Undefined reference to method, even though method is defined
I created a template class EWMA in my project, but when using the class in my main.cpp, I get an undefined reference to EWMA<int, 2>::EWMA(float) Error. The .h and .cpp files of this class are inside lib/EWMA/. The .h file looks as following:
#ifndef _EWMA_H
#define _EWMA_H
#include <Filter.h>
template<typename T, int dimensions = 1>
class EWMA : public Filter<T, dimensions> {
public:
    EWMA(float alpha[dimensions]);
    EWMA(float alpha = 0.2);
    std::array<T, dimensions> addValue(T value[dimensions]);
private:
    float alpha[dimensions];
    T value[dimensions];
    bool hasValue = false;
The .cpp file looks like this:
#include <EWMA.h>
template<typename T, int dimensions>
EWMA<T, dimensions>::EWMA(float alpha[dimensions]) {
    this->alpha = alpha;
EWMA<T, dimensions>::EWMA(float alpha) {
    for (int i = 0; i < dimensions; i++) {
        this->alpha[i] = alpha;
std::array<T, dimensions> EWMA<T, dimensions>::addValue(T value[]) {
    this->value = this->hasValue ? (1 - this->alpha) * this->value + this->alpha * value : value;
    return this->value;
A very strong simplification of the main.cpp file is as following:
#include <EWMA.h>
EWMA<int, 3>* filter = new EWMA<int, 3>();
Here I get the undefined reference to EWMA<int, 3>::EWMA(float)’` Error, indicating that the method might be declared, but not defined. When I move the content of EWMA.cpp to the .h file, everything compiles fine. I’m not even sure if that is a problem with PlatformIO or if I am missing something about C++ or something completely different.
Any help is much appreciated.
BTW, my other classes in the lib/ folder work just fine.
You cannot implement templates in cpp files that way. See Standard C++. Not a PlatformIO error, purely C++ error.
