drivers/STM32H7xx_HAL_Driver/Inc
  -Ilib/cube_ide/Middlewares/ST/STM32_USB_Device_Library/Class/CDC/Inc
  -Ilib/cube_ide/Middlewares/ST/STM32_USB_Device_Library/Core/Inc
  -Ilib/cube_ide/Middlewares/Third_Party/FreeRTOS/Source/CMSIS_RTOS
  -Ilib/cube_ide/Middlewares/Third_Party/FreeRTOS/Source/CMSIS_RTOS_V2/Include
  -Ilib/cube_ide/Middlewares/Third_Party/FreeRTOS/Source/include
  -Ilib/cube_ide/Middlewares/Third_Party/FreeRTOS/Source/portable/GCC/ARM_CM4F
  -Ilib/cube_ide/Middlewares/Third_Party/FatFs/src
  -Ilib/cube_ide/USB_DEVICE/App
  -Ilib/cube_ide/USB_DEVICE/Target
  -Ilib/cube_ide/FATFS/App
  -Ilib/cube_ide/FATFS/Target
  -D CONFIG_MAX_PACKET_DATA_LEN=1000
  -D CONFIG_MAX_PENDING_COMMANDS=5
test/test_trivial/test.cpp: (app_main() is called from main() in my startup file, which first stats FreeRTOS)
#include "Unity.h"
#include "time_util.h"
#include "io.h"
void setUp() {}
void tearDown() {}
void test_sample() { TEST_ASSERT_TRUE(true); }
void app_main() {
  // LEt the USB/Serial time to settle down.
  time_util::delay_millis(3000);
  UNITY_BEGIN();
  RUN_TEST(test_sample);
  UNITY_END();
  for (;;) {
    time_util::delay_millis(100);
    io::LED.toggle();
Test failure (lib_dep doesn’t contain Unity, running a verbose test after a Full Clean):
 *  Executing task: C:\Users\user\.platformio\penv\Scripts\platformio.exe test --verbose --environment my_env
Collected 10 tests (misc/test_static_string, misc/test_time_util, sd/test_rw, serial_packets/test_serial_packets_client, serial_packets/test_serial_packets_crc, serial_packets/test_serial_packets_data, serial_packets/test_serial_packets_decoder, serial_packets/test_serial_packets_encoder, test_sample, test_trivial)
Processing test_trivial in my_env environment
Building & Uploading...
test\test_trivial\test.cpp:1:10: fatal error: Unity.h: No such file or directory
* Looking for Unity.h dependency? Check our library registry!
* CLI  > platformio lib search "header:Unity.h"
* Web  > https://registry.platformio.org/search?q=header:Unity.h
 #include "Unity.h"
compilation terminated.
*** [.pio\build\my_env\test\test_trivial\test.o] Error 1
Uploading stage has failed, see errors above. Use `pio test -vvv` option to enable verbose output.
-------------------------------------------------------- my_env:test_trivial [ERRORED] Took 25.12 seconds --------------------------------------------------------
============================================================================ SUMMARY ============================================================================
Environment    Test                                        Status    Duration
my_env         misc/test_static_string                     SKIPPED
my_env         misc/test_time_util                         SKIPPED
my_env         sd/test_rw                                  SKIPPED
my_env         serial_packets/test_serial_packets_client   SKIPPED
my_env         serial_packets/test_serial_packets_crc      SKIPPED
my_env         serial_packets/test_serial_packets_data     SKIPPED
my_env         serial_packets/test_serial_packets_decoder  SKIPPED
my_env         serial_packets/test_serial_packets_encoder  SKIPPED
my_env         test_sample                                 SKIPPED
my_env         test_trivial                                ERRORED   00:00:25.125
=========================================================== 1 test cases: 0 succeeded in 00:00:25.125 ===========================================================
 *  The terminal process "C:\Users\user\.platformio\penv\Scripts\platformio.exe 'test', '--verbose', '--environment', 'my_env'" terminated with exit code: 1.
Successful test, when I include unity in platformio.ini lib_dep:
Licensed under GNU GPL v2
For bug reports, read
debug_level: 1
hla_swd
[stm32h7x.cpu0] halted due to debug-request, current mode: Thread
xPSR: 0x01000000 pc: 0x08001994 msp: 0x24080000
** Programming Started **
Warn : Adding extra erase range, 0x0800c560 .. 0x0801ffff
** Programming Finished **
** Verify Started **
** Verified OK **
** Resetting Target **
shutdown command invoked
Testing...
