Hello, I’m slowly getting familiar with PIO and trying to learn a little bit of how it works under the hood.
Is it possible to understand how the Library Dependency Finder (LDF) led the compiler to a library that caused a missing dependency error? In other words, the dependency chain of who included who until it broke?
For example, my project has a dependency on the Adafruit GFX Library which causes a know dependency error. I now understand how to fix the error thanks to this post and this post. My understanding is that Adafruit GFX Library has an #include <Adafruit_I2CDevice.h> that is not picked up by the LDF by default (lib_ldf_mode = chain) since it’s in the source file Adafruit_GrayOLED.cpp (rather than being in a header file).
The error generated is the following:
Processing mkrwifi1010 (platform: atmelsam; board: mkrwifi1010; framework: arduino)
------------------------------------------------------------------------------------------------------------------------------------------------------------------Verbose mode can be enabled via `-v, --verbose` option
CONFIGURATION: https://docs.platformio.org/page/boards/atmelsam/mkrwifi1010.html
PLATFORM: Atmel SAM (6.3.0) > Arduino MKR WiFi 1010
HARDWARE: SAMD21G18A 48MHz, 32KB RAM, 256KB Flash
DEBUG: Current (atmel-ice) External (atmel-ice, blackmagic, jlink)
- framework-arduino-samd 1.8.11
- framework-cmsis 1.40500.0 (4.5.0)
- framework-cmsis-atmel 1.2.2
LDF Modes: Finder ~ chain+, Compatibility ~ soft
Found 36 compatible libraries
|-- <Arduino_MKRIoTCarrier> 1.0.2
| |-- <Wire> 1.0
| |-- <Arduino_BQ24195> 0.9.1
| | |-- <Wire> 1.0
| |-- <Arduino_APDS9960> 1.0.3
| | |-- <Wire> 1.0
| |-- <Arduino_LPS22HB> 1.0.1
| | |-- <Wire> 1.0
| |-- <Arduino_LSM6DS3> 1.0.0
| | |-- <Wire> 1.0
| | |-- <SPI> 1.0
| |-- <SPI> 1.0
| |-- <Arduino_HTS221> 1.0.0
| | |-- <Wire> 1.0
| |-- <Arduino_MCHPTouch> 1.2.1
| |-- <SD> 0.0.0-alpha+sha.041f788250
| | |-- <SPI> 1.0
| |-- <Adafruit GFX Library> 1.10.10
| | |-- <SPI> 1.0
| | |-- <Wire> 1.0
| |-- <Adafruit ST7735 and ST7789 Library> 1.7.3
| | | |-- <SPI> 1.0
| | | |-- <Wire> 1.0
| | |-- <SPI> 1.0
| |-- <Adafruit DotStar> 1.1.4
| | |-- <SPI> 1.0
|-- <ArduinoIoTCloud> 1.1.1
| |-- <ArduinoECCX08> 1.3.5
| | |-- <Wire> 1.0
| |-- <Wire> 1.0
| |-- <Arduino_DebugUtils> 1.1.0
| |-- <Arduino_ConnectionHandler> 0.6.4
| | |-- <WiFiNINA> 1.8.13
| | | |-- <SPI> 1.0
| | |-- <SPI> 1.0
| |-- <RTCZero> 1.6.0
| |-- <ArduinoMqttClient> 0.1.5
| | |-- <SPI> 1.0
| |-- <SPI> 1.0
|-- <RTCZero> 1.6.0
|-- <Wire> 1.0
| |-- <Wire> 1.0
| |-- <Wire> 1.0
| |-- <Wire> 1.0
| |-- <Wire> 1.0
| |-- <SPI> 1.0
|-- <SPI> 1.0
| |-- <Wire> 1.0
| |-- <SPI> 1.0
| |-- <SPI> 1.0
| |-- <Wire> 1.0
| | |-- <SPI> 1.0
| | |-- <Wire> 1.0
| |-- <SPI> 1.0
| |-- <SPI> 1.0
Compiling .pio\build\mkrwifi1010\lib581\Adafruit GFX Library\Adafruit_GrayOLED.cpp.o
In file included from .pio\libdeps\mkrwifi1010\Adafruit GFX Library\Adafruit_GrayOLED.cpp:20:0:
.pio\libdeps\mkrwifi1010\Adafruit GFX Library\Adafruit_GrayOLED.h:30:10: fatal error: Adafruit_I2CDevice.h: No such file or directory
* Looking for Adafruit_I2CDevice.h dependency? Check our library registry!
* CLI > platformio lib search "header:Adafruit_I2CDevice.h"
* Web > https://platformio.org/lib/search?query=header:Adafruit_I2CDevice.h
compilation terminated.
Archiving .pio\build\mkrwifi1010\lib74d\libArduinoECCX08.a
Archiving .pio\build\mkrwifi1010\libb8d\libArduino_DebugUtils.a
Compiling .pio\build\mkrwifi1010\libc61\WiFiNINA\utility\WiFiSocketBuffer.cpp.o
Compiling .pio\build\mkrwifi1010\libc61\WiFiNINA\utility\nano_rp2040_support.cpp.o
Compiling .pio\build\mkrwifi1010\libc61\WiFiNINA\utility\server_drv.cpp.o
Compiling .pio\build\mkrwifi1010\libc61\WiFiNINA\utility\spi_drv.cpp.o
Compiling .pio\build\mkrwifi1010\libc61\WiFiNINA\utility\wifi_drv.cpp.o
Compiling .pio\build\mkrwifi1010\liba7c\Arduino_ConnectionHandler\Arduino_ConnectionHandler.cpp.o
Compiling .pio\build\mkrwifi1010\liba7c\Arduino_ConnectionHandler\Arduino_GSMConnectionHandler.cpp.o
Compiling .pio\build\mkrwifi1010\liba7c\Arduino_ConnectionHandler\Arduino_LoRaConnectionHandler.cpp.o
Compiling .pio\build\mkrwifi1010\liba7c\Arduino_ConnectionHandler\Arduino_NBConnectionHandler.cpp.o
*** [.pio\build\mkrwifi1010\lib581\Adafruit GFX Library\Adafruit_GrayOLED.cpp.o] Error 1
================================ [FAILED] Took 19.31 seconds ================================
How can I know which file included Adafruit_GrayOLED.cpp or Adafruit_GrayOLED.h? I did a global search and could not find such references.
Because I could not find any references to one of these two files from any other library, I’m suspecting that PIO is compiling all the files inside /libdeps/Adafruit GFX Library (rather than just the files listed in a #include statement). Is my suspicion correct? (library’s github repo)
Any references to documentation or related articles would be greatly appreciated. Thanks.
