_joku
April 15, 2022, 3:18pm
#1
While working on a project (avaanchor
directory) I have written a library (protocol
directory) for de/serializing network packets, that I now also want to use in a different project (avanode
directory). Moving the library a few levels up and including it using it with lib_extra_dirs = ${PROJECT_DIR}/../../common_libs
worked fine and builds. However, there are unit tests in the test/
subdirectory of the first project that now won’t compile, because a header inside the moved library can’t be found.
This is my folder structure:
├── avaanchor
│ ├── feather-firmware
│ │ ├── include
│ │ │ └── README
│ │ ├── lib
│ │ │ └── README
│ │ ├── platformio.ini
│ │ ├── src
│ │ │ ├── main.cpp
│ │ │ └── send_lora_command.py
│ │ └── test
│ │ ├── README
│ │ └── test_protocol.cpp
├── avanode
│ └── README.md
├── common_libs
│ ├── config
│ │ └── config.h
│ ├── id_manager
│ ├── logging
│ │ ├── macros.h
│ │ ├── PriUint64.h
│ │ └── Streaming.h
│ └── protocol
│ ├── fields
│ │ ├── BinaryData.h
│ │ ├── GenericField.h
│ │ ├── NetworkNumber.h
│ │ ├── PacketType.cpp
│ │ ├── PacketType.h
│ │ ├── UnitID.cpp
│ │ └── UnitID.h
│ └── packets
│ ├── AddressablePacket.cpp
│ ├── AddressablePacket.h
│ ├── Command.h
│ ├── GenericPacket.cpp
│ ├── GenericPacket.h
│ ├── RangeRequest.h
│ └── StatusReport.h
This is the platformio.ini
for the first project:
[common]
[common_embedded]
extends = common
platform = atmelsam
board = adafruit_feather_m0
lib_deps = mikem/RadioHead@^1.113, adafruit/Adafruit INA219 @ ^1.1.1, adafruit/Adafruit SHTC3 Library @ ^1.0.0
[env:debug]
extends = common_embedded
build_flags = -D DEBUG_ON
[env:release]
[env:test_native]
extends = common
platform = native
test_ignore = test_embedded
build_flags = -g -O0
And finally the error log when trying to run test_native > Advanced > Test
in the sidebar:
Collected 1 items
Processing * in test_native environment
Building...
/home/joku/SHK/avarange/common_libs/protocol/fields/PacketType.cpp:2:10: fatal error: macros.h: No such file or directory
* Looking for macros.h dependency? Check our library registry!
* CLI > platformio lib search "header:macros.h"
* Web > https://registry.platformio.org/search?q=header:macros.h
2 | #include <macros.h>
/home/joku/SHK/avarange/common_libs/protocol/fields/UnitID.cpp:2:10: fatal error: macros.h: No such file or directory
compilation terminated.
*** [.pio/build/test_native/lib18c/protocol/fields/UnitID.o] Error 1
*** [.pio/build/test_native/lib18c/protocol/fields/PacketType.o] Error 1
In file included from test/test_protocol.cpp:1:
/home/joku/SHK/avarange/common_libs/protocol/fields/BinaryData.h:6:10: fatal error: macros.h: No such file or directory
6 | #include <macros.h>
*** [.pio/build/test_native/test/test_protocol.o] Error 1
================================================================= [FAILED] Took 4.89 seconds =================================================================
Test Environment Status Duration
* test_native FAILED 00:00:04.889
=========================================================== 1 failed, 0 succeeded in 00:00:04.889 ===========================================================
The terminal process "platformio 'test', '--environment', 'test_native'" terminated with exit code: 1.
I really don’t know what is wrong, since both debug and release targets build and there are no changes to options for the test_native
target that mess with the library dependency finder. Does anyone have experience with this and have an idea what I am doing wrong? Also, ideally, I want to have the unit tests together with the library code in a single directory. Is there any way to do this?
Thank You!
Please add lib_ldf_mode = chain+
and on the CLI , do pio test -e test_native --without-upload --without-testing -v
and post the output.
_joku
April 15, 2022, 6:38pm
#3
Collected 1 items
Building...