If you don't see any output for the first 10 secs, please reset board (press reset button)
I: Task Main started successfully
I: Task Logger started successfully
I: Serial USB started
I: &uxTopUsedPriority = 0x800c1b8
test\test_trivial\test.cpp:16:test_sample:PASS
1 Tests 0 Failures 0 Ignored
OK
-------------------------------------------------------- my_env:test_trivial [PASSED] Took 32.59 seconds --------------------------------------------------------
my_env         test_trivial                                PASSED    00:00:32.594
=========================================================== 1 test cases: 1 succeeded in 00:00:32.594 ===========================================================
And if I perform my normal build with unity listed in lib_dep I get this error:
 *  Executing task: C:\Users\user\.platformio\penv\Scripts\platformio.exe run
Processing my_env (platform: ststm32; board: my_genericSTM32H750VBT6)
-----------------------------------------------------------------------------------------------------------------------------------------------------------Verbose mode can be enabled via `-v, --verbose` option
CONFIGURATION: https://docs.platformio.org/page/boards/ststm32/my_genericSTM32H750VBT6.html
PLATFORM: ST STM32 (16.1.0) > STM32H750VBT6 (1024k RAM. 128k Flash)
HARDWARE: STM32H750VBT6 480MHz, 1MB RAM, 128KB Flash
DEBUG: Current (stlink) External (blackmagic, jlink, stlink)
 - toolchain-gccarmnoneeabi @ 1.70201.0 (7.2.1)
Found 11 compatible libraries
|-- adc
|-- data_recorder
|-- host_link
|-- io
|-- misc
|-- printer_link
|-- controller
|-- cube_ide
|-- serial_packets
|-- system
|-- Unity @ 2.5.2
Building in debug mode
Compiling .pio\build\my_env\lib50d\io\cdc_serial.o
Compiling .pio\build\my_env\lib50d\io\io.o
Compiling .pio\build\my_env\lib50d\io\serial.o
Compiling .pio\build\my_env\lib2be\misc\error_handler.o
Compiling .pio\build\my_env\lib2be\misc\logger.o
Compiling .pio\build\my_env\lib2be\misc\session.o
Compiling .pio\build\my_env\libee8\serial_packets\serial_packets_client.o
Compiling .pio\build\my_env\libee8\serial_packets\serial_packets_crc.o
Compiling .pio\build\my_env\libee8\serial_packets\serial_packets_decoder.o
Compiling .pio\build\my_env\libee8\serial_packets\serial_packets_encoder.o
Compiling .pio\build\my_env\libd5d\data_recorder\data_recorder.o
Compiling .pio\build\my_env\lib48e\host_link\host_link.o
Compiling .pio\build\my_env\lib4fd\controller\controller.o
Compiling .pio\build\my_env\lib465\adc\adc.o
Compiling .pio\build\my_env\lib9d9\printer_link\printer_link.o
Compiling .pio\build\my_env\libe47\cube_ide\Core\Src\dma.o
Compiling .pio\build\my_env\libe47\cube_ide\Core\Src\freertos.o
Compiling .pio\build\my_env\libe47\cube_ide\Core\Src\gpio.o
Compiling .pio\build\my_env\libe47\cube_ide\Core\Src\main.o
Compiling .pio\build\my_env\libe47\cube_ide\Core\Src\rng.o
Compiling .pio\build\my_env\libe47\cube_ide\Core\Src\sdmmc.o
Compiling .pio\build\my_env\libe47\cube_ide\Core\Src\spi.o
Compiling .pio\build\my_env\libe47\cube_ide\Core\Src\stm32h7xx_hal_msp.o
Compiling .pio\build\my_env\libe47\cube_ide\Core\Src\stm32h7xx_it.o
Compiling .pio\build\my_env\libe47\cube_ide\Core\Src\syscalls.o
Compiling .pio\build\my_env\libe47\cube_ide\Core\Src\sysmem.o
Compiling .pio\build\my_env\libe47\cube_ide\Core\Src\system_stm32h7xx.o
Compiling .pio\build\my_env\libe47\cube_ide\Core\Src\tim.o
