I am trying to setup unit testing for an STM32 project, and I need to use a custom unity_config file to make it work. I need to include my usart.h file so I can setup the USART without having to copy and paste a lot of code, but when I run test I keep getting the same errors:
.pio/build/disco_f072rb/test/unity_config.o: In function `unityOutputStart':
unity_config.c:(.text.unityOutputStart+0x2): undefined reference to `MX_USART3_Init'
.pio/build/disco_f072rb/test/unity_config.o: In function `unityOutputChar':
unity_config.c:(.text.unityOutputChar+0x18): undefined reference to `husart3'
.pio/build/disco_f072rb/test/unity_config.o: In function `unityOutputFlush':
unity_config.c:(.text.unityOutputFlush+0x4): undefined reference to `HAL_USART_FlushRxFifo'
unity_config.c:(.text.unityOutputFlush+0xc): undefined reference to `husart3'
Here are my config files. Note that unity_config.h is unchanged from the example in the documentation and is included here for completeness only. Also note that I have tried both the relative path to usart.h as shown here, as well as just the name assuming the correct include directory the way I would do typically. Neither has worked.
unity_config.h
#ifndef UNITY_CONFIG_H
#define UNITY_CONFIG_H
#ifndef NULL
#ifndef __cplusplus
#define NULL (void*)0
#else
#define NULL 0
#ifdef __cplusplus
extern "C"
void unityOutputStart();
void unityOutputChar(char);
void unityOutputFlush();
void unityOutputComplete();
#define UNITY_OUTPUT_START() unityOutputStart()
#define UNITY_OUTPUT_CHAR(c) unityOutputChar(c)
#define UNITY_OUTPUT_FLUSH() unityOutputFlush()
#define UNITY_OUTPUT_COMPLETE() unityOutputComplete()
#ifdef __cplusplus
#endif /* extern "C" */
#endif /* UNITY_CONFIG_H */
unity_config.c
#include "unity_config.h"
#include "../Inc/usart.h"
void unityOutputStart() {
MX_USART3_Init();
void unityOutputChar(char c) {
HAL_USART_Transmit(&husart3, (uint8_t*)&c, 1, 0xFFFF);
void unityOutputFlush() {
HAL_USART_FlushRxFifo(&husart3);
void unityOutputComplete() {}