LDF Modes: Finder ~ chain+, Compatibility ~ soft
Framework incompatible library /home/joku/SHK/avarange/common_libs/logging
More details about "Library Compatibility Mode": https://docs.platformio.org/page/librarymanager/ldf.html#ldf-compat-mode
Found 3 compatible libraries
|-- <protocol> (/home/joku/SHK/avarange/common_libs/protocol)
| |-- <config> (/home/joku/SHK/avarange/common_libs/config)
g++ -o .pio/build/test_native/test/test_protocol.o -c -g -O0 -DPLATFORMIO=50205 -DUNIT_TEST -DUNITY_INCLUDE_CONFIG_H -Iinclude -Isrc -I/home/joku/SHK/avarange/common_libs/protocol -I/home/joku/SHK/avarange/common_libs/config -I.pio/build/test_native/UnityTestLib -I/home/joku/.platformio/packages/tool-unity test/test_protocol.cpp
gcc -o .pio/build/test_native/test/tmp_pio_test_transport.o -c -g -O0 -DPLATFORMIO=50205 -DUNIT_TEST -DUNITY_INCLUDE_CONFIG_H -Iinclude -Isrc -I/home/joku/SHK/avarange/common_libs/protocol -I/home/joku/SHK/avarange/common_libs/config -I.pio/build/test_native/UnityTestLib -I/home/joku/.platformio/packages/tool-unity test/tmp_pio_test_transport.c
g++ -o .pio/build/test_native/lib18c/protocol/fields/PacketType.o -c -g -O0 -DPLATFORMIO=50205 -DUNIT_TEST -DUNITY_INCLUDE_CONFIG_H -I/home/joku/SHK/avarange/common_libs/protocol -I/home/joku/SHK/avarange/common_libs/config -I.pio/build/test_native/UnityTestLib -I/home/joku/.platformio/packages/tool-unity /home/joku/SHK/avarange/common_libs/protocol/fields/PacketType.cpp
g++ -o .pio/build/test_native/lib18c/protocol/fields/UnitID.o -c -g -O0 -DPLATFORMIO=50205 -DUNIT_TEST -DUNITY_INCLUDE_CONFIG_H -I/home/joku/SHK/avarange/common_libs/protocol -I/home/joku/SHK/avarange/common_libs/config -I.pio/build/test_native/UnityTestLib -I/home/joku/.platformio/packages/tool-unity /home/joku/SHK/avarange/common_libs/protocol/fields/UnitID.cpp
====================================================================== [FAILED] Took 0.70 seconds ======================================================================
Hm a file within protocol
seems to need macros.h
which is in the logging
library, but the dependency is not recognized.
Please add
protocol
config
logging
to the platformio.ini
and retry the previous command.
_joku
April 15, 2022, 6:44pm
#5
seems to be the same error
Collected 1 items
Building...
Library Manager: Installing logging
Warning! Could not find the package with 'logging' requirements for your system 'linux_x86_64'
g++ -o .pio/build/test_native/lib18c/protocol/packets/AddressablePacket.o -c -g -O0 -DPLATFORMIO=50205 -DUNIT_TEST -DUNITY_INCLUDE_CONFIG_H -I/home/joku/SHK/avarange/common_libs/protocol -I/home/joku/SHK/avarange/common_libs/config -I.pio/build/test_native/UnityTestLib -I/home/joku/.platformio/packages/tool-unity /home/joku/SHK/avarange/common_libs/protocol/packets/AddressablePacket.cpp
In file included from /home/joku/SHK/avarange/common_libs/protocol/packets/GenericPacket.h:4,
from /home/joku/SHK/avarange/common_libs/protocol/packets/AddressablePacket.h:3,
from /home/joku/SHK/avarange/common_libs/protocol/packets/AddressablePacket.cpp:1:
/home/joku/SHK/avarange/common_libs/protocol/fields/NetworkNumber.h:5:10: fatal error: macros.h: No such file or directory
5 | #include <macros.h>
*** [.pio/build/test_native/lib18c/protocol/packets/AddressablePacket.o] Error 1
====================================================================== [FAILED] Took 1.46 seconds ======================================================================
it seems to find it but it is “framework incompatible”. what does that mean?
Can you place an explicit #include <macros.h>
in the test .cpp file?
Can you show how protocol/fields/PacketType.cpp
includes macros.h? Are there any conditional inclusion macros in there like in Library dependency not recognized in conditional include · Issue #4152 · platformio/platformio-core · GitHub ?
_joku
April 15, 2022, 6:58pm
#9
PacketType.cpp just includes it without any #ifdefs etc
but macros.h itself has some. Could that be the problem?
here is macros.h for reference:
#pragma once
#if defined(UNIT_TEST)
#include <iostream>
#define PRINT_OUT std::cout
#define ENDL std::endl
#else
// clang-format off
#include "Streaming.h"
#include "PriUint64.h"
// clang-format on
#define PRINT_OUT Serial
#define ENDL "\n"
#ifdef DEBUG_ON
#define dbgln(...) \
do { \
PRINT_OUT << __VA_ARGS__ << ENDL; \
} while (0)
#define dbg_only(code) \
do { \
code \
} while (0)
#else
#define dbgln(...)
#define VERIFY(expression) \
do { \
if (!(expression)) { \
dbgln("ASSERTION FAILED: " #expression); \
dbgln("in " << __FILE__ << ":" << __LINE__); \
throw; \
} while (0)
#else
do { \
for (;;) { \
digitalWrite(LED_BUILTIN, LOW); \
delayMicroseconds(500000); \
digitalWrite(LED_BUILTIN, HIGH); \
} while (0)
#define VERIFY_NOT_REACHED() VERIFY(false)
No, the LDF should have recognized the PacketType.cpp → macros dependency…
If you replace the #pragma once
with traditional include guards in some critical header files (the path from the test.cpp to packettype.h and in macros.h) does that help?
_joku
April 15, 2022, 7:27pm
#11
no didn’t change anything
Open a CLI and execute pio upgrade --dev
and retry. If it’s not solved after that, please open an issue at Issues · platformio/platformio-core · GitHub with the reference project.
_joku
April 15, 2022, 7:37pm
#13
yeah that didnt fix it.
I will try to make an issue in the upcoming days.
but tysm for your help
have a nice day!
