I have my code fully working and have decided, mid project (I know bad decision), to start implementing unit testing. I have gone through the tutorials and have had no issues getting it all working. But with my current code I am having issues getting it working. When trying to run my unit tests I keep getting the errors of "multiple definitions of loop(); and setup(). That being said my code works perfectly and I have no compile or build errors with it.
When I am doing the tutorials or starting a new project, where I have a setup/loop function in both the main src dir and the test dir, I have no issues. But in this project, I keep getting this error.
You are telling PlatformIO to compile the src/ folder when testing. As the GCC error message tells you, your src/main.cpp and test/test_main.cpp both want to define the functions setup() and loop(), so that won’t work – only one can implement this.
Review if you really need the source folder to be built, and remove it if not necessary. If you do need src to be built, surround the implementations of setup() and loop() with #ifndef UNIT_TEST in src/main.cpp, just like the documentation says.
All the code I have written is in src, so I would like that tested. I have put the #ifndef UNIT_TEST statement in and it is working a bit better now. The same issue is still coming up now I have put the #ifndef and #endif around the src main and setup functions. So not sure what the issue is now.
I have a similar issue, using test_build_project_src = yes with ESP-IDF. I wrapped the app_main() in my src/main.c with #ifndef UNIT_TEST. However, the build still failed due to multiple definitions of app_main.
It seems like the UNIT_TEST build flag isn’t actually being supplied at build-time for some reason. I was able to work around it with a custom pre-script that looks something like this:
from SCons.Script import COMMAND_LINE_TARGETS
Import("env")
def add_build_flags():
if "__test" in COMMAND_LINE_TARGETS:
env.Append(CCFLAGS=["-DUNIT_TEST=1"])
add_build_flags()
With this in place, the #ifndef UNIT_TEST actually works.
Yup, I see that, but it doesn’t seem to be happening in this case. My project is pretty large, I’m guessing @luke.m.coffey is closer to having a minimally-reproducible example.
