Hi all,
I’m using Unity for running tests for Arduino.
I have tests which isn’t working well on any local environment (using vscode) since I upgraded to platformio 6.0.X.
I fixed the directories according to the new hierarchy and still I have an issue.
I’ve entered a failing assertion into the test, and expected to see it in the summary of the tests run.
When I’m running platformio test --environment pico32 -v
command I see the following results:
Processing test_parsing in pico32 environment
Building & Uploading...
1 Tests 1 Failures 0 Ignored
FAIL
--------------------------------------------------------------------- pico32:test_parsing [PASSED] Took 12.19 seconds ---------------------------------------------------------------------
========================================================================================= SUMMARY =========================================================================================
Environment Test Status Duration
pico32 test_parsing SKIPPED 00:00:12.186
======================================================================== 0 test cases: 0 succeeded in 00:00:12.186 ========================================================================
the tests file code is similar to any examples file (using setup()
and loop()
methods) and it also works on our CI procedure.
any ideas how to fix this?
thanks