Compiling .pio\build\my_env\libe47\cube_ide\Core\Src\usart.o
Compiling .pio\build\my_env\libe47\cube_ide\Core\Startup\startup_stm32h750vbtx.o
Compiling .pio\build\my_env\libe47\cube_ide\Core\ThreadSafe\newlib_lock_glue.o
Compiling .pio\build\my_env\libe47\cube_ide\Drivers\STM32H7xx_HAL_Driver\Src\stm32h7xx_hal.o
Compiling .pio\build\my_env\libe47\cube_ide\Drivers\STM32H7xx_HAL_Driver\Src\stm32h7xx_hal_cortex.o
Compiling .pio\build\my_env\libe47\cube_ide\Drivers\STM32H7xx_HAL_Driver\Src\stm32h7xx_hal_dma.o
Compiling .pio\build\my_env\libe47\cube_ide\Drivers\STM32H7xx_HAL_Driver\Src\stm32h7xx_hal_dma_ex.o
Compiling .pio\build\my_env\libe47\cube_ide\Drivers\STM32H7xx_HAL_Driver\Src\stm32h7xx_hal_exti.o
Compiling .pio\build\my_env\libe47\cube_ide\Drivers\STM32H7xx_HAL_Driver\Src\stm32h7xx_hal_flash.o
Compiling .pio\build\my_env\libe47\cube_ide\Drivers\STM32H7xx_HAL_Driver\Src\stm32h7xx_hal_flash_ex.o
Compiling .pio\build\my_env\libe47\cube_ide\Drivers\STM32H7xx_HAL_Driver\Src\stm32h7xx_hal_gpio.o
Compiling .pio\build\my_env\libe47\cube_ide\Drivers\STM32H7xx_HAL_Driver\Src\stm32h7xx_hal_hsem.o
Compiling .pio\build\my_env\libe47\cube_ide\Drivers\STM32H7xx_HAL_Driver\Src\stm32h7xx_hal_i2c.o
Compiling .pio\build\my_env\libe47\cube_ide\Drivers\STM32H7xx_HAL_Driver\Src\stm32h7xx_hal_i2c_ex.o
Compiling .pio\build\my_env\libe47\cube_ide\Drivers\STM32H7xx_HAL_Driver\Src\stm32h7xx_hal_mdma.o
Compiling .pio\build\my_env\libe47\cube_ide\Drivers\STM32H7xx_HAL_Driver\Src\stm32h7xx_hal_pcd.o
Compiling .pio\build\my_env\libe47\cube_ide\Drivers\STM32H7xx_HAL_Driver\Src\stm32h7xx_hal_pcd_ex.o
Compiling .pio\build\my_env\libe47\cube_ide\Drivers\STM32H7xx_HAL_Driver\Src\stm32h7xx_hal_pwr.o
Compiling .pio\build\my_env\libe47\cube_ide\Drivers\STM32H7xx_HAL_Driver\Src\stm32h7xx_hal_pwr_ex.o
Compiling .pio\build\my_env\libe47\cube_ide\Drivers\STM32H7xx_HAL_Driver\Src\stm32h7xx_hal_rcc.o
Compiling .pio\build\my_env\libe47\cube_ide\Drivers\STM32H7xx_HAL_Driver\Src\stm32h7xx_hal_rcc_ex.o
Compiling .pio\build\my_env\libe47\cube_ide\Drivers\STM32H7xx_HAL_Driver\Src\stm32h7xx_hal_rng.o
Compiling .pio\build\my_env\libe47\cube_ide\Drivers\STM32H7xx_HAL_Driver\Src\stm32h7xx_hal_rng_ex.o
Compiling .pio\build\my_env\libe47\cube_ide\Drivers\STM32H7xx_HAL_Driver\Src\stm32h7xx_hal_sd.o
Compiling .pio\build\my_env\libe47\cube_ide\Drivers\STM32H7xx_HAL_Driver\Src\stm32h7xx_hal_sd_ex.o
Compiling .pio\build\my_env\libe47\cube_ide\Drivers\STM32H7xx_HAL_Driver\Src\stm32h7xx_hal_spi.o
Compiling .pio\build\my_env\libe47\cube_ide\Drivers\STM32H7xx_HAL_Driver\Src\stm32h7xx_hal_spi_ex.o
Compiling .pio\build\my_env\libe47\cube_ide\Drivers\STM32H7xx_HAL_Driver\Src\stm32h7xx_hal_tim.o
Compiling .pio\build\my_env\libe47\cube_ide\Drivers\STM32H7xx_HAL_Driver\Src\stm32h7xx_hal_tim_ex.o
Compiling .pio\build\my_env\libe47\cube_ide\Drivers\STM32H7xx_HAL_Driver\Src\stm32h7xx_hal_uart.o
Compiling .pio\build\my_env\libe47\cube_ide\Drivers\STM32H7xx_HAL_Driver\Src\stm32h7xx_hal_uart_ex.o
Compiling .pio\build\my_env\libe47\cube_ide\Drivers\STM32H7xx_HAL_Driver\Src\stm32h7xx_ll_delayblock.o
Compiling .pio\build\my_env\libe47\cube_ide\Drivers\STM32H7xx_HAL_Driver\Src\stm32h7xx_ll_sdmmc.o
Compiling .pio\build\my_env\libe47\cube_ide\Drivers\STM32H7xx_HAL_Driver\Src\stm32h7xx_ll_usb.o
Compiling .pio\build\my_env\libe47\cube_ide\FATFS\App\fatfs.o
Compiling .pio\build\my_env\libe47\cube_ide\FATFS\Target\bsp_driver_sd.o
Compiling .pio\build\my_env\libe47\cube_ide\FATFS\Target\fatfs_platform.o
Compiling .pio\build\my_env\libe47\cube_ide\FATFS\Target\sd_diskio.o
Compiling .pio\build\my_env\libe47\cube_ide\Middlewares\ST\STM32_USB_Device_Library\Class\CDC\Src\usbd_cdc.o
Compiling .pio\build\my_env\libe47\cube_ide\Middlewares\ST\STM32_USB_Device_Library\Core\Src\usbd_core.o
Compiling .pio\build\my_env\libe47\cube_ide\Middlewares\ST\STM32_USB_Device_Library\Core\Src\usbd_ctlreq.o
Compiling .pio\build\my_env\libe47\cube_ide\Middlewares\ST\STM32_USB_Device_Library\Core\Src\usbd_ioreq.o
Compiling .pio\build\my_env\libe47\cube_ide\Middlewares\Third_Party\FatFs\src\diskio.o
Compiling .pio\build\my_env\libe47\cube_ide\Middlewares\Third_Party\FatFs\src\ff.o
Compiling .pio\build\my_env\libe47\cube_ide\Middlewares\Third_Party\FatFs\src\ff_gen_drv.o
Compiling .pio\build\my_env\libe47\cube_ide\Middlewares\Third_Party\FatFs\src\option\ccsbcs.o
Compiling .pio\build\my_env\libe47\cube_ide\Middlewares\Third_Party\FatFs\src\option\syscall.o
Compiling .pio\build\my_env\libe47\cube_ide\Middlewares\Third_Party\FreeRTOS\Source\CMSIS_RTOS\cmsis_os.o
Compiling .pio\build\my_env\libe47\cube_ide\Middlewares\Third_Party\FreeRTOS\Source\croutine.o
Compiling .pio\build\my_env\libe47\cube_ide\Middlewares\Third_Party\FreeRTOS\Source\event_groups.o
Compiling .pio\build\my_env\libe47\cube_ide\Middlewares\Third_Party\FreeRTOS\Source\list.o
Compiling .pio\build\my_env\libe47\cube_ide\Middlewares\Third_Party\FreeRTOS\Source\portable\GCC\ARM_CM4F\port.o
Compiling .pio\build\my_env\libe47\cube_ide\Middlewares\Third_Party\FreeRTOS\Source\queue.o
Compiling .pio\build\my_env\libe47\cube_ide\Middlewares\Third_Party\FreeRTOS\Source\stream_buffer.o
Compiling .pio\build\my_env\libe47\cube_ide\Middlewares\Third_Party\FreeRTOS\Source\tasks.o
Compiling .pio\build\my_env\libe47\cube_ide\Middlewares\Third_Party\FreeRTOS\Source\timers.o
Compiling .pio\build\my_env\libe47\cube_ide\USB_DEVICE\App\usb_device.o
Compiling .pio\build\my_env\libe47\cube_ide\USB_DEVICE\App\usbd_cdc_if.o
Compiling .pio\build\my_env\libe47\cube_ide\USB_DEVICE\App\usbd_desc.o
Compiling .pio\build\my_env\libe47\cube_ide\USB_DEVICE\Target\usbd_conf.o
Compiling .pio\build\my_env\lib0db\system\startup.o
Compiling .pio\build\my_env\lib924\Unity\unity.o
Compiling .pio\build\my_env\src\main.o
In file included from .pio\libdeps\my_env\Unity\src\unity.h:21:0,
                 from .pio\libdeps\my_env\Unity\src\unity.c:7:
.pio\libdeps\my_env\Unity\src\unity_internals.h:11:10: fatal error: unity_config.h: No such file or directory
* Looking for unity_config.h dependency? Check our library registry!
* CLI  > platformio lib search "header:unity_config.h"
* Web  > https://registry.platformio.org/search?q=header:unity_config.h
 #include "unity_config.h"
*** [.pio\build\my_env\lib924\Unity\unity.o] Error 1
=============================================================== [FAILED] Took 27.59 seconds ===============================================================
 *  The terminal process "C:\Users\user\.platformio\penv\Scripts\platformio.exe 'run'" terminated with exit code: 1.
Anybody has any idea why the Unity dependency is not detected automatically as it should?
OK, found it. My platformio.ini has test_platform=custom. Should be test_platform=unity (default).
